TRD lift questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Every name is taken, Jun 19, 2023.
  1. Jun 19, 2023 at 8:26 AM
    Every name is taken
    Every name is taken [OP] New Member
    Jeff
    2010 TRD Off Road
    I have been researching lifts for my 2010 and have a few question I hope you all can help with.
    First off all my goal is to run 285's, I don't do any hard-core wheeling just have had the truck 10+ years and ready for a face lift and make it feel like something new.
    I understand the TRD comes with a small lift and want to make sure I'm not taking off stock suspension just to replace it with the same and not achieve any lift.
    Are spacers and blocks a good way to go when only doing mild off reading? If doing spacers what point do I need to other mods to the suspension?
    I see so many posts the contradict others I'm not sure what is correct.
    Thanks
  2. Jun 19, 2023 at 9:38 AM
    ace96
    ace96 Well-Known Member
    Western KY
    '11 SWB DC TRD SPORT
    AVS bug deflector, Weathertech digital fit floor mats, TRD skid plate w/ Sockmonkey decal, SOS Cocept sliders w/ Line-x, Pioneer 3500, Hybrid Audio Technology Mirus 6X9s & 6.5s, back up cam mod, Wet Okoles-front & rear, TRD exhaust, 17X9 XD Spy w/ Falken Wildpeaks, Avid light bar
    TRD off-road doesn’t come with a lift on it. TRD Pros have a lift. Block and spacers are not advisable for off roading.
  3. Jun 19, 2023 at 9:46 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I’d go with Bilstein 5100 shocks
    I don’t personally like blocks. But 1” blocks in the rear isn’t “too bad”.
    You’d be better off with an add-a-leaf or full pack. But that’s more expensive and more labor.
    If you don’t don’t do a lot of off-road or hardcore off-roading you will probably be just fine with 5100’s and small blocks in the rear. If you’re just looking to level the truck, then all you need is the front 5100s
    The 5100s are adjustable.
    Tiedie likes this.
  4. Jun 19, 2023 at 12:18 PM
    10thMTNgrunt
    10thMTNgrunt This is the way, step inside.
    2013 TRD Sport
    Lift is a relative term OP, basically any suspension on an off road type vehicle is theoretically considered a lifted vehicle, now how much of a lift is dependent on what you’re after. The TRD Pros just have more of a lift than the TRD off road and sport and so forth, and the TRD off road had more of a lift than the base model Tacoma.
    I second TnShooter, stay away from block lifts, get yourself a set of Bilstein 5100s front and rear. Talk to the supplier about whether or not you need to have them adjusted for taco lean (the driver’s side that is) or if all you need is a 1/4” spacer on the driver side. I’m not too familiar with the 5100s but i know they’re the business. I did upgrade my suspension to what the third gen Tacomas run and it netted me a little less than an inch of lift in the front. I did need to include a 1/4” spacer on the driver side though as they are non adjustable struts.
    Tiedie, BluberryBCtaco and TnShooter like this.
  5. Jun 19, 2023 at 6:26 PM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    if you wanna run 285s I hope you plan on doing some cutting
    Out2gtcha likes this.
  6. Jun 19, 2023 at 8:22 PM
    BluberryBCtaco
    BluberryBCtaco Making the magic happen
    BC Canada
    2007 Tacoma Sport DCLB
    3in lift, Tow package, Any time 400w inverter, in cab outlet, vinyl floor, roof rack
    For me on 285/75/17.
    No BMC only the inner fender liner on the front side.
  7. Jun 20, 2023 at 4:55 AM
    Every name is taken
    Jeff
    2010 TRD Off Road
    What does BMC stand for?
    Thanks
  8. Jun 20, 2023 at 6:00 AM
    HWI
    HWI Well-Known Member
    North Florida
    2015 Tacoma TRD Off Road
    Body mount chop, also referred to as a CMC (cab mount chop).
  9. Sep 27, 2023 at 12:18 PM
    Clymber
    Clymber Well-Known Member
    Vermont
    Trd
    It’s odd how some have to to BMC and others do not. Wonder if it’s the wheels they choose, the lift or combo of both
  10. Sep 27, 2023 at 12:22 PM
    Out2gtcha
    Out2gtcha Well-Known Member
    Brian
    Omaha, NE
    2020 Quicksand Off Road DCLB 4x4
    Yes. Offset and width along with clearance from a lift makes a huge difference.
    I run 285/75/17s with a 2.5" lift, CMC and pinch.
    I still rub a tiny bit under full compression and full lock, but 0 rubbing day to day.
  11. Sep 27, 2023 at 3:29 PM
    BigCountry762x39
    BigCountry762x39 Well-Known Member
    TL
    PNW, Oregon!
    2009 Tacoma, with the cool white paint peel
    Arb Deluxe bull bar Front Bumper Ironman4x4 12k winch synth line AFE Intake OME 2.75in Dakar Leaf springs (R) Fox 2.0 bypass shocks (R) Bilstein 6112 (F) 33's on KMC wheels off road lighting comfort mods Redrock HD roof rack Retevis rt95 Radio Slotted Rotors and HD pads
    no body chop, thought i do get some Rub when turning if under some compression, thought I'm on some aftermarket KMC wheels and the liner and flair has some trimming on a 285/75 17 BFG
    though I'm not sure what my lift is any more as my ARB bumper and 12k winch have some weight and my rear suspension leaf's are really badly warn.
  12. Sep 27, 2023 at 3:46 PM
    Tiedie
    Tiedie The Only Shantytown Resident.
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    Since no-one has asked the most crucial and important question and you did not disclose it. What is your budget? Then you can start really looking .
    Good luck.
    jeminyned likes this.
