TRD Exhaust Installation w/ pics
Discussion in '2nd Gen. Tacomas (2005-2015)' started by thebottomline, May 7, 2011.
  1. Oct 4, 2014 at 4:58 PM
    #61
    thebottomline
    thebottomline [OP] Well-Known Member
    Pac NW
    11 sport
    Not required.
  2. Oct 4, 2014 at 8:31 PM
    #62
    hemitruk
    hemitruk Old man , young boi truk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    I always use silicon spray on rubber hangers .Never had problems
  3. Jul 10, 2015 at 7:39 PM
    #63
    Jalapeno
    Jalapeno Ne Desit Virtus
    SE Arizona
    '14 DCSB TRD OR 4x4 - Spruce Mica
    SnugTop, BFG KO2s, TRD Exhaust
    Resurrecting an old thread here, but just did this install today. Easy as can be. The TRD catback exhaust has a nice throaty burble. Thus far I've only taken it around the block and from one freeway exit to another, but I'm pretty happy with this exhaust. I was worried it wouldn't be "loud enough" but it actually surprised me with how loud it is. Definitely not as loud as the Flowmaster 40-series I had on my old F150 but I'm glad that it isn't.
    Thanks for the write-up OP! :cheers:
  4. Jul 10, 2015 at 10:04 PM
    #64
    RKCRUZA
    RKCRUZA Well-Known Member
    Bob
    Placerville, Ca
    2015 TRD Pro in the Garage!
    As the OP stated, dish soap makes life much easier (I used Dawn). Another easy way to get the exhaust in and out (if you have a floor jack and receiver hitch) is to put a drop hitch in the receiver, jack it up as high as it will go without picking up the tires, slide the whole thing out the back...easy in and out and you don't have to drop the spare tire. Took about 20 minutes each on and off on my Pro to do the reverse swap (TRD back to stock). Biggest pita was the rubber hangers as they were still pretty much new (1200 mi on the truck). Great write up by the OP.
    PatrickR likes this.
  5. Jul 12, 2015 at 7:55 AM
    #65
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    What made you want to take off the TRD exhaust?
  6. Jul 12, 2015 at 8:05 AM
    #66
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
    nice write up, I wonder who might be the aftermarket manufacturer for the TRD exhausts,Magnaflow,JBA etc.
  7. Jul 12, 2015 at 12:49 PM
    #67
    hemitruk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    Spray silicon spray lube on hanger and rubber and comes off easy.
    Cmurder likes this.
  8. Jul 13, 2015 at 11:30 PM
    #68
    RKCRUZA
    Bob
    Placerville, Ca
    For some reason the TRD has an annoying drone around 2000 rpm or so. Living in the mountains the truck sees a lot of time in this rpm range. It got worse when I added the shell so I decided to swap it out for a stock set-up (kept the SS Tip so it is a TRD Clone exhaust now). Didn't notice much of any change in actual performance and mileage is about the same also. All that is gone is the noise. From what some folks have posted, the drone isn't really there on the AC models, one guy pulled it off his DC for the same reason as me and his son put it on his AC...no drone. Might be an age thing also, when I was a 20 something I would have loved it...now I'd rather hear the stereo.
  9. Jul 14, 2015 at 5:04 AM
    #69
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Gotcha. I know what sound you're talking about. I like it , lol. But it's not constant for me. I only hear it going up a hill here and there. I could see it being annoying if that's all you hear.
  10. Sep 13, 2015 at 10:15 AM
    #70
    Filiwaiian808
    Filiwaiian808 Member
    Rod
    Honolulu
    2014 double cab tacoma
    question does the trd exhaust come with a new exhaust gasket
  11. Sep 13, 2015 at 10:21 AM
    #71
    Cmurder
    Cmurder 2011 TX TRD Offroad
    B.C.
    Kansas City
    2011 TX TRD Offroad
    nothing cool
    Nope.
  12. Sep 13, 2015 at 10:22 AM
    #72
    Cmurder
    B.C.
    Kansas City
    2011 TX TRD Offroad
    nothing cool
    Tried dish soap also. But silicone spray worked way better. Slipped right off the hangers.
    hemitruk[QUOTED] likes this.
  13. Sep 13, 2015 at 3:17 PM
    #73
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    X2
    But the dealer gave me one, no charge when I got mine. That was 5 years ago...
