TRD engine swap
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Remedial man, Feb 12, 2025.
  1. Feb 14, 2025 at 6:58 PM
    Ricardo13x
    Ricardo13x YT: @UrbanOpsOffRoad IG: @urban.ops.offroad
    Upland, CA.
    05 OR DCSB ProRunner(4x4 conv.), Chevy 63”s, NWF EcoCrawler, 35”s
    Random stuff. Oh! and converted to non ADD 4x4.
    Hell yeah dude, I’m a 2g guy and I was like “damn that sucks” good to learn new details :fistbump:
    BLtheP[QUOTED] likes this.
  2. Feb 14, 2025 at 7:01 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    You would...
    Chew likes this.
  3. Feb 14, 2025 at 8:17 PM
    Remedial man
    Remedial man [OP] Member
    Tom
    Its odd really as when i removed the intake so i can double check all my injector seals and harness i put it all back together and it started right up and ran until i shut it off. Then its doing the same thing again, Wants too but just doesn't. But i will check the compression. I did put new plugs in it and the old ones still looked fine. No signs of anything peculiar. Its a JDM engine with 40k but who knows? The old engine was burning oil so i just thought of it to check the catalytic converters? Thanks for everyone's input as its very much appreciated.
  4. Feb 14, 2025 at 8:42 PM
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    For what it’s worth, the long block is a different part number between TRD Off Road and non-TRD Off Road, specifically due to the camshaft ball and block off plate being installed or not.
    Jeff
  5. Feb 14, 2025 at 8:44 PM
    Vlady
    Issy, WA
    Focus on basics- air, fuel, compression, spark.
    Engine wil fire up regardless of the state of cats
  6. Feb 14, 2025 at 8:46 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    I’m assuming you’re referring to the partial engine assembly part numbers?
    Jeff Lange[QUOTED] likes this.
  7. Feb 14, 2025 at 8:47 PM
    Remedial man
    Tom
    Yes i got around the vacuum pump and plugged the cam end and then with the block off plate? I read that's all you needed to do unless I'm missing something? Everything is same as far as i know?
    t0p_d0g likes this.
  8. Feb 14, 2025 at 8:51 PM
    Remedial man
    Tom
    I will grab the #'s in the morning when its light out. Ty
  9. Feb 14, 2025 at 9:04 PM
    Dirt McGirk
    Dirt McGirk Well-Known Member
    Phoenix, AZ
    19 TRD OR 4X4
    just a heads up it looks like you put your home address in the vehicle description of your profile so it’s showing to everyone.
    t0p_d0g likes this.
  10. Feb 14, 2025 at 9:48 PM
    Jeff Lange
    Calgary, Canada
    Yeah, that’s right.
    Jeff
  11. Feb 15, 2025 at 11:05 AM
    Remedial man
    Tom
    Found the problem on the fuel flooding issue. Bent over pins on the fuel pressure sensor. I want to thank everyone for there input, it is much appreciated!.
  12. Feb 15, 2025 at 3:08 PM
    Vlady
    Issy, WA
    Was there a circuit code?
  13. Feb 15, 2025 at 3:30 PM
    Remedial man
    Tom
    Yes initially for rail pressure. But, looked at everything else and missed the pins inside the connector. It came on the engine and never thought to replace as it looked ok on the outside and the plug clipped right in. Its running like a champ now. Thnx
