TRD EXHAUST QUESTION ????
Discussion in '2nd Gen. Tacomas (2005-2015)' started by blue02r1, Nov 2, 2010.
  1. Nov 2, 2010 at 3:50 PM
    blue02r1
    blue02r1 [OP] tom
    tom
    pennsylvainia
    2011 trd timberland green
    toyota hood protector, AVS vent shades, Toyota Bed Mat, TRD Catback Exhaust , K&N Intake, Tacoma Bedmat, Weathertech Mats, Extang Tuff Toneau ,Foglight Mod.
    picked up my trd exhaust today and didn't realize there is a kit with a new gasket and bolts that i didn't get. My truck only has 700 mi on it ,can i re use the original gasket and bolts? Will it be hard getting those bolts off with my truck being so new?:confused: thanks
  2. Nov 2, 2010 at 4:33 PM
    hopkins
    hopkins Member
    NS Canada
    05 TRD DC LB
    Jack Rabbit Tonneau Cover 18" BFG A/T on KMC Addicts XD Series TRD Cat Back Grillcraft upper with TRD Emblem
    I would say you could try to get away with the bolts but would recommend a new gasket. The gasket with 700mi has been seated between two pieces of metal. Now you are going to disturb it and try to reseal it. It may work for a bit but you may have a leak. Better off to do it once with the gasket.
    *When i installed mine, my truck had 160000kms so I put new bolts, springs and gasket.
  3. Nov 2, 2010 at 4:36 PM
    Hiatt1991
    Hiatt1991 Well-Known Member
    Hiatt
    Flagstaff, AZ/Walnut, CA
    2005 Tacoma Prerunner SR5 TRD offroad
    4" Bodylift 20" Offroad shock spacers Turbo Encabulator
    Do any of you guys know where to get the gasket or what part number it is? I recently installed a Flowmaster exhaust and I used the same washer.
  4. Nov 2, 2010 at 4:51 PM
    05RedTaco
    05RedTaco Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    Any time you change any exhaust part you "should" use a new gasket. Some people WILL say they re-used the same gasket and were fine. Yes that is true. However if it leaks do you want have to fix it? Is it worth it the $15 new gasket costs?
