trd factory wheel and pro comp 7089 wheel or other ?
Discussion in 'Wheels & Tires' started by klee07taco, Oct 18, 2010.
  1. Oct 18, 2010 at 9:43 AM
    klee07taco
    klee07taco [OP] Well-Known Member
    calfornia
    07 tacoma
    stock 07 tacoma db 4x4
    hello eveone , stock trd factory wheel 265-75-16 and pro comp 7089 wheel 265 75 16
    how many lost mpg
    sorry make your confuse my question sentence and im still think stay stock factory or other brand name different wheel more wide 8" ?
  2. Oct 18, 2010 at 10:37 AM
    LEX
    LEX --- --- --- - ----
    Houston, Texas
    100 Series LC
    huh?
  3. Oct 18, 2010 at 10:44 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    :eek::confused:
  4. Oct 18, 2010 at 10:48 AM
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    Dude how do you expect us to answer your question when you can't take the five seconds to write out a decent sentence.
    You won't notice a change in MPGs. The only difference will be the weight of the wheels between your stock and the 7089s. That is assuming you will be keeping your stock tires.
  5. Oct 18, 2010 at 3:52 PM
    LEX
    Houston, Texas
    100 Series LC
    Sorry. Even after your edit, I'm still not quite understanding you.
    Are you asking if you'll lose MPG's if you go with a wider aftermarket wheel?
    If so, probably not since you're using the same size tire.
    If you with a steel wheel, you might since they're heavier, but not enough to be concerned about.
  6. Oct 18, 2010 at 4:09 PM
    klee07taco
    calfornia
    07 tacoma
    i have bfg ko tires size 265 75 16 with stock trd factory and i still like more wider aftermarket it same MPG or little lose MPG ?
  7. Oct 18, 2010 at 6:25 PM
    IB Slingin
    IB Slingin Well-Known Member
  8. Oct 18, 2010 at 6:28 PM
    stmpjmpr
    stmpjmpr Well-Known Member
    Jimmy
    So Orange County, Ca
    2014 Tacoma Sport MGM 4X4
    Cant u guys see what it is?..Its that Oakland ebonics language.
