TRD headers, if you have them, would you do it again, or waste of $?
Discussion in '1st Gen. Tacomas (1995-2004)' started by The Driver, Dec 6, 2016.
  1. Dec 6, 2016 at 7:41 PM
    The Driver
    The Driver [OP] Trail Runner/Barefoot Beach Runner/Snow Skier
    Raph
    Lakewood (Green Mountain), CO.
    '02 Extra cab 4X4 TRD SR5 3.4
    Aftermarket tranny cooler, 5100 Series Bilsteins, ToyTec Bilstein front coilovers, SPC UCA's, Alcan leafs, Class 3 Hitch, Tundra Front Brakes,
    Pondering installing the TRD headers, and a Magnaflow 2.5 catback.
  2. Dec 6, 2016 at 8:47 PM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
    I enjoy mine, but I'm SC'd so it provided a benefit. Not sure how much gains can be had w/out a SC
  3. Dec 6, 2016 at 10:16 PM
    brs127s
    brs127s Well-Known Member
    O'Fallon, MO
    04 D-Cab 4x4 Limited TRD
    TRD Headers, Aero Turbine AT2525XL Deckplate Mod, TRD tranny cooler, King Coilovers, LR UCAs, Alcan 5 Leaf springs and Bilstein 5100s, Shrockworks front bumper, CBI rear bumper.
    No doubt in my mind. My Dcab is N/A, but I can still tell a difference towing.
  4. Dec 7, 2016 at 3:53 AM
    Indy
    Indy Master of all I survey.
    Most bolt on parts are fairly useless,is just the way it is. a modern engine is built to maximize as much of what it reliably can produce while meeting govt mandates. if slapping on a couple simple bolt ons could net real results, it would roll off the line with them already attached so the numbers could be in the advertising.
    Every engine is different, so there might be an extra hp or 2 still there but you'll spend some money finding it and it's only going to show up for a short time on the charts if you have a dyno.
    Fi makes a real difference,some parts can help it make more of a difference. but short of going that route at best you make the truck louder.
    I've added just about every part known to man to my vehicles and so far they all fall into the "sonething to do with my weekend" category far more than the "actual difference" category.
    That's excluding things like regearing that aren't really in the bolt on type and produce noticeable results.
    skeezix likes this.
  5. Dec 7, 2016 at 7:33 AM
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    There are tons of bolt-ons that add performance. And comparing the cost of cast manifolds to bent/welded SS headers is just silly. That said, you would need to upgrade the entire system to see any real gains with most. With headers alone you won't change much but if you also open up the intake or supercharge and increase the fuel you will certainly make more power.
    Expect to spend big money if you want results.
    vasinvictor and skeezix like this.
  6. Dec 7, 2016 at 8:19 AM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    Depends on if you think $700 and a horrible install is worth 10-14hp. ive seen superchargers go used under $2000. thats better bang for buck imo.
    vasinvictor likes this.
  7. Dec 7, 2016 at 8:22 AM
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    hx35 turbo, AEM F/IC, Transgo, custom converter, CalTracs, Elocker, 2-4" drop, 4x4 conversion (2023) on a new purple powdercoated fram, 255/55r18 street, 255/60r16 M&H Racemasters, 7.6 at 91
    So much this. Headers for my turbo kit were a freaking nightmare... Obvioulsy the end result was worth it for the turbo, but for 8whp, no way in hell.
  8. Dec 7, 2016 at 10:24 AM
    Indy
    Yep, and don't forget that 0 is a number included in the "up to 15hp" claims. After many scientific studies researching gains of your common parts every scientist has come to the conclusion that if you spend $2000 to add 5 parts and net 5hp, you're an idiot :laugh:
  9. Dec 7, 2016 at 10:29 AM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
  10. Dec 7, 2016 at 2:57 PM
    devinzz1
    devin
    2023 aclb trd or mt
    Most hp on a na truck ive seen gained was 14hp from some dt headers. Actually i should say that gains throughout the rpm starting low looked fairly good. If you can find a used set and know what your at to install them then id say go for it.
  11. Dec 7, 2016 at 4:08 PM
    The Driver
    Raph
    Thanks for all the posts, still undecided. Keep 'em coming!
  12. Dec 9, 2016 at 4:32 PM
    eon_blue
    Azusa, CA
    I have the TRD headers and TRD supercharger. Both came already on the truck when I bought it, so I can't compare it to how it was before. But the TRD headers/exhaust sound fucking awesome, that much I can say for sure. Very low, deep grumble. I have to take it easy driving through my neighborhood because it'll set off a couple car alarms if I'm not. It's not that it's obnoxiously loud, I think it's more to do with the sound vibrations. Anyway, I highly recommend TRD headers if you can score them (considering they were discontinued by TRD years ago)
