TRD HOOD
Discussion in '2nd Gen. Tacomas (2005-2015)' started by smoker0478, Oct 24, 2015.
  1. Oct 24, 2015 at 8:02 AM
    smoker0478
    smoker0478 [OP] Well-Known Member
    dylan
    2015 taco
    hey all i found a trd hood with scoop its primer black the piant shop i called for a quote said they cant just paint the hood they have to paint the whole front end of the truck which requires removal of the head lights and all kinds of labour in taping this sounds crazy to me my truck is 1 month old and magnetic grey. cant they mix the paint by the code to match or ishe correct? PLEASE HELP i dont know anything about paint
  2. Oct 24, 2015 at 8:05 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Some shops will do just the hood. The problem is the paint match has to be spot on or you will be able to tell, by blending in with the surrounding panels you won't be able to tell. On a brand new truck I would look to do just the hood as well.
    Island Cruiser likes this.
  3. Oct 24, 2015 at 8:24 AM
    smoker0478
    dylan
    2015 taco
    has any 1 else had 1painted and how did it turn out
  4. Oct 24, 2015 at 9:01 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Yeah they are wanting to blend it.
  5. Oct 24, 2015 at 2:40 PM
    DW6
    DW6 New Member
    I have an '08 silver, TRD scoop that id like to trade for non-scoop.
  6. Oct 24, 2015 at 2:46 PM
    smoker0478
    dylan
    2015 taco
    sorry bud i have a 2015 and it wont fit but ty you will have no trouble makin that trade
    lol
  7. Oct 24, 2015 at 3:59 PM
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    I also have a skewp hood in black primer. If a shop tells me they cant paint it to match the panels then they are not a shop good enough to paint my truck. There is no valid reason to paint the entire front end.
    AR15xAR10 likes this.
  8. Oct 24, 2015 at 5:52 PM
    smoker0478
    dylan
    2015 taco
    i was shocked when they said that they couldnt match the paint on a brand new hood
  9. Oct 24, 2015 at 6:59 PM
    Toy4me
    Toy4me Well-Known Member
    Tom
    NNJ
    '10 DCLB TRD Sport MGM
    There is a valid reason.
    There is no reason to be shocked. Let me explain to you both how the process works. When you come in to a shop, we don't call Toyota and buy a pint of paint from their million gallon master batch of whatever color you car is (which still wouldn't guarantee a perfect match), it is custom blended. I go to a computer and enter the paint code and am given a recipe in grams for each tint color to come up with the final expected color. I put a cup on a scale and start pouring from my rack of master color bases, tints and metal flakes (which also vary in size and color) for metallic colors. I pour x amount of grams of base, then x amount of grams of each tint until I'm done. One drop more or less of any will cause a variance in how the final color will look. Not only that, but I don't know what brand of paint the manufacturer used - PPG?, 3M?, Sikens?, and even if I know Toyota uses brand x, what if my shop uses brand y? Then there is how I set my gun to shoot the paint and then how I shoot. And my gun is not exactly the same as what was used to originally shoot the car at the factory. Then there is my personal technique, from how far away I shoot to how I overlap my passes and how fast or slow I move. Oh and let's not forget age and fading to account for. The variables are almost endless. Ultimately, yes, a new panel could be painted without blending the surrounding panels without blending. I will shoot a test flop and compare it to the car, and do that again and again until I'm satisfied that it is a perfect match, but you're paying me (the shop) for time and materials to do that. Blending is generally the best way to make sure it looks good and you're happy. Good luck op.
    bogginator and shakerhood like this.
  10. Oct 24, 2015 at 7:20 PM
    smoker0478
    dylan
    2015 taco
    i guess i am not wanting to pay for the labour to dismantle and paint a perfect frontend sounds stupid to me guess i will stick with my stock hood ty
  11. Oct 24, 2015 at 7:23 PM
    Black Taco
    Black Taco Well-Known Member
    Rob
    WPB, FL
    TOYOTA
    No mods whatsoever!
    Bring your truck to the paint shop and have them match the paint chip to your existing hood in natural light. They wanted to blend mine also, but I didn't want it. They buffed the nose and it's pretty damn close to the hood.
  12. Oct 24, 2015 at 7:31 PM
    TruKnight
    TruKnight Well-Known Member
    Tru
    Arkansas
    Autobot Mall Crawler
    read build thread
    I know a thing or two about having your hood painted op. just paint the hood alone. you don't have to have anything blended at all if you don't want to. regardless, the paint will be a shade or two off so just expect that, there is nothing they can do to make it perfectly perfect. the good news is that there are sharp near 90 degree bends and curves where the hood meets the fenders, and I have loads of pics before and after mine and I honestly don't see a difference cause my color looks different shades from different angles and times of the day BEFORE I had the paintwork done. id suggest not blending, cause that just shifts the paint shade problem to the side of your truck.
    that shop basically just wants you to spend more $$. just do the hood bro. if they wont do what you want, find another shop.
  13. Oct 24, 2015 at 7:32 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    Why do you care? I've seen your car in person and the paint doesn't match at all. Probably doesn't help that you continually clear it off with a hockey stick either...
  14. Oct 24, 2015 at 7:37 PM
    bobsuruncle
    bobsuruncle PhD in voiding warranties
    Bob
    Fall City, WA
    06 TRD OR DCSB
    ARB bull bumper Warn XD9000 Icon 2.5 EXT Road Armor rear bumper Archive Garage shackle flip FJ/T4R tcase 4.30 gears Dirty5’s T4R rear axle swap w/disc brakes New frame from Toyota under EWP
    Don't forget the greasy chicken finger stains and hotspots from the grill.
  15. Oct 24, 2015 at 8:08 PM
    smoker0478
    dylan
    2015 taco
    lol but a hood scoop would make that car look miles better mabye i will just cut a hole inmy hood with a quickcut
  16. Oct 24, 2015 at 10:26 PM
    Crosis
    Dunedin Fl
    Lack of painting skills is not a valid reason and lack of skill is all it comes down to. Why have Americans become so accepting of shit work?
  17. Oct 25, 2015 at 5:17 AM
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    Location??????
  18. Oct 25, 2015 at 12:38 PM
    Toy4me
    Tom
    NNJ
    Sorry, I didn't realize you're a professional painter and have all the answers. Didn't mean to bore you with the truth.
    bogginator likes this.
  19. Oct 25, 2015 at 12:41 PM
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    Amen!
    Find another shop OP
  20. Oct 25, 2015 at 1:30 PM
    smoker0478
    dylan
    2015 taco
    ok all no need to get testy i thank all of u for the input and will take it all into account when makin my decision THANKS FOR ALL THE HELP
