TRD Lift kit... fog light delete help!?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JHusky, Jun 20, 2021.
  1. Jun 21, 2021 at 2:48 AM
    Pro-Taco
    Pro-Taco Well-Known Member
    Lou
    Commiefornia
    2019 OR DCSB 4X4 Prem/Tech Cement
    All TRD Pro parts
    Of course they "can't get them to work". It's a liability issue! They reinstalled them back for aesthetics but they will never turn them on, no matter how many waivers you will sign. Service director will never let this happed.
    1- They didn't plug them in
    2- They removed a fuse
    3- They programmed them out
    LOL: The service manager gave the idea that maybe the car's computer is registering the lift and cancelling the fog lights. They must think you're an idiot. I would not waste my time at that dealership again. Find another dealer and tell them that something is wrong with your foglights. Let them fix it under warranty.
  2. Jun 21, 2021 at 3:55 AM
    Paulndot
    Paulndot Well-Known Member
    2020 TRD Off Road
    Check out pgs. 26-27 of the install instructions. Steps 37(c) and 37(h). The ONLY thing the tech should have done is to unplug the lights, remove the fuse (I'd triple check that to be sure the fuse is in and not a dummy or something to that effect) and add dielectric grease to the plugs. Retrace those steps man. If the idiot light on the dash is coming on, there's something else going on.
  3. Jun 21, 2021 at 9:29 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    Off topic but is there a shared drive of all the factory installed options instructions by chance? Didn't find anything in the sticky's (sure wish we had more sticky's on here!)
  4. Jun 21, 2021 at 9:35 AM
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    'Maybe the computer is registering that it's daytime, and there is no fog..' - managers next suggestion..
    Junkhead, vivid02 and Clearwater Bill like this.
  5. Jun 21, 2021 at 2:34 PM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    They will see it in the records when he takes it to another dealership. Not a good idea. I would find a toyota mechanic and pay him on the side, plenty of them on FB.
  6. Oct 23, 2021 at 7:46 AM
    Lmad928
    Lmad928 Active Member
    Logan
    2022 Army Green Tacoma TRD Off-Road
    Would anyone know how high the fog lights sit after the lift kit? I live in PA and am trying to decide if I should get the lift kit installed or not. The state of PA has a regulation where the fog lights can not exceed 42 inches above the surface of the road.
  7. Oct 23, 2021 at 9:31 AM
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    Not the OP, but I’ve got the 2G TRD Pro lift on my truck (~2 inches). 42 inches is above the bottom of the DRL on my headlamp, likely 1/3 the way up the headlamp itself. I’d need a 6” drop bracket lift to even get close to 42”.
    Lmad928[QUOTED] likes this.
  8. Oct 23, 2021 at 9:37 AM
    MikeyMcFly
    I'm a Masshole
    Building a Broja
    Two things that jump out at me, #1 is that CA (where the OP lives) isn’t on the fog delete list and #2 is that they expect Toyota to discard the old parts, including the fog lamps it seems. My inner Karen (is it Kyle for dudes?) says that if they’re not returning the old parts to you they should compensate you for it.
    Paulndot[QUOTED] and Lmad928 like this.
  9. Oct 23, 2021 at 9:56 AM
    Lmad928
    Logan
    Sounds good, thank you for the info! From what your saying it seems like I shouldn’t have any issues in the state of PA. Unless the Toyota dealership tries to pull a fast one on me haha
  10. Oct 23, 2021 at 11:29 AM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    okay that might be the dumbest thing I've heard from a dealership :rofl:
    Lmad928 likes this.
  11. Oct 23, 2021 at 11:39 AM
    Lmad928
    Logan
    I completely agree!!
  12. Oct 23, 2021 at 12:35 PM
    vivid02
    vivid02 Buy a Tesla…..I need the gas.
    Edwin
    SoCal
    2021 Tacoma TRD Off Road 4x4 DCSB
    OEM+
    Start backwards, make sure the bulb is there.
    Make sure each one is plugged in properly. Unplug them a replug. Follow the electrical wiring on each to make sure they did not cut any wiring. Check the fuse. Remove the fuse and swap it with another fuse in the fusebox.
  13. Nov 29, 2021 at 10:02 AM
    markey
    markey Active Member
    NE Ohio
    '06 Tacoma TRD
    Any update on if you were able to get the fog lights functional? I just ordered a 2022 TRD OR with lift kit but now I’m reluctant to go with this option if it means losing the fog lights. I like the idea of the custom grill and upgraded shocks but not at the expense of losing the fog lights. I believe the premium pkg I ordered includes LED fog lights on top of it.
  14. Dec 12, 2021 at 8:43 PM
    JHusky
    JHusky [OP] Active Member
    James
    2021 Army Green Tacoma Off Road
    I took out and put back all relevant fuses and inspected all wiring and unplugged everything I can think of and it all came back on. My hunch is fuses but it works now! Just ask for them to leave the fogs in if they can otherwise just install them yourself. Something odd must have happened with mine and the dealer was too lazy to go through and make sure it was back up and running. or they just didnt care cuz they werent supposed to hook it up anyways.
    markey[QUOTED] likes this.
  15. Dec 12, 2021 at 8:53 PM
    #35
    bluelinetaco
    bluelinetaco Well-Known Member
    North Cali - Yay Area! (707)
    2019 TRD Pro VooDoo Blue
    COOL Stuff I can't afford . . . But I bought anyway!
    Hey, I'm really close to you, in Benicia. I've got a pretty good amount of experience with automotive lighting. If you'd like you could come over Wed or Thurs and we can take a look at if you can't figure it out.
    Check the fuse, bulbs and relay, as others have said. Also, there are two fuses if I recall correctly. One in the engine bay main block and one under the dash. One is for the switch to relay the other is the power for the light.
    If you can't figure it out, I'll be happy to help if you'd like. PM me if so.
    Cheers and good luck.
  16. Dec 12, 2021 at 8:55 PM
    #36
    JHusky
    James
    I think we posted at the exact same time lol even though mine was a very delayed update.
    This is why I love this forum. awesome people like you thanks man I appreciate it. Luckily I was able to fix it myself.
  17. Dec 12, 2021 at 9:03 PM
    #37
    bluelinetaco
    all good glad you got them working.
    curious, are the housings the normal h11 reflector housing or something else?
  18. Dec 12, 2021 at 9:05 PM
    #38
    JHusky
    James
    Normal. I bought the trick off the lot and had the kit installed at like 500 miles at a different dealer. labor was like $1500 cheaper in walnut creek compared to Marin.
  19. Dec 12, 2021 at 9:07 PM
    #39
    bluelinetaco
    Oh. Ok. I ask because I have the rigid pro lights (on my pro, duh) and I’ll be swapping them for some diode dynamics. Wondering if you’d be interested in them? Lights and bezels.
  20. Dec 13, 2021 at 10:05 AM
    #40
    markey
    NE Ohio
    '06 Tacoma TRD
    Cool thanks Jhusky. Gives me some confidence that I didn't make the wrong choice.
