Trd fj bronze wheels on a tacoma
Discussion in 'Wheels & Tires' started by yotatoy, Jun 4, 2010.
  1. Jun 4, 2010 at 6:06 AM
    yotatoy
    yotatoy [OP] Well-Known Member
    il
    2010 Toyota TRD 4x4 4D V6
    Avid side steps Nokia Yellow fog lights t-rex eyelids trd sport hood front windows tint
    i was just checking to see if anyone has install the FJ 16in trd bronze beadlock wheels on a tacoma. the wheel info on the tacoma is 16x7 offset 30. the fj wheel is 16x7.5 offset 10. my truck is not lifted. i wanted to use my stock tires because i just bought them 3mth ago. anyone know about if they will stick out (how far), and if they will hit anything?
    thanks for anyhelp
  2. Jun 4, 2010 at 9:02 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    A 7.5" rim with +10mm offset will be around 4.75" backspacing, so they will stick out about 3/4 of an inch over stock.
  3. Jun 5, 2010 at 6:13 PM
    nelztaco
    nelztaco Well-Known Member
    Neil
    Levittown, PA
    09 TRD Sport DCLB 4x4 SW
    UNDERCOVER, EIBACH COILS, TSB 4 LEAFS, TRD WHEELS, 255/85R16 KM2
    I just bought those rims in black if it's the ones I'm thinki9ng about. 2010 trd trail teams? I'll let you know once I get tires. Gotta save for the tires.
  4. Jun 6, 2010 at 8:09 PM
    yotatoy
    il
    yea let me know how they fit also, what are the offset
  5. Sep 30, 2010 at 5:26 PM
    Gabex35
    Gabex35 Well-Known Member
    Gabe
    San Diego
    2020 Tundra Limited 4x4 Crewmax
    x2
  6. Sep 30, 2010 at 5:53 PM
    bivey
    bivey Well-Known Member
    Would like to see these on a tacoma.
  7. Oct 1, 2010 at 5:54 AM
    nelztaco
    Neil
    Levittown, PA
    This is from another thread look up tacoma tx pro.
  8. Oct 1, 2010 at 9:53 AM
    n0rth
    n0rth Well-Known Member
    J.W.
    New Mexico
    2019 Tundra Platinum
    2009 Tacoma Access Cab SR5, 4wd, 2.7L URD S/C, 4:88's ARB lockers, 36x9.8r16 Radial TSL
    Here are some pics of the wheels you are asking about on my tacoma. They will fit your truck with the stock tires Toyota recommends a 265 with this rim can't remember if it is a 70 or 75 series (I believe it is a 75 series) but am not positive. I painted the rings black on mine so they would look a little different. They are a really sharp looking wheel hope this helps.
  9. Oct 1, 2010 at 9:58 AM
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
  10. Oct 1, 2010 at 10:03 AM
    nelztaco
    Neil
    Levittown, PA
    Wow that looks great and you have the tire size I'm going for! Do you like them? The tires don't look skinny at all to me!
  11. Oct 1, 2010 at 10:12 AM
    n0rth
    J.W.
    New Mexico
    Thanks, They are a perfect fit for a 3" lift and function even better than they look.
  12. Oct 1, 2010 at 10:13 AM
    HBMurphy
    Paul
    So California Coast
    None
    I am running 285/75/16s - they look a lot skinnier than they do on my countersteers.
  13. Oct 1, 2010 at 10:22 AM
    jblaze805
    jblaze805 Well-Known Member
    Ventura/Fresno, CA
    04 trd pre-runner
    2.5" king coilovers, caburg uca, magnaflow exhaust, aem intake
    man those rims look sweet
  14. Oct 1, 2010 at 11:17 AM
    HBMurphy
    Paul
    So California Coast
    None
    I just wish they were wider!
  15. Oct 2, 2010 at 5:57 AM
    yotatoy
    il
    do you by chance have a part number and a cost of what you paid?
    and those pics look great
  16. Oct 2, 2010 at 6:07 AM
    nelztaco
    Neil
    Levittown, PA
    Isn't the difference only a half of an inch? 16x7.5 vs. 16x8? I think the backspacing is what's off. Your konigs probably stuck out further. Correct me if I'm wrong. I personally feel that they look perfect. Any rubbing with 285's? How much lift?
  17. Oct 2, 2010 at 7:19 AM
    HBMurphy
    Paul
    So California Coast
    None
    No rubbing here but it's a long story... I have bent the pinch weld and pushed the wheel well back and cut the cab mount. Backspacing on both are 4.5.
    2.5-3 inch lift. Need new springs in the back.
  18. Feb 1, 2011 at 11:21 AM
    BryWi
    BryWi Psalm 109:8
    Earth
    2011 TRD off-road DC SB w/JBL
    5100s, black valance
    :rolleyes:
    I know this is an old thread, but I had to respond.
    They will probably have to take care of the 2nd amendment "problem" before any of that property redistribution stuff gets done ;)
    By the way, that's a great avatar. Satan...and his wife! :D
  19. Nov 4, 2015 at 8:34 PM
    MyBlueTacoParty
    MyBlueTacoParty Member
    2015 BRM Tacoma TRD Offroad 6spd 4x4
    Here is my blue and bronze set up
  20. Nov 22, 2015 at 3:34 PM
    AKHawkeye
    AKHawkeye Well-Known Member
    Anchorage, AK
    15 AC Sport 4x4 6 Spd
    Locked as stock
    Anyone know if 265/75/16 will work with these on stock suspension? I'm going to order the wheels, lugs, and maybe a new set of TPMS and want to pair all of this with a set of DuraTracs. Just want to check clearances first.
