TRD intake CA Smog Test
Discussion in 'Performance and Tuning' started by TRDmosco, Aug 19, 2011.
  1. Aug 19, 2011 at 12:39 PM
    TRDmosco
    TRDmosco [OP] Member
    Scott
    So Cal
    05 PreRunner SR5 V6
    TRD intake, magna flow exhaust, new gears with 4:56 ratio, unichip computer
    I have a 05 prerunner v6 with a TRD intake and I have a smog test for the first time. I know that this intake is not street legal in CA. This will be my first smog test since I bought the truck in 05. My question is will it pass? I know the obvious answer is no because it is not street legal, but my 99 tacoma had a k&n intake that was not street legal as well and it passed!.Has anyone passed smog in CA with this intake? Anybody know if my 05 will pass? Anybody know how the TRD intake affects smog tests? Any help would be greatly appreciated. My test is due by 8/31/11 so any help,tips,advice before then would be great! Thanks
  2. Aug 19, 2011 at 12:42 PM
    Lucario Runner
    Lucario Runner Resident SUV racer
    Robert
    San Antonio, TX
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    when its time for inspection switch to the factory box.
  3. Aug 19, 2011 at 12:44 PM
    The1youluv2hate
    The1youluv2hate Well-Known Member
    Peps
    SP... CaL
    11 TRD sPort
    5100's@1.75 Horns (Andres) Satoshi TRD cat back BHLM
    Find a friend with same truck & ask to borrow stock intake if you don't have it or just go to a junkyard
  4. Aug 19, 2011 at 12:54 PM
    TRDmosco
    Scott
    So Cal
    05 PreRunner SR5 V6
    The problem is I sold my stock intake:(. Im thinking about just risking it and go to a mom and pop type place and see if they care
  5. Aug 19, 2011 at 12:56 PM
    The1youluv2hate
    Peps
    SP... CaL
    11 TRD sPort
    You are in so cal & worth a try
  6. Aug 19, 2011 at 12:56 PM
    Lucario Runner
    Robert
    San Antonio, TX
    06 Toyota 4Runner
    I got a stock intake and a K&N, but there for a 4runner.
  7. Aug 19, 2011 at 1:44 PM
    TRDmosco
    Scott
    So Cal
    05 PreRunner SR5 V6
    Thx that is really cool of you. Unfortunately I'm in Ventura and I believe that is pretty far from chino hills. I might try searching for a cheap used stock intake on the internet or junkyard
  8. Aug 25, 2011 at 4:48 PM
    TRDmosco
    Scott
    So Cal
    05 PreRunner SR5 V6
    I got my truck smogged today and I passed! I passed with extremely low numbers as well. I got almost all zeros on everything. So why is the TRD intake illegal if it puts out such little emissions? It actually made it better. Thanks for everyone's help! Very appreciated!
  9. Aug 25, 2011 at 5:40 PM
    TRDmosco
    Scott
    So Cal
    05 PreRunner SR5 V6
    I noticed the new TRD intake is 50 state legal. I also noticed that it has a flat air filter instead of a cone. I cant find the dyno map on it. Do you know which one gets better performance or are they the same?
  10. Aug 25, 2011 at 7:57 PM
    TRDmosco
    Scott
    So Cal
    05 PreRunner SR5 V6
    what do you mean by run lean?
  11. Aug 25, 2011 at 9:43 PM
    TRDmosco
    Scott
    So Cal
    05 PreRunner SR5 V6
    I see. They probably had to do that to make it CARB legal, so the first gen probably has better performance
  12. Sep 6, 2011 at 5:45 PM
    Bill3888
    Bill3888 New Member
    Bill
    Riverside CA
    05 PreRunner SR5 TRD 4D LB
    Just got a used 2005 with a K&N. Need to go back to stock for smog test if I can't find a smog guy to do it with the K&N. Anyone got pictures of a stock 2005 set up so I can put the original back on for the test? Thanks
  13. Sep 6, 2011 at 7:20 PM
    Menametony
    Menametony Well-Known Member
    Tony
    San Diego
    09 Black 4x4 DC Offroad
    Flow Master 40 Series, TRD CAI, Kings 2.5 remote res front and back, All Pro Front bumper, All Pro Skid Plate, PIAA 4" 510 XT SMR, TC UCA's, 265/75/16 WildPeak AT3 on ATX Artillery, LightForce 240 Blitz HID's, WeatherTech Vents and FloorMats, Cobra 19 CB & PA, Maglite mod both driver and passenger, safari snorkel, TRD supercharger, warn 10k winch, PRINSU CabRack, Cali Raised 42" Light Bar,
    I got mine smogged with it on, passed, and the guy said since Toyota installed it, it was fine, just say the dealer installed it?
  14. Sep 6, 2011 at 7:36 PM
    jarvis210
    jarvis210 Well-Known Member
    Bryan
    Fullerton
    05 TRD Tacoma
    my truck is trd supercharged with trd intake i smogged last year with no issues
  15. Sep 6, 2011 at 7:46 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    the intake should be CARB legal...
    the kits we have installed came with a CARB exempt sticker to place on the chassis...
    i've taken my truck in for smog a couple times and they didn't even look at the sticker...
    all they asked is if i modified the throttle body...
    haven't had an issue passing...
  16. Sep 7, 2011 at 10:27 AM
    TRDmosco
    Scott
    So Cal
    05 PreRunner SR5 V6
    I have an 05 with a TRD intake that I just got smogged and it passed with no problem. It actually passed with all zeros on the emissions test. If you're in SO CAL ill give you the name of the shop I went to.
  17. Mar 1, 2012 at 4:31 PM
    renencb
    renencb Member
    Renen
    Willow Creek, Ca.
    06 Tacoma Trd
    TRD Supercharger, TRD Exaust
    that's all good news! I just dropped my 06 TRD w/blower off at a smog shop in nor-cal. Figured id cruise the forum for some encouraging words while I await the verdict!
