Trd intake on a 2020?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nwelsh415, Feb 11, 2020.
  1. Feb 11, 2020 at 6:15 PM
    nwelsh415
    nwelsh415 [OP] Member
    Nick
    2020 tacoma trd sport quicksand
    I’ve been looking at the trd intake and I know my truck is the same as the previous years but I can’t confirm anywhere that the trd intake will fit my 2020. Does anyone know?
    Junkhead likes this.
  2. Feb 11, 2020 at 6:19 PM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
  3. Feb 11, 2020 at 8:23 PM
    nwelsh415
    Nick
  4. Feb 11, 2020 at 8:25 PM
    nwelsh415
    Nick
    I know in the title it says 2020 but then down below it says up to 2019 and Toyota can’t confirm the fit on 2020 so that left me a little confused. Should I assume anything that fits a 2019 will fit a 2020? I just got my truck and it’s my first Toyota so I’m still figuring it all out. Thanks
  5. Feb 11, 2020 at 8:27 PM
    shane100700
    shane100700 Bed, Bath & Beyond Crawler
    Montana
    2019 DCSB, OR
    Rocket Boosters
    Yes... it will. It’s going to take awhile for parts lists to be updated to 2020 vs 2019.
    whatstcp and shakerhood like this.
  6. Feb 11, 2020 at 9:49 PM
    Walkdog
    Walkdog Member
    2017 TRD OR
    Save yourself some money and time and get the TRD air filter if performance is what you’re after. The box is just bling since you already have an essentially identical CAI. The stock assembly is actually quite a bit more expensive than the TRD kit, FWIW.
  7. Feb 11, 2020 at 9:52 PM
    shane100700
    Montana
    2019 DCSB, OR
    Rocket Boosters
    o_O Ummm really?
    For looks only.. maybe some sound..
  8. Feb 11, 2020 at 10:26 PM
    Walkdog
    Walkdog Member
    2017 TRD OR
    Lol true but it does give slightly better throttle response per my posterior dyno. Pretty comparable improvement to the TRD catback exhaust, IMO. At 1/10 the price.
    Crionchip likes this.
  9. Feb 11, 2020 at 10:30 PM
    shane100700
    Montana
    2019 DCSB, OR
    Rocket Boosters
    Should post those results. Might actually be the first with evidence of it providing any real benefit.
    In&out and GreyBaldTaco like this.
  10. Feb 11, 2020 at 10:42 PM
    Walkdog
    Walkdog Member
    2017 TRD OR
    Sorry to confuse. Posterior dyno = butt dyno. No empirical results of any kind.
    It feels a little better and I really don’t think it’s placebo from the noise. In my limited personal experience, the engine pulls/revs more freely, has fewer moments where it struggles, etc. Whether or not it’s making more ponies, the improved “feel” is palpable.
  11. Feb 11, 2020 at 10:44 PM
    shane100700
    Montana
    2019 DCSB, OR
    Rocket Boosters
    Ahhh, got ya... I just seen “post” and then my brain skipped the rest of the word.
  12. Feb 12, 2020 at 2:44 AM
    Crionchip
    Crionchip Well-Known Member
    2018 TRD 4x4 OR DCLB
    I can attest, the truck feels better, smoother, stronger pull on acceleration, and sounds better with TRD CAI.
    Just some notes on the design... Larger volume box above filter, larger diameter tube from box to throttle body, smaller resonator box. And then there is the main filter, and the permanent filter in top of box, both less restrictive.
    Junkhead, VaToy, AKGSD and 1 other person like this.
  13. Feb 12, 2020 at 2:51 AM
    GreyBaldTaco
    GreyBaldTaco Well-Known Member
    2019 F150 5.0
    The truck can't even use all the air the stock intake is capable of providing.
    Hatfieco05, Tullie D, In&out and 2 others like this.
  14. Feb 12, 2020 at 5:14 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Don't forget it seals better going into the fender.
  15. Feb 12, 2020 at 5:17 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Websites are often slow to update fitment when the newer years of the same vehicle are released. Nothing has changed under the hood of the 3rd Gen Tacomas with regards to the air intakes so you are good to go.
    Irons likes this.
  16. Feb 12, 2020 at 5:42 AM
    Crionchip
    That is true... Much better, so theoretically colder air supply.
    AKGSD likes this.
  17. Feb 12, 2020 at 8:27 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    The TRD Pro comes with this TRD Intake and TRD Exhaust and is rated exactly the same as other Tacoma's as far as HP, Torque, and MPG.
    putt1333, Mmaira2018, BSFord and 8 others like this.
  18. Feb 12, 2020 at 8:33 AM
    Filterec
    Filterec Well-Known Member
    J
    San Diego, CA
    2019 Voodoo TRD Pro
    No. No it doesn’t. It comes with a “TRD muffler, pipe, tip” but does not come with any different intake than any other Tacoma.
    WVTacoma08 and Junkhead like this.
  19. Feb 12, 2020 at 8:34 AM
    shakerhood
    Southern Ohio
    My bad, I thought it had the TRD exhaust.
  20. Feb 12, 2020 at 8:39 AM
    Devious6
    Devious6 Not your Average College President Emeritus
    Mark
    Northeast Pennsyltuckyvania
    2020 Army Green TRD Pro
    It does - it comes with the TRD Pro cat-back exhaust. It doesn't come with the TRD Cold Air Intake.
    TRD-ED, WVTacoma08, Ch78 and 5 others like this.