  14. Apr 17, 2016 at 12:22 PM
    #74
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Weird. Wonder if they gave you the wrong gasket. I had no issues with mine when I did it. Don't remember it being that thick. And why would they say a gasket is rarely used? You'd probably have a lovely sounding leak without it.
    Edit: Part number for gasket matches up to be the correct one. :notsure:
    Maybe just not seated properly?
  15. Apr 29, 2016 at 7:26 PM
    #75
    Mtn Tacoma
    Mtn Tacoma Dude
    Craig
    MI
    13 MGM AC OR
    Just installed the TRD exhaust, thanks for the right up and pictures OP!
    Took the truck for a run around the block (did a cop check first :thumbsup:) and that rumble between 2500-3500 rpm is PERFECT! This thing might get me a ticket, or at least cost me more in gas! :oldglory:
  16. Aug 27, 2016 at 2:26 PM
    #76
    Wags187
    Wags187 Member
    Northern Wisconsin
    09 tacoma trd
    Just installed the trd exhaust. Thanks for the write up on this install!! It was nice to have the torque spec and gasket number!!! Thanks again!!
  17. Aug 27, 2016 at 5:24 PM
    #77
    Fitz235
    Fitz235 Well-Known Member
    Rob
    New Hampshire
    Black '22 DCSB TRD Offroad 4WD
    - TRD T4R Pro Wheels - TRD Lift Kit - TRD Skid Plate - 265/70/17 Toyo Open Country 3's - OEM Bed Lights - OEM Bed mat - Alpharex Tail Lights - TacomaBeast LED Interior Lights - Green Lane Offroad Aluminum Sliders - Place Holder for More Bad Financial Decisions...
    It's funny, I was about to install this thing tomorrow, until I read the rest of this thread (I have it bookmarked, and read the write up portion already), and saw the exhaust gasket. It's getting ordered now. Along with new bolts and springs.
    Even though my truck is 11 years old, the bolts look new (I had my frame swapped last year, I'm assuming they replaced these at that point). But you know how this goes.... If I don't order them, I'll need them.
  18. Sep 3, 2016 at 3:30 PM
    #78
    Fitz235
    Rob
    New Hampshire
    Another satisfied customer...
    I installed mine today. It was about as basic as an install can get. I didn't have any issues with the hangers due to using the dish soap, and maybe this time, having an older truck actually helped me out because the rubber was actually pretty pliable. I did use this pick tool I have from my car phone installation days that definitely made working the hangers a lot easier.
    I did order, (and use) new bolts, springs, and exhaust gasket (about $50 in parts), but don't think in most cases they would even be needed (my truck is 11 years old), as everything still looked usable. Even the gasket. I'm not sure what it's made of, but it's solid. The old one looked just like the new one, except dirtier.
    The sound....
    I have gone back, and forth on getting this exhaust for years, due to fears of it being too loud, or too ricey. Well, I was at the point that I actually needed a new exhaust now, so I took a chance (not ever having heard one in person). I'll say this: You can definitely hear it on start up, and at different rpms. I have yet to stomp on it with this exhaust, but I'm OK with it being louder under heavy acceleration. At about 2000 rpms (about 70 on the highway) I couldn't even hear it. At about 1000 rpms (surface roads) I can hear it. I wouldn't consider it loud, or ricey, but you can hear it. Overall, I like it.
    One thing that was somewhat surprising, was (at least going by feel, as I didn't weigh them) was that the TRD exhaust did not feel any lighter than the stock exhaust (it may have even been slightly heavier), despite the muffler on the stock exhaust being a lot bigger.
  19. Sep 27, 2016 at 6:22 AM
    #79
    kjkroll83
    kjkroll83 Well-Known Member
    Anybody know if it is possible to just buy the trd muffler. Maybe save a few bucks also my exhaust is dumped right behind axle. Was just goin to use stock pipes
  20. Feb 20, 2017 at 10:18 PM
    #80
    Shoot2live4286
    Shoot2live4286 Well-Known Member
    Tim
    2009 v6 trd sport tacoma 4x4
    Cold air intake
    Wow 5 year old thread, lol I'm really considering buying it for my 09 taco, any even just slightly mpg or power gains? On the TRD website it said it should yield at least a little.. anyone?
