TRD Ivan Stewart Wheels - any pics?
Discussion in 'Wheels & Tires' started by lyonmat, Mar 18, 2008.
  1. Mar 18, 2008 at 5:13 PM
    lyonmat
    lyonmat [OP] Member
    08 Silver Prerunner TRD Double CAb
  2. Mar 18, 2008 at 5:44 PM
    rick
    rick `
    TW member Tjopilot[​IMG]
  3. Mar 19, 2008 at 8:21 AM
    Burns
    Burns Excellent Member
    17 DCSB Off-Road
    Bilstein 5100's @ 2.0", Wheelers 1.5" AAL, 265/75/16's
    I have seen that truck in person (another forum meet) it is one kickass truck, I love that color!
  4. Mar 19, 2008 at 7:37 PM
    lyonmat
    lyonmat [OP] Member
    Perfect! Yeah those look good thanks for posting the pic up..... Will those fit the 2 and 4 wd versions? I saw an ad on Ebay for them and they said would only fit the 4wd versions.
  5. Mar 19, 2008 at 7:41 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    they should fit a 4x2. the rims on sports, offroads, and regular sr5's are the same on 4x2 or 4x4.
  6. Apr 1, 2008 at 3:32 PM
    cpanos
    cpanos New Member
    08 4x4 TRD Off-Road
    How were your wheels and tires balanced?
  7. Apr 2, 2008 at 11:42 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    It's usually done on a machine that makes the wheel spin and tells someone how much weight to put on a given part of the rim. :smack!:
    Be more specific. :p
  8. Apr 2, 2008 at 11:42 AM
    mjp2
    NJ
    Oh, and welcome to TW! :D
  9. Apr 2, 2008 at 3:50 PM
    cpanos
    cpanos New Member
    08 4x4 TRD Off-Road
    Thanks!
    I want to know if he is satisfied with the balancing job he got when he mounted the tires. Was a Hunter "Road Force" machine used? Did they use pound on weights on the inner bead and tape on weight behind the spokes, as per the Toyota TSB for these wheels?
    I'm trying to get a straight answer out of someone if the newer version wheel designed for TPMS is actually a hub centric or lug centric design? This make a big difference on what type of balancing equipment needs to be used.
    Hope this clears my question up!
  10. Apr 2, 2008 at 4:44 PM
    Toycoma06
    Toycoma06 Well-Known Member
    Richmond Va.
    2016 tacoma 4x4 dbl. cab
    20% window tint, emblems removed, aftermarket grill, TRD Pro shift knob,4'' RC lift with BDS 2.0 fox rear shocks, 285x65r18 Nitto Ridge Grappler, 18x9 Monster Energy 540B 0mm offset, ...and more to come
    Here is a pic of the Ivan Stewarts with Mickey Thompson Baja ATZ's
    285/75-16. I have had no balancing issues at all.
  11. Apr 3, 2008 at 7:00 AM
    mjp2
    NJ
    Very much! Of course, now it's all over my head so hopefully someone else will step up. :eek:
  12. Apr 3, 2008 at 4:46 PM
    PatheticJoe
    PatheticJoe Well-Known Member
    Sacramento, CA
    07 Prerunner SR5 TRD Sport - Access Cab
    Is your truck lifted? If so how much?
  13. Apr 3, 2008 at 4:52 PM
    Toycoma06
    Richmond Va.
    Yes it is....... 3'' Toytec OME 884's in the front and suspension TSB with 1.5 blocks in the rear
  14. Apr 6, 2008 at 4:24 PM
    rpoint16
    rpoint16 Well-Known Member
    Tempe, AZ
    2022 TRD Off-Road, Super White.
    Bone Stock
    NICE LOOKING RIDE!!!!!!
    Do you get any rubbing when you are "ass up in the air" 4-wheeling?
  15. Apr 6, 2008 at 4:27 PM
    rpoint16
    Tempe, AZ
    Bone Stock
    There is Precision Toyota in Tuscon, that has those in a EBAY store for $165 ea..(888-751-1188). Most dealers will negotiate down to $200. ea.
    I was told two different things though about the lug nuts. Not sure if you can use the OEM's or have to but the TRD's.
  16. Dec 20, 2011 at 11:32 AM
    fltacoma
    fltacoma Well-Known Member
    daniel
    Shreveport, LA
    no truck as of yet :)
    that is indeed a nice truck. old post, but nice truck :)
  17. Dec 21, 2011 at 1:29 PM
    Warputer
    Warputer Dirt Road Inspector
    Lake Murray, South Carolina
    2011 TRD Off Road
    9" of Super Bro lift
    Cause I'm a pic ho.......
  18. Sep 9, 2012 at 9:29 AM
    Warputer
    2011 TRD Off Road
    Updated pic with better tires.....love my wheels! :D
  19. Sep 9, 2012 at 9:39 AM
    Yamaha Dave
    Yamaha Dave Well-Known Member
  20. Sep 9, 2012 at 10:02 AM
    Manwithoutaplan
    ID
