TRD E-Locked rear 8" COMPLETE
Discussion in 'Buy / Sell / Trade' started by SilverSeven, Nov 12, 2009.
  1. Nov 12, 2009 at 5:06 PM
    SilverSeven
    SilverSeven [OP] Rock Solid Toy
    Jordon
    South Jurzee
    6" 35s mud and scratched to shit
    hub to hub out of my 07. 28k on it. stock gears.
    asking $1200 obo
  2. Nov 12, 2009 at 5:14 PM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    Does this mean that the build is underway?
  3. Nov 12, 2009 at 5:14 PM
    SilverSeven
    Jordon
    South Jurzee
    I got a deal on a set of FZJ80 axles front and rear so I am going to be using the 9.5 elocked third in a diamond housing out back.
    thanks dude!
  4. Nov 13, 2009 at 6:58 AM
    jonny
    jonny Betty White Edition Heep ZJ
    very nice man!
    free bump for you
  5. Nov 13, 2009 at 7:06 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
  6. Nov 13, 2009 at 7:10 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Me want, me 2 far away:mad:
  7. Nov 13, 2009 at 7:13 AM
    SilverSeven
    Jordon
    South Jurzee
    updated with the only picture i have.
    I cant afford a digital camera, in fact keep your eye out for a for sale thread for my left nut.
    Where are you located Taco Prerunner?
  8. Nov 13, 2009 at 8:26 AM
    nelztaco
    nelztaco Well-Known Member
    Neil
    Levittown, PA
    09 TRD Sport DCLB 4x4 SW
    UNDERCOVER, EIBACH COILS, TSB 4 LEAFS, TRD WHEELS, 255/85R16 KM2
    Damnit! I'm broke.
  9. Nov 13, 2009 at 8:28 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Is everything in the pic included?
  10. Nov 13, 2009 at 8:48 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I was being funny. :smack:
  11. Nov 13, 2009 at 9:09 AM
    SACTOWN
    SACTOWN Well-Known Member
    Greg
    Is it possible for some one to "reverse it" and turn it into a sas front swap?
  12. Nov 13, 2009 at 9:21 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    I suppose anything's possible but you'll have a heck of a time clearancing the front driveshaft. The pinion is more or less centered on rear axles, while front axles generally have it offset to get around the engine, oil pan, and everything else. Remember that the transfer case front output is offset for this reason as well.
    Bump for a good guy's sale. :)
  13. Nov 13, 2009 at 9:27 AM
    SACTOWN
    Greg
    Bumb. Wow sounds like alot of work!! Good product though
  14. Nov 13, 2009 at 10:17 AM
    SilverSeven
    Jordon
    South Jurzee
    yeah like mjp2 said it would be hard. More so with toyota axles because they are not "tubed" per-se
    with a dana there are axle tubes taht set in the pumpkin that can be removed and replaced with any length tube you want, but a toyota housing is 1 piece and then the third plugs into it.
  15. Nov 13, 2009 at 11:44 AM
    sonjay
    sonjay Well-Known Member
    I would love to get that off you but a little bit too much highways between us haha. Just wondering how come you don't just use the 80 axles as they are? Bump
  16. Nov 13, 2009 at 11:48 AM
    higherlux
    higherlux Well-Known Member
    Blake
    middle of S.C.
    1998 tacoma 2.7l 4wd/1986 POS
    Mall crawler status
    i want it
    will you take 3 bucks for it
    ill pick it up
  17. Nov 13, 2009 at 11:49 AM
    SilverSeven
    Jordon
    South Jurzee
    Well i came up on these 80 axles just last week, the diamond i have had on order since september 2nd. I have learned a lot through this process and one thing i have just learned is that this 80 front end is BEEF. It uses bigger knuckle balls and birfs. One could technically use an 80 front end in a sas, on the newer tacos you would want to run probably a 1" wheel spacer or so. I will actually be selling the front 80 without the 3rd member because that is all i am using of the front.
    Edit: also to use an 80 axle up front you would need to replace your transfercase with passenger side output, which isnt necesarily as easy as u would hope.
    The rear 80 axle has an offset pumpkin, which has been used in tacomas with minimal issues, but this axle is complete so i would just as soon get a sweet diamond housing for it with a centered pumpkin and chromoly shafts, it will run me about 1200 but to me its worth it.
    i didnt see where you were from before i hit reply, but ground freight is not TOO bad i dont think.
  18. Nov 13, 2009 at 11:53 AM
    SilverSeven
    Jordon
    South Jurzee
    this suit is black not.
  19. Nov 13, 2009 at 4:53 PM
    sonjay
    For sure the diamond axle is a sweet unit! I was just wondering is all. Thanks for answering, I was thinking the front would make a wicked SAS swap, elec locker, BEEFY... Not as good as a diamond axle though! By the way I'm on the west coast of Canada... ground freight isn't cheap enough.
  20. Nov 13, 2009 at 10:08 PM
    nelztaco
    Neil
    Levittown, PA
    C'mon Powerball!
