TRD Intake vs Aftermarket Intake
Discussion in '2nd Gen. Tacomas (2005-2015)' started by eddieEndo, May 28, 2010.
  1. May 28, 2010 at 12:24 AM
    eddieEndo
    eddieEndo [OP] Well-Known Member
    Eddie
    Fullerton, CA
    Scion FRS
    I've been in the market for a true CAI, what're your guys' thoughts on the TRD Intake (on sale online for a whopping 390) vs aftermarket intakes
  2. May 28, 2010 at 12:51 AM
    j1999t
    j1999t Well-Known Member
    Justin
    Northern Colorado
    traded it in
    urd makes the only true cold air intake
  3. May 28, 2010 at 12:57 AM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    if u want the TRD, get the AFE stage 2....IIRC, it's the exact same w/o the trd on it and cheaper
  4. May 28, 2010 at 1:02 AM
    Jigzor
    Jigzor Well-Known Member
    Pennsylvania
    17 DCSB Silver Sky
    Exactly correct. the only difference besides the TRD logo is that the AFE intake box has a slot in the front for either drainage or a little additional air. The location of the small slot would allow the warmer air in though. It also comes with a plug to insert, instead of leaving it open.
  5. May 28, 2010 at 1:14 AM
    2010 trd sport
    2010 trd sport Well-Known Member
    NY
    2010 trd sport
    none yet
  6. May 28, 2010 at 1:15 AM
    eddieEndo
    Eddie
    Fullerton, CA
    Scion FRS
  7. May 28, 2010 at 1:26 AM
    jhodge83
    SC
    17 XLT Sport
    correct...it's primarily just rebranded
  8. May 28, 2010 at 8:14 AM
    T0LLPHR33
    T0LLPHR33 Well-Known Member
    S1N C1TY...(from Hilo, HI)...
    BSP TRD Off-Road
    APR X-1 | TRD CAI w/Clear Cover | TRD Short Shifter w/ TRD "RED" Shift Knob | SGII w/Blendmount| Snugtop SL w/KeyLess Entry | 5% Tint | Pop-n-Lock | Bosch Icon WB | S2K Antenna | HRM | LS 8K Projectors w/BSP HLM & 8K Fogs w/FLM | Debadged |Tinted Tails | Black Weathertechs | MX RGM & RBM | Optima Red Top 35 | Gatorback Belt |
    the TRD CAI is an aftermarket intake...just clearing the air...:D
    but keep in mind that there are 2 version of the TRD CAI...
    1st gen was made by AFE...like mentioned above you can pick up the AFE Stage 2 w/Pro Dry S filter...the 1st gen is no longer made...and its really hard to track 1 down.
    2nd gen is now made by AEM...same company that makes the CAI for the Tundra...another thing to keep in mind...AEM was contracted by Toyota to make a carb legal CAI...by making the 2nd gen a drop in filter along with carbon filter...is allows people who like in california to pass smog check...
    I say the downside to the 2nd gen is the carbon filter...its a little bigger than stock so you will gain some TQ/HP but overall it doesn't make as much power as the 1st gen...
    URD does make a nice CAI...you do have to splice your existing wiring for the MAF sensor because it is relocated further down the intake piping...you will also need to purchase a shield to protect the intake from sucking in water...you will also need to cut a section out of the radiator support (behind the passenger side headlight) too fit and run the piping for the URD CAI into the intake manifold...MAF calibrator is a must for the URD...just so that your ECU doesn't run to lean or rich...but if you have the X-1 the MAF CAL. is not needed...
    good luck on your hunt for your CAI...I'll tell you I love my 1st gen TRD CAI...:D
