TRD exhaust install question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jareebz, Sep 22, 2010.
  1. Sep 22, 2010 at 11:59 AM
    jareebz
    jareebz [OP] Well-Known Member
    Seaside CA
    Previous: '14 TRD OR DCSB 4x4
    Icon, Camburg, BFG
    Do I need to use any sort of sealant or anything when I put the new exhaust on? I was going to pay 80 bucks for the dealer to put it on, but after reading how easy it is, I think I'm just going to do it myself.
  2. Sep 22, 2010 at 12:10 PM
    05RedTaco
    05RedTaco Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    I wouldn't re-use exhaust gaskets. I bet the TRD exhaust came with new gaskets...
  3. Sep 22, 2010 at 12:10 PM
    jareebz
    Seaside CA
    Icon, Camburg, BFG
    It didn't come with any instructions/gaskets/box or anything. The place I ordered it from wrapped the tip and slapped the fedex label right on the muffler. I'm just trying to find out if I need to stop and pick anything up before I take the stock muffler off.
  4. Sep 22, 2010 at 12:13 PM
    05RedTaco
    Tony
    Scottsdale
    I would definitely get new exhaust gaskets. You can re-use exhaust gaskets, however they might end up leaking. Exhaust leaks will make your TRD exhaust sound like crap. If you spend the money on TRD exhaust, I would highly suggest getting new exhaust gaskets...
  5. Sep 22, 2010 at 12:14 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Get an OEM gasket and some copper RTV. Use a thin layer of Copper RTV on the gasket surfaces, and connect the exhaust.
  6. Sep 22, 2010 at 12:16 PM
    HondaGM
    HondaGM Roll Tide
    James
    South-Pole
    09 DC 4x4 Blown Honda VTEC V8
    trd exhaust,step bars,vent visors,bed lights,tailgate mod
    being yours is a 2010,i would just bolt it on.thats what i did with my 09
  7. Sep 22, 2010 at 12:20 PM
    jbone
    jbone Well-Known Member
    Jack
    CT
    10 DC TRD Sport Pyrite Mica
    Weathertech floor liners, Bed mat, Transmission TSB, disabled seat belt chime, Pioneer Avic- x920bt, TRD catback exhaust, Bilstein 5100s on all 4 (front @ 1.75"), Rear TSB, 17x8 pro comp 7005, 265/70/17 Duratracs, AFE Pro Dry S filter
    I just put my TRD exhaust on myself about a month ago. I didn't get a new gasket and the old one seems to work fine for now, no leaks.
    Just my 2 cents.
  8. Sep 22, 2010 at 12:21 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You should still use a new gasket. The flange on teh exhaust has some texturing on it, and it will be a little different from the stock exhaust to the TRD. Just because it seals up for the time being, doesnt mean leaks wont develop later. Like mentioned above, you spent the extra cash on the TRD exhaust, take a few bucks and get a new gasket.
  9. Sep 22, 2010 at 1:24 PM
    Gene563
    Gene563 Well-Known Member
    Eugene
    Lanoka Harbor, NJ
    08 Double Cab, LB, TRD Sport
    TRD catback exhaust, Undercover hard tonneau, Vent visors, Husky liners, customized seat covers, front license plate bracket, rear suspension TSB, Eibach springs w 5100s@0, & General Grabber AT2 (265.70.17).
    A new gasket sounds like a good idea. I re-used the original one on the truck and haven't had any issues...there were only a few thousand miles on it at the time.
    I installed mine in the driveway; it was a snap.
    I jacked up the passenger side, letting the rear axle hang and did the swap. I left the wrapping on the tip so not to scratch it.
  10. Sep 22, 2010 at 1:28 PM
    MAXTacoma
    MAXTacoma Well-Known Member
    Lexus GS 350
    Your truck is new enough you shouldn't need a new gasket. When I bought my truck back in 06 I put the TRD exhaust on before 1k and it was a simple bolt on. I didn't buy a new gasket or anything. I now have 70k and haven't had any problems. Its def worth saving yourself the $80.00 and doing it yourself.
  11. Sep 22, 2010 at 1:52 PM
    RLDTACO
    RLDTACO Well-Known Member
    Bob
    Houston Tx.
    2010 DCLB PreRunner SR5
    Debadged,Tailgate theft mod,Extra D-rings,OEM bed mat,TRD exhaust, 5100 Billys@ 4 corners set@ 0 with Eibach springs, rear TSB springs.N-Fab tube Steps. TRD FJ SE wheels and Michelin LTX A/T 2's
    I bought mine from the dealer, no instuctions, no new gasket. Just removed the stock one and installed the new, no problems. It took me a couple of hours total. My truck is a 2010 and gasket was fine. Leave the tip wrapped while you install so you don't scratch up.
    Bob
