TRD Intake Questions
Discussion in 'Performance and Tuning' started by TonyDobbs, Jan 31, 2016.
  1. Jan 31, 2016 at 8:35 PM
    thebottomline
    thebottomline Well-Known Member
    Pac NW
    11 sport
    2nd gen trd air intake with a TRD supercharger.
    No lean out at all, AFR just under 11. Supercharger noise is quite loud. Not sure about much in the way of performance gains, I got the intake before the supercharger.
    Don't believe the hype about how terrible it is. I've had no issues whatsoever. It is an oiled filter and my MAF is fine.
  2. Jan 31, 2016 at 8:37 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    The new trd is based off of wrong demensions isnt it?
  3. Jan 31, 2016 at 9:12 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Oddly as this will sound, Gadget doesn't run a boost gauge. Said he believes that his s/c was at ~8psi on the dyno.
    http://www.xr-underground.com/forum/showthread.php?t=56551
    My engine which I am prepping to install in the next two weeks, is very similarly built as his. Minus the stroker crank.
    With URD's configuration on that dyno, take notice of how high the torque is at 2250 rpms. Over 300. As well that it was a fairly linear progression. Very impressive.
    To compare to a turbo 1GR, in stock trim, it makes roughly the same torque at the same ~8psi. While right at 400 peak whp. Again, stock internals.
    Different volumes of flow between turbos and centrifical superchargers.
    On a stock 1GR, I highly recommend against surpassing 450 wtq. Which roughly equates to 400 whp depending on the s/c variant.
    With my built engine, Goldylocks, I do not know exactly what to expect as far as output will be concerned, since it has been over-bored so much. ~8 psi will be the starting boost level as for reference to the many dyno charts which I have catagorized. Then up to ~15 psi.
    On my last built engine, with the only change aside from being built, was that the compression was 9.5:1, the engine made what is in my Sig. I expect this 4.xx liter 1GR to output more.
    With the stroker engine, which also has cams, I expect to make something similar to what Gadget's truck did at ~8psi, but with much more torque.
    So there are the tasty performance treats which I can offer.
    A 1GR with rods, pistons, head gaskets, and head studs, is capable of 600+. It has been done and proven. Just need the F/I inducer to get it there.
    Biscuits likes this.
  4. Jan 31, 2016 at 9:23 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    For all of the "blown built engines," which have happened on the two forums which I am a member of, I can tell you that poor tuning, owner error, or a combination was the root cause. Me included. :wave:
  5. Feb 2, 2016 at 5:13 PM
    WOODEX M.E.
    WOODEX M.E. Well-Known Member
    Corey
    Maine
    2013 Tacoma TRD OR Pyrite Mica
    TRD Supercharger, Speedhut TRD Boost Gauge, Speedhut TRD AFR Gauge, PLX Wideband Controller W/Bosch O2 Sensor, Cravenspeed Boost Pod, AFE Pro Dri II Si Intake, Calvert Racing Caltrac Traction Bars. URD Catback Exhaust, URD 2.825" Super Grip Pulley, URD Spec-U Equal Length Headers, URD 255lph Fuel Pump, OEM FPR Mod.
    From what I understand, you are like a death sentence for tacoma engines.
  6. Feb 2, 2016 at 6:00 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Just doing a better job of testing the "extremes" than Toyota. ;)
