TRD E-Locker Capabilities??
Discussion in 'Off-Roading & Trails' started by PreRunning, Aug 31, 2012.
  1. Aug 31, 2012 at 9:43 AM
    PreRunning
    PreRunning [OP] Well-Known Member
    Clayton
    Missouri
    01 Lunar Mist Prerunner SR5
    Window Vents, Westin Bull Bars, Kenwood Deck, Kicker and Kenwood Door and rear Speakers, Alpine 660 RMS Amp, Twin Kicker 12 inch CompVR Series Subs, 265/75/16 Wrangler ArmorTrac Tires, Uhaul Towing package, removed mud flaps, Flowmaster 40, Cold Air.
    Really curious on the capabilties on them. I have the TRD prerunner thats an 01. I would love to use it more but that sticker by the steering wheel limits it at 5 mph! im scared to even use it. Need some advice on the subject!:confused:
  2. Aug 31, 2012 at 10:18 PM
    s7racing
    s7racing Well-Known Member
    If your on loose soil you can rip at any speed. Every time I'm off road use it. I have been over 100 with the rear locked
  3. Aug 31, 2012 at 10:26 PM
    650H1
    650H1 Well-Known Member
    NH
    2010 Tundra TRD OR C/M 5.7l 4x4
    really?
  4. Aug 31, 2012 at 10:30 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Calgary
    2006 Campster Mobile
    My truck is MAGIC
    Having the rear end locked makes ZERO difference when you're going fast. If you turn, that's a different story.
  5. Aug 31, 2012 at 10:31 PM
    IDtrucks
    IDtrucks My screen name is now slightly incorrect...
    Mark "Buck"
    Jackson Wyoming
    why?:confused:
    You can certainly go over 5mph with it while off roading, don't worry. No need to ever have it on while driving on the road of course. The only real way to test the capabilities of your truck is to get out and wheel it. Drive it till you get stuck and you know where you need more practice.
  6. Aug 31, 2012 at 10:33 PM
    Spoonman
    Jamie
    Calgary
    My truck is MAGIC
    Offroad unlocked, get stuck, engage locker, get free. If you can't, get a tug :D
    CedarPark likes this.
  7. Aug 31, 2012 at 10:51 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    paging David K..
  8. Aug 31, 2012 at 10:52 PM
    maxamillion2345
    maxamillion2345 Make Nevada Great Again, build the wall
    Max
    Nevada
    80 series LC
    Tons and 40s
    I drove on mine locked at 55-75 mph for 700 miles, but one side gear was broken, so I could still turn, and then I pulled the diff and put a new one in. :D
  9. Aug 31, 2012 at 10:53 PM
    Spoonman
    Jamie
    Calgary
    My truck is MAGIC
    If you understand what a locker does, and how it works, you wont need an explanation.
  10. Aug 31, 2012 at 10:54 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    I turn mine on when I see a hairy situation ahead (giggity)
    never failed me
  11. Aug 31, 2012 at 10:55 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    lol, in that case, you being locked was really you being open diff. so it balances out.
  12. Aug 31, 2012 at 11:11 PM
    maxamillion2345
    Max
    Nevada
    80 series LC
    Tons and 40s
    The locker was still engaged but I wasn't mechanically connected to one wheel so it turned freely. The only difference there was that I could turn with the locker engaged, and it also made the truck pull madly to the right. Or push really. Point is that the locker was engaged at 75mph from Salt lake to Reno and varying speeds from Moab to SLC.
    Without a broken sidegear you'd be fine 75mph as long as you didn't turn or you were on a soft surface.
  13. Sep 1, 2012 at 8:28 AM
    s7racing
  14. Sep 2, 2012 at 7:41 AM
    PreRunning
    Clayton
    Missouri
    Ok so what's with not being able to turn? It seems counterproductive to lock the diff and not turn.
  15. Sep 2, 2012 at 7:54 AM
    Rakso
    Rakso CeRaTi
    OsKaR
    California
    09 PreRunner SR5
    King RR w/adjusters, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    E locker differential is capable of getting your truck where open differential woul not. Also it will save you from getting stuck.
  16. Sep 2, 2012 at 8:16 AM
    TROKITA
    TROKITA Well-Known Member
    Arty
    Utah, the valley
    98 tacoma TRD supercharged
    Supercharged, Custom sunroof, 6 inch lift, wheel spacers, over the rail tire carrier
    Having the locker locked on the road can ruin your tires every time you turn YouTube (how axles work) and it will show you why. It's also fun when its raining. Lock it up and go siding on the turns =)
  17. Sep 2, 2012 at 8:23 AM
    TROKITA
    Arty
    Utah, the valley
    I forgot to mention that 5 mph warning sticker is probably there cause you can push the Button at 5mph max. Don't ever try to lock the diff at a high speed
  18. Sep 2, 2012 at 8:28 AM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    he was referring to racing in the dirt i believe...
    at least i HOPE he isn't on city streets at them speeds... hahaha
  19. Sep 2, 2012 at 8:33 AM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    but yah, as stated above, you just need to have the truck under 5mph to safely engage the locker... once locked, you can hit just about any speed in the dirt...
    also, when ready to unlock, just take the truck back down to a crawl...
    when i lock mine, i do it at a stop, then i roll the truck forward until i hear the locker click in the rear and the RR DIFF LOCK button goes from flashing to solid...
    if it doesn't engage right away, i roll forward and turn the wheel to allow the rear axles to line up... same can be done when unlocking...
    x3 on not driving on the street locked... the tires will hate it, and it attracts too much attention from cops who will think you are taking a turn too hard...
    ARCHIVE likes this.
  20. Sep 2, 2012 at 9:00 AM
    PreRunning
    Clayton
    Missouri
    Ok thanks a lot guys! I had always wondered why the truck was classified as an "off road" truck but I only had 1 wheel spinning and couldn't use the diff above 5mph. I feel a lot better about using it now. Again thanks for all your help!
