TRD FJ Wheels and 1.25" Spacer
Discussion in 'Wheels & Tires' started by Blk04SR, Jan 21, 2013.
  1. Jan 21, 2013 at 9:16 PM
    Blk04SR
    Blk04SR [OP] Well-Known Member
    SoCal
    '20 TRD Offroad 4x4 DCSB 6 Speed Manual
    AccuTune Fox 2.5's, Camburg Billets A-Arms, Enkei+Toyo AT3's, Deaver Overland Stage 2, Demello Front Bumper, Go Fast Camper
    So I am up in the air if I want to run my Spidertrax spacers with the FJ wheel. I have to do my brakes so I have to take them off and am thinking of running the 1" Bora Spacer...My fear with the 1.25" is the stress on the wheel bearing and but I guess people do run a 1.25" spacer with a set of wheels that have a 4.5"BS. What are your guys thoughts?
  2. Jan 21, 2013 at 9:54 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    As long as you're using hubcentric adapters, you will be OK. A wider stance definitely looks better.
  3. Jan 22, 2013 at 7:42 AM
    Blk04SR
    SoCal
    Yeah I think I will stick with the Spidertrax so I dont have to buy another pair of spacers for the front...they are hubcentric.
  4. Jan 22, 2013 at 9:00 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    TW member Zombie Runner ran 1.25" spacers on wheels that already had 4.5" BS (as the TRD fj's do), and he couldn't even turn out of his driveway. Wheels were pushed too far outside the fenders.
  5. Jan 22, 2013 at 9:03 AM
    hard2kill
    hard2kill Well-Known Member
    Rhinebeck NY
    06 4door trd sport white 6spd
    ...315's,2in bora wheel spacers,safari snorkel,wheel spacers,bruteforcefab rear bumper and sliders,afe filter,hi-lift jack,5100 with OME 886 & 1/2in spacer,allpro expo's,icon 10in rear shox,flip kit,ss brake lines,cobra cb,fog light mod,yellow fogs,weathertech mats,fullsize spare tire and extra sport rim,tinted windows,aeroturbine 2525 muffler dumped over axle...rear diff breather mod...removed factory spare...removed 2nd air filter...THULE roof rack and fairing....bud builts front to back,allpoo front bumper,BAMF lca skids,overland Offroad roof and bed racks,
    i run 2in bora spacers i used to have spidertrax both are great and i have lots of very hard miles with no problems this is with tall skinnys on stock trd sport 17's
  6. Jan 22, 2013 at 9:29 AM
    Jbcm12
    Jbcm12 Well-Known Member
    Joshua
    Bay Area
    The FJ TRD rims are wide enough on a Tacoma.
  7. Jan 22, 2013 at 4:23 PM
    Blk04SR
    SoCal
    If I remember correctly the TRD FJ wheel are a 4.75" BS with a +15mm offset...they are wider by they are a 16x7.5" wheel...I dont see a problem if I am running a hubcentric spacer. Just trying to save a $100 and not order the 1" Bora spacers. I figure they will stick out more than now but maybe by 1/2" so it wouldn't be that bad.
  8. Jan 22, 2013 at 4:37 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    15mm - (1.25")x25.4mm = -17mm, so the Spidertrax spacer together with the FJ wheel would be equivalent to running a wheel with -17mm offset. With your front wheels steered at full lock, what clearances are you getting between the tire and the fender liner / mudflap? Now visualize the same tire pushed out on its hub by 1.25".
  9. Jan 22, 2013 at 4:50 PM
    Blk04SR
    SoCal
    Opps I forgot the mention about 1/2" more than it does now with a stock TRD offroad wheel + spidertrax...my bad
  10. Jan 25, 2013 at 9:41 AM
    nelztaco
    nelztaco Well-Known Member
    Neil
    Levittown, PA
    09 TRD Sport DCLB 4x4 SW
    UNDERCOVER, EIBACH COILS, TSB 4 LEAFS, TRD WHEELS, 255/85R16 KM2
    This! Going from TRD Sport backspacing to the TRD Faux Beadlock backspacing pushed the wheels outwards a good bit. Not sure why you would need spacers. But I guess different lift and tires, maybe.
  11. Jan 26, 2013 at 8:59 AM
    Blk04SR
    SoCal
    I have 1.25" spacers in the front already with the stock TRD OR wheels and want to keep it around the same just debating if I want to buy another pair of spacers to keep the same stance by ordering 1" Bora spacers.
