TRD Exhaust Rattle
Discussion in 'Performance and Tuning' started by dpak, Aug 8, 2010.
  1. Aug 8, 2010 at 7:55 PM
    dpak
    dpak [OP] Well-Known Member
    Richmond, VA
    09 4x4 TRD Offroad DCSB
    Toytec/Eibach coils w/ 5100's set at 0, Toytec 2.0 Aluma Rear Shocks, Toytec Boss Leaf Springs, TRD Catback Exhaust, SCS F-5 Matte Gray Wheels, Elusive Elements Mesh Grill
    Hi,
    I purchased a TRD exhaust about 2 weeks ago and installed it yesterday. I noticed that there is a bit of rattling when driving at low speeds and low RPM's. Just curious, is this normal? Has anyone else experienced this also?
  2. Aug 8, 2010 at 7:57 PM
    Chad
    Chad Well-Known Member
    Chad
    Cary, NC
    09 V6 Access Cab TRD Sport
    Kenwood DMX-7704S Headunit -- Blackvue DR-470 Dashcam -- Pioneer TS-A1685R Speakers in Front -- Suntek CXP 40 Front Tint -- Access Vanish Roll-up Tonneau -- Wet Okole Seat Covers -- Fog Lights on Anytime -- PnL Powered Tailgate Lock -- DTRL "Stealth Mode" -- LED Footwell and Cup Holder Lights -- Map Lights ON with Dome Light -- Shorty Antenna -- AC Line Extension Mod -- Access Cab Rear Headrest Removal
    Most people don't complain of it having to loud of a noise or rasp. Maybe the screws arent tightened enough where the exhaust meets the headers?
  3. Aug 8, 2010 at 7:58 PM
    Kenny650
    Kenny650 Well-Known Member
    Might be your catalytic converter...
  4. Aug 8, 2010 at 8:07 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    x2 that shits annoying
  5. Aug 8, 2010 at 8:13 PM
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    Make sure one of the very thin heat shields are not touching the exhaust.
    They are real easy to bend while installing exhaust parts.
  6. Aug 21, 2010 at 7:54 PM
    Silver DC
    Silver DC Well-Known Member
    Mark
    Nashville
    07 TRD Prerunner SuperCharged
    Supercharged,TRD CAI, TRD exhaust, DTLT Headers, L.E.D. Taillights, Factory BHLM,Wet Okole Seat Covers,Weather Tech Digi-cut Floorliners
    Mine is starting to rattle when i put it in drive and start to pull off. It seems to be coming from inside the muffler. I've had it for a couple of months, I wonder if it's covered under the warranty.
  7. Aug 21, 2010 at 8:09 PM
    judd94
    judd94 Well-Known Member
    Ponchatoula, LA
    17 4Runner TRD Off Road Premium
    Mods in Progress
    you need to crawl under while its running and try to pinpoint it. bang around the catalytic converter, the muffler, and see where it leads you.
  8. Aug 22, 2010 at 8:02 PM
    Silver DC
    Mark
    Nashville
    I didn't have this rattle until I installed this muffler. If I pry against the muffler with a pipe or pry bar the rattle goes away. It sounds like it coming from inside the muffler.
  9. Aug 24, 2010 at 1:45 PM
    dpak
    Richmond, VA
    So the rattling is coming from the muffler. Anyway to fix it?
  10. Aug 24, 2010 at 4:51 PM
    roxspin72
    roxspin72 Enjoying my addiction
    NC
    Speedway Blue, TRD, 4X4,
    Oh Yeah!!!
    I would return it. Sounds like a dud..:D Maybe the Packing or something loose internally within the muffler. 2 weeks should be good to return to vendor, but you might have to return the whole system. If you got through dealer have them check it, and they will replace the muffler.
  11. Aug 24, 2010 at 4:57 PM
    judd94
    Ponchatoula, LA
    Mods in Progress
    DISCLAIMER: i cannot be hold responsible for any thing that can or will go wrong.
    if warranty is not an option, try pin pointing exactly which baffle and where you need pressure applied in the muffler. take a hammer and dent the muffler in at that spot. be very careful because you can loosen another baffle and jack up the whole thing.
  12. Aug 24, 2010 at 4:59 PM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    No noise like that on mine. Have had it since December.
  13. Aug 24, 2010 at 7:11 PM
    08TRDOFFROAD
    08TRDOFFROAD Well-Known Member
    Dan
    21' Tundra Platinum & 08' TRD Offroad DCSB 4x4
    Bilstein 5100's w/front's set at 1.75", TRD exhaust, Colormatched grill, Illuminated 4wd selector switch, BAMF Bolt on Sliders w/kickout.
    No noise like that on mine and I have had it for about two years.
  14. Aug 24, 2010 at 7:21 PM
    jandrews
    '09 FourDubDee TRD OR
    No noise on mine. Had it since June 09. Should not be anything other than a sweet sweet exhaust note.
  15. Aug 24, 2010 at 7:23 PM
    roxspin72
    NC
    Oh Yeah!!!
    It's a Dud... Have it replaced.
  16. Aug 24, 2010 at 7:34 PM
    Rich Beauregard
    Rich Beauregard Well-Known Member
    Rich
    New London, CT
    17 Taco 4x4 SR5 Access Cab White
    Mine has rattle, I checked it out and found the rattle was coming from under the passanger side at the joint where thefront and rear exhaust bolt together. The doughnut gasket is leaking and the bolts with springs are slightly loose. As it now has 80,000 miles on it I know there is no warranty. Had 36K bumper to bumper w/ 70k on drivetrain. Anyway, I stopped in at my local stealership and they want $71.00 for 2 bolts w springs and the doughnut gasket. Yeah Right! No way! I can find 2 bolts and a gasket for a lot less. Oh crap! Just took a look at my front end and found wheel bearing on driver side is shot. Well, Hope you find your rattle, Rich
  17. Sep 28, 2010 at 10:59 PM
    HawTaco
    HawTaco New Member
    Hawaii
    2009 4x4
    TRD CAI, TRD Catback Exhaust,Trd Wheels, 3in lift
    Aloha
    I had the same trouble and it drove me nuts. It seems the source is the collector flange to muffler area. Try tapping the pipe with a rubber mallet you will hear a rattle. It seems that the stock exhaust pipe between the flange and muffler was shorter and more ridged and heaver. I tighten up the first muffler hanger with a smaller rubber hanger that seemed to stop the rattle. you can use a metal hose clamp around the hangers to verify the problem.
  18. Sep 29, 2010 at 7:38 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    No rattles on mine....
  19. Sep 29, 2010 at 10:04 AM
    scott20054
    scott20054 Active Member
    tuned TRD supercharged taco
    TRD Supercharger, IPT High Performance Transmission, DTLT long headers, APR X-1 tuner, Full fiberglass body, E85 injectors, APR 7th injector, Walbro 255 fuel pump, Pulstar Performance Series Spark Plugs, 2.7" pulley, Flexalite Electric Cooling Fan, Cooler Thermostat System, Timing gears, Pro Comp Traction Bars, K&N Cold Air Intake, Airaid PowerAid Throttle Body Spacer, Aero Turbine 2525 with custom piping true duals, Grillcraft MX Series upper and lower grill, Redline Tuning Hood QuickLIFT ELITE, 20% tint front, 5% tint back, tinted headlights, tail lights, fog lights, and mirrors, Debadged, ... So YES this truck is "STOCK" ;D
    hahahahahaha ok i'm sorry but i cant stop watching your sig video lol that is great lol
  20. Sep 29, 2010 at 4:45 PM
    dpak
    Richmond, VA
    I'll give that a try. Thanks!
