TRD exhaust and cold air intake question regarding URD MAF
Discussion in 'Performance and Tuning' started by ToyotaTRD, Apr 1, 2012.
  1. Apr 1, 2012 at 8:28 AM
    ToyotaTRD
    ToyotaTRD [OP] Well-Known Member
    TRD Sport
    I have a 2011 Tacoma 4.0 and I will be adding the TRD exhaust and cold air intake next week. What is the next best thing in regards to the UNichip or the URD MAF. I will not be adding anything else after the exhaust and intake. I also would like to know about warranty issues on the truck itself. I'm not racing or off roading. I just want a little more power and sound and maybe some MPGs. I don't want to void warranty though. The truck has 50 miles on it. I will be taking it easy through the break in preriod. What are your thoughts? I don't want to cut factory wires apart and splice something in. I just want the best device for my application.
  2. Apr 1, 2012 at 8:44 AM
    ToyotaTRD
    TRD Sport
    What is the difference between the old and new style TRD intake?
  3. Apr 1, 2012 at 8:51 AM
    ToyotaTRD
    TRD Sport
    That doesn't really explain why it's better or worse.
  4. Apr 1, 2012 at 8:56 AM
    ToyotaTRD
    TRD Sport
    Wouldn't the URD fix that either way whether it ran lean or rich.
  5. Apr 1, 2012 at 9:10 AM
    ToyotaTRD
    TRD Sport
    Thanks. I just watched the video and it appears the PCV is blocked by a connector between the filter housing and the coupling to the intake.
  6. Apr 4, 2012 at 3:02 PM
    DR Da_da
    DR Da_da Infrequent Member
    Northeast FL
    '06 4x4 V6 TRD Offroad auto access cab
    ToyTec ultimate lift, LR UCAs, TRD gen 1 CAI, TRD cat-back, bull bar, anytime fog lights, lighted 4x4 switch, factory SS step tubes, factory interior lighting package, factory VIP 3200 alarm, FJ TRD center caps, rear diff breather relocate, tint, bug deflector, Weather Tech liners
    You are correct. This is the video you probably watched. From what the mechanics say in the video, it appears that if you cut off the extra length of intake tube you will no longer have the lean issue.
  7. Apr 4, 2012 at 3:05 PM
    NoSoup4You
    NoSoup4You Well-Known Member
    David
    San Clemente
    2008 DCSB DMZ LT 4x4
    Camburg | King | Glassworks | DMZ | Nitro | Banks | Pelfreybilt | Brute Force Fab | Bay Area Metal Fab | Baja Designs | Rigid Industries | STL
    URD MAF Cal only addresses open-loop tuning, or full throttle gas-mashing goodness.
    rich/lean is still an issue at all other throttle positions
  8. Apr 5, 2012 at 4:26 AM
    ToyotaTRD
    TRD Sport
    I installed the exhaust and intake and I am very happy with the results. The intake install required no cutting. In fact the piece that is supposed to be too long has two ridges which in the directions are used for two different applications. For naturally aspirated you only go to the first ridge which doesn't block the PCV and vacuum line. I love how so many people bashed the TRD intake when there is no problem with the product. People are not installing it correctly. Even the picture shows it lined up to this first ridge. Not sure how people are missng this. Everything fit great and I have no error codes. My idle is a little high but that should settle once the ECU learns the new air flow.
  9. Apr 5, 2012 at 4:55 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Yeah, because no one on here knows anything or has any experiences to back up what they are warning people about, they just hate on TRD products blindly. Assumption error. Good luck, enjoy, welcome aboard.
  10. Apr 5, 2012 at 6:37 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    I don't think so, closed loop operation relys more on the O2 sensors for injector settings vs. open loop where it's MAF and fuel tables.
    I could be wrong though, it's happened before, just ask my wife....
  11. Apr 5, 2012 at 2:57 PM
    ToyotaTRD
    TRD Sport
    I don't believe I said every person here is wrong.
