Trd lift kit
Discussion in '3rd Gen. Tacomas (2016-2023)' started by D Mayo, Jun 25, 2025.
  1. Jun 25, 2025 at 8:28 PM
    D Mayo
    D Mayo [OP] Active Member
    Devin
    2021 Toyota Tacoma Off Road
    2” level with TRD lift kit. SPC UCA. 285/70/17 OME medium load leaf
    I’m about to put fox 2.0 on my truck, i was wondering how much i could get for my trd lift, probably 10 miles on them. Just wondering.
  2. Jun 25, 2025 at 8:35 PM
    Mach
    Mach Well-Known Member
    2022 Lunar Rock DCLB TRD Off-Road
    Fox 2.0 seems like at best a lateral move not really an upgrade. Why the switch?
  3. Jun 25, 2025 at 9:41 PM
    Veet-88
    Veet-88 Well-Known Member
    18 Tacoma DCLB sport
    ^This, it really seems like a same same if not potentially worse change. Why bother.
  4. Jun 26, 2025 at 12:57 AM
    D Mayo
    Devin
    Looking for a softer ride, these are basically 5100s. Would switching to a linear from a digressive not be a step in the right direction if getting a smoother ride is the goal?
  5. Jun 26, 2025 at 3:01 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    You won't see that much of a difference. Comparing my truck lifted on 5100s and a 1-inch block aka 2/1 on 285s rides almost as good as my family member's Pro. Try and improve on what you have like making sure the air pressure is about 30 and try some better bump stops. I don't think it's worth the hassle and money.
  6. Jun 26, 2025 at 3:12 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Try lowering the tire pressure. I have E loads on a heavy truck (~5400 lbs) and run 30 PSI front and 25 rear.
  7. Jun 26, 2025 at 5:28 AM
    Veet-88
    Sorta. Fox especially their lower end stuff was noted for less than ideal ride quality during the blind testing videos that were done. I now remember your other post. I would really go and experiment with other tire combinations before dropping money on all new suspension. There are way to many happy people with the 5100's or that trd kit to be the root of your problem.
    Tocamo and Chew like this.
  8. Jun 26, 2025 at 5:42 AM
    D Mayo
    Devin
    I’ve lowered my pressure to 32/33 on all 4 tires. It helped a little. I believe i have bad ball joints on my spcs so im going to swap those with the newer ones. I also did the carrier bearing drop. I’m not sure if that really did anything or it’s in my mind but to me that also helped a tad bit. I was thinking of trying to drop the front so my cvs were as straight as they could be, maybe I’m getting vibration there. But my thought process is, i have 5100s “tuned for trd” with the stock coils on them. I ditched the rear block and just went with the ome medium load with gives me a little more lift in the back than the blocks did. I believe it rides better with those vs the block. I just have been and convinced that if i swapped to a linear valved shock it would increase the comfort on road. But that’s why i asked in here before hitting that buy button last night lmao
  9. Jun 26, 2025 at 9:18 AM
    Veet-88
    Add some weight to the bed if it's empty. Assuming this is dcsb those med leafs will be stiff until the flatten out and you want to replace them as they won't hold up groceries much less an actual load.
    I mean all the power to you to swap out suspension but going to an sl rated 285 would likely do you far better than anything
    71tattooguy likes this.
  10. Jun 26, 2025 at 3:14 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Good luck Devin.
  11. Jun 26, 2025 at 5:26 PM
    D Mayo
    Devin
    Thank you tocamo
  12. Jun 26, 2025 at 5:27 PM
    VaToy
    Parts Unknown
    The block will be a better ride, try new bump stops.
    absolutely!
  13. Jun 27, 2025 at 2:33 AM
    D Mayo
    Devin
    I went with Bilstein 6112 5160
