TRD (fake) beadlock rims vs stock offroad rims
Discussion in 'Wheels & Tires' started by Mavrick, Mar 25, 2017.
  1. Mar 25, 2017 at 7:31 AM
    Mavrick
    Mavrick [OP] Well-Known Member
    2015 DCSBOR
    I'm pretty much sold on getting a set of the bronze fake bead lock rims but before I pull the plug I wanted to double check the specs on these rims when compared to my 2015 stock off road rims.
    Can anyone tell me, (when compared to the stock off road 16" rims), if the TRD bead lock rims are heavier, wider, and will they stick out farther than my stock rims?
  2. Mar 25, 2017 at 7:33 AM
    bajatacoguy
    bajatacoguy Well-Known Member
    Johnny
    RI to NH
    Blk Taco
    OEM: Bed Mat Roof Rack Tri-Fold Tonneau Cover Door Sill Protectors KO2's Dobinson GTS Suspension TRD Beadlocks Timbren Bump Stops SPC UCA Rear SuperSpring SSO Slimline Winch Bumper SmittyBilt x20 Mobtown Sliders Mobtown Front Skid Avid Basket Bed Rack DECKED Draw Organizer Total Chaos Bed Stiffners Relentless Fab Bed Corner Tie Downs CBI Ditch Light Brackets ARB Dual Compressor Instant Air Tank Smittybilt RTT Road Shower II Indel-B Fridge/Freezer w/ Slide Ironman 4x4 Insulated Fridge Case Redline Tuning Hood QuickLIFT Yo_Hec - Center Console Molle Little Johnny III CB Radio KB Voodoo Flashlight Kit Switch Pro 8100 BlueSea Fuse Pelfreybilt Fuse Panel Mount Gecko - LED Bed Lights Gecko - LED Hood Lights Raptor Grill Lights Cali Raised - Bed Flag Pole Holder Center Console Tray & Organizer Weather Tech Floor Mats Weather Tech Hood Deflector TRAILER BUILD HAPPENING! Plate: Negan
    You will need new lug nuts also!
  3. Mar 27, 2017 at 12:23 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Your stock rim should be a 16x7/ET +30/5.18" backspace/? lbs.
    The beadlock is a 16x7.5/ET +10/4.64" backspace/25 lbs. They protrude outward 1".
  4. Mar 28, 2017 at 8:41 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    It should put the wheels near flush with the fender, which is a solid look without protruding. I believe both are 7.5" wide, and the bead lock is .5lb heavier than the standard OR, 23.5lbs vs 23lbs.
  5. Mar 30, 2017 at 7:05 AM
    Mavrick
    2015 DCSBOR
    Thats the info I was looking for, thank you. I know these are older rims now but I'm going for it, they have that unique look without looking stupid.
  6. Apr 8, 2017 at 9:46 AM
    Mavrick
    2015 DCSBOR
    I have one more question, do the rings need to be removed to mount a tire or just leave them on?
  7. Apr 8, 2017 at 9:48 AM
    Northern Taco
    Northern Taco Well-Known Member
    2022 Tacoma trd off road premium 2023 tundra trd off road
    They are fake, they don't come off.
  8. Apr 8, 2017 at 9:50 AM
    Mavrick
    2015 DCSBOR
    Yes they are fake but they come off, its just a trim ring that screws on. I need to know it that will interfere with mounting a tire or not? I don't want the tire guy to jack my rims.
  9. Apr 8, 2017 at 9:51 AM
    Jeffas7
    Jeffas7 Monta what na???
    Missoula
    12quad6spd
    Take them off. Only takes a few min and saves them from getting unnecessary scratched from the tire mounting
  10. Apr 8, 2017 at 9:52 AM
    Jeffas7
    Missoula
    12quad6spd
    From experience, they will jack up your rim :censored:
  11. Apr 8, 2017 at 10:00 AM
    Northern Taco
    I didn't know they came off. I'd take them off for sure, then if they scratched them it would be hidden by the ring at least.
  12. Apr 8, 2017 at 8:46 PM
    jbaborr
    jbaborr Member
    2017 trd OR
    I have these. You can mount them with the beadlocks on if you or the guy mounting them is careful. That's what I did and no scratches.... otherwise just take them off... it's easy
  13. Apr 10, 2017 at 8:28 AM
    Mavrick
    2015 DCSBOR
    Thanks everyone, I'm taking them off to be safe.
  14. Apr 10, 2017 at 8:31 AM
    CaptainAwesome
    CaptainAwesome Well-Known Member
    Calgary, Alberta
    Will the stock TRD offroad tires fit on the fake beadlock wheels?
  15. Apr 10, 2017 at 8:33 AM
    Mavrick
    2015 DCSBOR
    Yes they will.
  16. Jun 23, 2017 at 6:38 PM
    Sarhog
    Sarhog Well-Known Member
    Greer, SC
    2017 Tacoma Sport Rally
    Anyone have a pic of the wheel with a tire mounted and the fake beadlock removed?
