TRD Exhaust Worth it?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Norsk, Mar 7, 2020.
  1. Mar 8, 2020 at 5:49 AM
    #41
    jeffthedude
    jeffthedude Well-Known Member
    Orlando, FL
    2017 Taco TRD O/R 4x4
    i bought mine when TRD had the anniversary sale going on, even then for hundreds of dollars cheaper it was "meh", it doesn't drone which is good, but the sound increase is barely there, it does look way better than the stock exhaust though
  2. Mar 8, 2020 at 5:55 AM
    #42
    RuckusReef
    RuckusReef Well-Known Member
    Antarctica
    2017 TRD OR MT
    AT or MT?
  3. Mar 8, 2020 at 5:57 AM
    #43
    Kevin Jones
    Kevin Jones Well-Known Member
    Kevin
    Va
    1996 Tacoma - 2018 Tacoma
    It took me about 40 minutes doing it by myself without a lift. Would be quite a bit quicker with a helper as it's a LOT heavier than the std OEM exhaust.
    Also, tape padding around the tip to keep from scaring it up during installation.
    RuckusReef likes this.
  4. Mar 8, 2020 at 6:02 AM
    #44
    Kevin Jones
    Kevin
    Va
    If looking for a loud exhaust best to go with another brand. The TRD Cat-Back is more about about a deep-throaty high-performance sound which it provides.
  5. Mar 8, 2020 at 6:06 AM
    #45
    jeffthedude
    Orlando, FL
    Automatic
  6. Mar 8, 2020 at 6:07 AM
    #46
    slowlane
    slowlane Well-Known Member
    AZ
    16 double cab MGM
    If doing this in the driveway. Also helps to lower or remove the spare.
    Agreed though, super easy install. 3 or 4 hangers and 2 bolts. Should take 30 - 1 hour if you're doing it by yourself, and that's taking your time.
  7. Mar 8, 2020 at 6:13 AM
    #47
    jeffthedude
    Orlando, FL
    I really wasn't going for loud, the engine doesn't sound good period. I have an 2016 Shelby GT350 that sounds amazing and will wake the dead, i just wanted something more aggressive than stock, if it was just a tad bit louder i think it would be perfect.
  8. Mar 8, 2020 at 6:18 AM
    #48
    Kevin Jones
    Kevin
    Va
    I considered removing/lowering the spare, however with the time it would take and weight of the spare, figured it would be about the same as carefully wrapping the pipe around the axle.
    The trick is to wrap the pipe around the axle angling it from the driver's side of the truck as opposed to straight back.
  9. Mar 8, 2020 at 11:15 AM
    #49
    CaptainTikihut
    CaptainTikihut Well-Known Member
    NorCal
    2017 Taco Supreme w Stuff
    Mine came with the truck, low drone sound, a bit throaty and I'm guessing 0.1% gain in HP and torque:fingerscrossed:. Actual performance numbers not published by Toyota but there was a thread about an independent dyno test.
    Kolter45 and Blackbeard83 like this.
  10. Mar 8, 2020 at 12:59 PM
    #50
    Lucifer1
    Lucifer1 Well-Known Member
    Lucifer
    Plano TX
    2023 Silver TRD Sport Access cab V6 automatic
    Toyota Bed divider
    @Norsk I am thinking, wouldn't be more polite to just say "We really don't want to do it" than insult your intelligence !
  11. Mar 8, 2020 at 1:13 PM
    #51
    Lucifer1
    Lucifer
    Plano TX
    Toyota Bed divider
  12. Mar 8, 2020 at 1:48 PM
    #52
    Kevin Jones
    Kevin
    Va
    :crazy:
    Lucifer1[QUOTED] likes this.
