TRD exhaust/Resonator question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SPORT55, Dec 7, 2011.
  1. Dec 7, 2011 at 2:45 PM
    SPORT55
    SPORT55 [OP] Well-Known Member
    Clinton, N.Y.
    2011 Double Cab TRD Sport Black
    HI gotta question, does anyone know the piping size for The TRD exhaust that's on my 2011 TRD sport ? I am also thinking about adding a resonator to the exhaust to dampen the noise in the cabin and I was told that on the 2010's and up that adding a Resonator will throw a check engine light due to the change in catlic converters they did in 2010..any one have any knowledge on this ? Also can anyone recommend a good Resonator to use.... Thanks for your help...
  2. Dec 7, 2011 at 2:46 PM
    Aw9d
    Aw9d That one guy
    If you want to go quiet then why not just sell the TRD and trade someone for a stock exhaust?
  3. Dec 7, 2011 at 2:57 PM
    SPORT55
    Clinton, N.Y.
    I actually have the stock exhaust as well, but love the sound outside the truck and look of the TRD...the cabin is not bad at all but would like to lower it a bit for my wife...it is a bit noisy between 1500-3000 rpm's...
  4. Dec 7, 2011 at 3:00 PM
    Aw9d
    Aw9d That one guy
    Lowering it inside will make it quiet outside as well.. IDK man, I'd tell your wife to just deal with it and then turn up the radio to drown out her bitching after you tell her that. :)
    I have the TRD and its very quiet compared to others like choke master.
  5. Dec 7, 2011 at 3:07 PM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    I cant imagine that a resonator down stream of the cats will cause a CEL. There is just no reason for that to occur. Adding a resonator is going to change the sound that you enjoy listening to. It doesnt really make sense to me. I'd almost rather see you add some sound deadening material, although that will probably wind up being more costly.
    I've consistently heard good reviews on aero turbine. They make the AR resonator in sizes 2, 2.5 and 3 and are named accordingly (AR20, AR25, etc)
  6. Dec 7, 2011 at 3:22 PM
    SPORT55
    Clinton, N.Y.
    HA ha ... Don't know if that will go over well... My wife just doesn't get performance upgrades to a vehicle. Should of seen her when I had my shelby, LOL....:)
  7. Dec 7, 2011 at 3:22 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Adding a resonator wont hurt anything, other than change the sound, and make it more quiet. The pipe size is 2.5"
  8. Dec 7, 2011 at 3:24 PM
    SPORT55
    Clinton, N.Y.
    Thanks for your imput , I will look into the AR... I hear good things about the flowmaster resonator as well. .. but if it lowers me to much back to stock then I just don't know if I'll do it....
  9. Dec 7, 2011 at 3:26 PM
    SPORT55
    Clinton, N.Y.
    LOL....some things never die... I knew you would be joining this thread...go easy on me this time killer....LOL
  10. Dec 7, 2011 at 3:27 PM
    SPORT55
    Clinton, N.Y.
    DO you feel it is going to make it to much like stock doing this ? The sound that Is...
  11. Dec 7, 2011 at 3:30 PM
    HIYota
    HIYota Well-Known Member
    Angel
    Las Vegas, NV originally Kauai, HI
    09 Silver 6 spd TRD Sport DCSB 4x4
    Check my build thread...too much to list.
    What about using dynamat for the inside?
  12. Dec 7, 2011 at 3:42 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I havent tried a resonator on the TRD exhaust, but I think it would make it close to stock.
  13. Dec 7, 2011 at 3:56 PM
    08speedway
    08speedway Member
    manitoba, canada
    08 dc sport
    trd cai
    I installed a huge cherrybomb glasspack just after the connection to the y pipe on my truck and the sound is perfect, you know its there when accelerating but barely hear it at all on the highway. Has almost no drone at all, and no check engine light. I have a dynomax exhaust and it droned very bad without the glasspack, I imagine the TRD exhaust will be the same. And as a bonus the glasspacks are cheap and available in different lengths, a shorter one will be louder.
  14. Dec 7, 2011 at 3:59 PM
    Aw9d
    Aw9d That one guy
    I took the resonator off my exhaust on my Type-R and it made a huge difference in how much sound came out of it. I'd assume you'd be close to stock sounding unless you were really stepping on the gas.
    I'm so thankful that I never have to have the conversation about buying parts with my wife. Every time I say I want to buy something for my truck I hear 'and what are you getting me for my car then?".. gotta love female gear-heads!
  15. Dec 7, 2011 at 4:14 PM
    SPORT55
    Clinton, N.Y.
    Seems like more of a pain then anything to do this, plus I have read people doing this with not good results...but yes it has crossed my mind.
  16. Dec 7, 2011 at 4:16 PM
    SPORT55
    Clinton, N.Y.
    I've talked to the guy at flow master and the one he advised me on was the 12 inch one and said it will not be a drastic change but it would definately help with unwanted cabin noise...
  17. Dec 7, 2011 at 9:11 PM
    08speedway
    08speedway Member
    manitoba, canada
    08 dc sport
    trd cai
    mine still sounds good outside, but almost no drone, i was very impressed. i am pretty sure my glasspack is even longer than that, it is huge!!
  18. Dec 8, 2011 at 7:06 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Only problem with the glasspack is that if it is truely a fiber-glasspack, then the material breaks down over a few years and will need to be replaced. If it is a stainless steel glasspack (like Magnaflow) then you should be good.
    If the OP is going to go this route, might want to use a Magnaflow round, or go with a true resonator.
  19. Dec 9, 2011 at 2:29 AM
    SPORT55
    Clinton, N.Y.
    PRobably not going to go the resonator route anymore, kinda talked my self out of it....but just curious what is a magnaflow round?
  20. Dec 9, 2011 at 7:11 AM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Just a Magnaflow muffler that is in a round canister instead of an oval one. I was just thinking of something small that would replace a glasspack.
