TRD E-Locker Rear end $
Discussion in '1st Gen Tacoma Parts Marketplace (1995-2004)' started by So.Cal Taco, Feb 20, 2012.
  1. Feb 20, 2012 at 1:59 PM
    So.Cal Taco
    So.Cal Taco [OP] Well-Known Member
    Jeremy
    So.Cal
    1996 4x4 v6
    Total Chaos Long travel Total Chaos Spindle Gussets, Nathan Air Chime K3LA's,Onboard Air system,K&N intake,Chuys 200 plus Amp Alternator,All Pro front Bumper,Lots of Dynamat,99 tacoma Gas Tank Mod ''Secret'' maybe I'll Tell
    I have a complete Trd e-locker rear end off a 2000 Tacoma also with it a brand new 12 volt guy e locker switch with blue L.E.D and the cable $500 I will not ship So.california
  2. Feb 20, 2012 at 2:02 PM
    Chipskip
    Chipskip N7MCS
    Chip
    Green Ridge, MO
    07 Tundra
    :censored: where is my tax return.... I want so bad!
    GLWS!
  3. Feb 20, 2012 at 2:05 PM
    So.Cal Taco
    Jeremy
    So.Cal
    1996 4x4 v6
  4. Feb 20, 2012 at 2:52 PM
    JSFoster75
    JSFoster75 Well-Known Member
    Scott
    Bluff City, TN
    2018 Wrangler JLU Sahara
    Too many to list.
    Man, I'd love to have that... But I'm on the other side of the country... :(
  5. Feb 20, 2012 at 5:22 PM
    06toyoboy
    06toyoboy Well-Known Member
    where in so cal are you located and what is the code on that rear end its an A... number i think
  6. Feb 20, 2012 at 10:35 PM
    BurgerTaco
    BurgerTaco Burger Slinger
    Redlands, CA
    04 Xtra Cab PreRunner
    Will this work on my 03 ext cab??
  7. Feb 20, 2012 at 10:42 PM
    So.Cal Taco
    Jeremy
    So.Cal
    1996 4x4 v6
    I'm near Pomona
  8. Feb 23, 2012 at 9:41 AM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    it should woork
  9. Feb 23, 2012 at 9:49 AM
    higherlux
    higherlux Well-Known Member
    Blake
    middle of S.C.
    1998 tacoma 2.7l 4wd/1986 POS
    Mall crawler status
    why is everything i want on the other side of the country? :(
  10. Feb 24, 2012 at 5:01 PM
    So.Cal Taco
    Jeremy
    So.Cal
    1996 4x4 v6
    On sale $400 takes all.
  11. Feb 24, 2012 at 5:07 PM
    Stout890
    Stout890 Well-Known Member
    Palmdale ca
    99 prerunner sr5
    10" sub, OME881 on Bilstein's, 3" all-pro leaf springs with billies in the back, JBA UCA's, bed cover with custom LED lighting, k&n intake and DT headers, OEM E-locker in the rear. 32" BFG KO2 on steel D window wheels, suicide knob. rebuilt 3RZ w/ stage 1 cam and balance shaft delete . big 3 mod, all new suspension and body mount bushings. cat back magnaflow exhaust.
    why are you getting rid of it? i see you didnt remove the intermediate harness so the 12volt guy harness hasnot been used....leads me to beleive you bought it to put on your truck and never did?
    reason i asked is cuz i did this same swap and it works great and was easy to do..just wondering what stopped you if i am indeed correct that you bought and never instaled
  12. Feb 24, 2012 at 5:28 PM
    buzzard1992
    buzzard1992 Yep
    Alex
    Summerville, SC
    01 4wd trd, 255/85/16 km2s
    5100's with eibachs. And 255/85/16 km2s
    what is the blue LED for?
  13. Feb 24, 2012 at 5:34 PM
    So.Cal Taco
    Jeremy
    So.Cal
    1996 4x4 v6
    Blue L.E.D on the locker switch never installed because I sold truck.
  14. Feb 24, 2012 at 6:54 PM
    Stout890
    Palmdale ca
    99 prerunner sr5
    the blue l.e.d is to indicate a locked or un-locked position
    also 400 is a screaming deal fyi.....these sell for 900$ sometimes, recent one went for 700$ with no wiring and wiring is 150$ from 12volt guy so you figure if the wiring is brand new this locking rear is selling for $250!!!!
    all anyone would really wanna know is whats the gearing ratio in the axle and does the locker actually work?
    look it up on here, lockers are always broke....and a ton of cash to replace (but can be rebuilt). if the locker is indeed working this would be the deal of 2012!!
    OP if you don't know if the locker motor works you can check by applying 3V to pins 3 and 5 i believe on the connector directly on the locking motor and than try spinning the drums to see if locked than swap the polarity of the 3V you applied to pins 3 and 5 to unlock it.
    also how many feet is the harness from 12volt guy? because that will tell which cab configuration it will fit on ex reg cab, ext cab, double cab.
    also buyer should do new brakes and diff fluid change before install. run the diff fluid through cheese cloth to screen out any metal particles to see if the gears are in good condition. large chunks of metal are bad! 190k is quite a bit of miles
    i got my rear end for 200$!!!!!! that was the deal of 2011 though lmao but after 12volt guy harness it was 350$
  15. Feb 26, 2012 at 12:29 AM
    DIRT YOTA
    DIRT YOTA Aka EL ROJO
    Cory
    Camarillo, CA
    03' dbl cab with some stuff
    Stock gearing?
  16. Feb 26, 2012 at 12:32 AM
    Greensystemsgo
    Greensystemsgo 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    good luck with sale! bitchen deal, always thought itd be cool to use this for front somehow.
  17. Feb 27, 2012 at 2:32 PM
    06toyoboy
    Is this still ip for sale
