Trd flash and magnuson supercharger
Discussion in 'Performance and Tuning' started by Nachotaco, Jul 28, 2017.
  1. Jul 28, 2017 at 5:13 PM
    Nachotaco
    Nachotaco [OP] Well-Known Member
    Jonathan
    Georgia
    So first off setup I'm going to run in near future
    2012 tacoma v6
    Manual trans
    Afe stage 2 cai
    Magnuson sc
    Upgraded fuel kit urd
    2.85 pulley
    Pros and cons trd flash vs uconn
    Can I even run a Trd flash safely? When I called Magnuson tech said no. The Trd flash is not compatable?
  2. Jul 28, 2017 at 5:22 PM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    The trd flash is compatible with the magnuson supercharger. It is what I am running. If you plan to go ucon then do not get the trd flash, I've heard it doesn't always play nice with the ucon. If you plan on just doing the supercharger and maybe a 2.85 pulley I would get the trd flash. If you plan on getting a smaller pulley or a 7th injector or other performance mods and want the most out of your truck the ucon might be best for you. Also if you have not already I would plan on replacing your clutch with something more heavy duty than stock. Most people agree the stock clutch is not up for the job with the supercharger.
    BassAckwards and Nachotaco[OP] like this.
  3. Jul 28, 2017 at 5:40 PM
    Nachotaco
    Jonathan
    Georgia
    Hmmm I've got 27k on my 2012. I've read about needing a clutch upgrade but was hoping I could wear out my old clutch before doing an upgrade. Seem like ucon is the way to go for my build. Anyone have experience installing the ucon?
  4. Jul 28, 2017 at 10:24 PM
    FinnJ
    FinnJ Well-Known Member
    Finland
    2007 FJ Cruiser 6M/T
    TRD SC, UCON, CNG conversion, RC 6" (lifted 4"/3" air suspension) w/FOX 2.5, 315/70R17 Duratracs, RECARO seats, etc.
    Check your ECU calibration first, if it's flashed once, TRD flash is not possible.
    Installing the UCON itself is just plug&play, but the cam gears need some tools. Just the same prosedure than this: http://www.aprpower.com/pdfs/Cam Gear Installation.pdf
    Plus the thermostat, but it's easy thing.
    Your clutch is fine. Change it if you burn it.
  5. Mar 23, 2018 at 6:17 AM
    My650sux
    My650sux Member
    @FinnJ
    I have the .pdf pulled up and I see that there is a table near the end listing year model, transmission exc. with "Target Calibration ID" and "Supercharger Calibration ID" I was thinking that the "Target Calibration ID" would be a number on the outside of the ECU. (Trying to verify if my ECU could be re-flashed) These numbers look nothing like what I am seeing on multiple ECU pictures on the internet. I'm guessing that this means I just need to schedule an appointment with Toyota and they will be able to see both of these codes on the special computer they have? As in pay them $100 to hook it up and let them tell me if it's a compatible ECU? I currently have a N/A truck but would like to purchase 455cc injectors and re-flash for the supercharger. I have found the "orange TRD Denso Injectors" for as low as $122.00ea. I emailed five-0 motorsports yesterday and they have two options 380cc Denso injectors or 450cc Bosh injectors $80ea with harness adapters. What injectors did you buy? Looks like the options are:
    • URD 61lb or 80lb (both would require UCON ECU) = $1860
    • FIVE-o motorsport 380cc or 450cc = $480
    • Denso/Toyota orange injectors =$732
    link to .pdf:
    http://www.trdsparks.com/install/PTR29-35120inst.pdf
    My truck:
    2006 Toyota Tacoma double cab 4x4 Base A/T (with leaky driver side axle "unfixable")
    Please give me your thoughts as well as anyone else that wants to give their $00.02
    Thanks,
    Joe
  6. Mar 23, 2018 at 6:24 AM
    cory02taco
    cory02taco Well-Known Member
    Cory
    Maine
    2013 trd super sport
    I'd budget in a urd stage 2 clutch as well. I wish I had. Mine slips from time to time with the trd supercharger with no mods other than the Toyota reflash.
  7. Mar 23, 2018 at 8:15 AM
    SUMOTNK
    SUMOTNK Pavement Pounder / Mall Crawler
    Eddie
    NorCal/South Bay Area
    Looks like a Gen2.5 TRD Sport, but really an '08 TRD OffRoad
    TRD Supercharged / OTT Tuned
    The #s outside of the ECU is just the Toyota part # of the actual ECU (hardware/computer brain). The ecu calibration file (target calibration ID) is the software on the ecu/computer. And yes, the special computer at the dealership should be able to tell you what calibration ID file is currently being used by your ECU.
  8. Mar 23, 2018 at 11:55 AM
    My650sux
    My650sux Member
    @SUMOTNK,
    Thank you for the reply, I didn’t mean to thread jack.
  9. Mar 23, 2018 at 2:03 PM
    FinnJ
    Finland
    Supercharger injectors and flash without the supercharger. :confused: Why?
  10. Mar 23, 2018 at 2:07 PM
    FinnJ
    Finland
    Download Techstream software for free and buy $15 Mini-VCI cable and you have access to your ECU with your laptop. I can highly recommend, you’ll see a lot of useful data with it.
  11. Mar 23, 2018 at 9:10 PM
    jojotoo
    jojotoo Well-Known Member
    Brandon
    Socal
    2015 DCLB
    $122 each for the injectors ? I’m pretty sure you can get them cheaper. @loginfailed
  12. Mar 24, 2018 at 5:31 AM
    My650sux
    My650sux Member
    I’m planning ahead, that’s why..
    If you try to buy them at the stealership they are $170ea
  13. Mar 24, 2018 at 3:57 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I wish mine were that cheap. Mine were ~$216 each ....
  14. Mar 26, 2018 at 3:32 AM
    My650sux
    My650sux Member
    Was this for the orange denso injector or larger aftermarket injector?
  15. Mar 26, 2018 at 4:37 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Another aftermarket brand of a higher flow rate.
