TRD lift/rake question
Discussion in 'Suspension' started by RRDave, Dec 30, 2010.
  1. Dec 30, 2010 at 6:44 AM
    RRDave
    RRDave [OP] Well-Known Member
    Halifax, NS
    08 Black TRD
    CAI, AT2525XL, 2.5" spacer, 1.5" AAL, DNX6140 HU c/w rearview cam, Fog Light Mod, Custom rear dog seat,
    Hey Everyone,
    I have an 08 DC TRD sport and I'm just curious as to whether or not there's any difference in the stock amount of rake between models? My plan is to do a slight lift, maybe 2.5" in the front and 1.5" in the rear. My question is, in doing so, will I be nose high, level or lower in the front than rear? I noticed the readylift leveling kit is 2.25" in the front so logically if I go .25" higher in the front and 1.5" in the rear then I'd have a slight rake. That being said, I don't know how the .25" actually affects the geometry of the front end and if that translates .25" higher.
    Any comments are appreciated. And if anyone as pics of this set up I'd love to see them. I know there are tons of pics of lifts here, but haven't read this exact set up.
    Cheers
  2. Dec 30, 2010 at 6:54 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Ditch the readylift and go with Bilstein 5100's @ 2.5" up front, and a 1.5" AAL in the back, and you will be level.
    $300 or so to do that, and it's a much better quality lift than any spacer.
  3. Dec 30, 2010 at 7:05 AM
    Reepur
    Reepur Well-Known Member
    Brevard, NC
    '10 RC Black 4x4 2.7L
    265/75/16 BFG KM2 's on XD Hoss's 2.5" lift/4xBillies, OME 885's, Firestone Ride-Rites Desert Specialties UCA Volant CAI Grillcraft Grill Kobalt Slim Line Box Weathertech mats and Ventvisors. DTRL mod. 4 Lo -Trac Mod. Int. Wiper Mod. rcbs204 4x4 LEDS URD Short Shifter Plate Front bumper with Smittybilt XRC8000 winch Body Armor rear bumper with swing out tire carrier. ATO Front Skid Ultragauge BHLM
    I just did this lift and it sits level. (I have the DSM UCA also) But you should get the results you are looking for. I love it so far...day 3
  4. Dec 30, 2010 at 7:09 AM
    urbanplanner
    urbanplanner Active Member
    washington state
    leveling kit HID
    I have 2" in the front and 1" in the rear on a 06 DC OR and it's level.
  5. Dec 30, 2010 at 7:16 AM
    RRDave
    Halifax, NS
    08 Black TRD
    Thanks for the replies. So as a follow up, anyone have any comments on AAL vs a block in the back? I really don't need the added payload and would like to avoid stiffening the ride anymore than needed. Would it be unwise to only put 5100's in the front and either AAL or blocks in the back? (in the interest of $$)
    urbanplanner: do you have any pics? What size tires are your running with this?
  6. Dec 30, 2010 at 7:26 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Mine's 5100s all around, 2.5 up front with 1.5 AAL and I have 1.25 higher in back. But mine is prerunner and I have AAL shoved into the 3 leaf crap TSB packs.
  7. Dec 30, 2010 at 8:33 AM
    Reepur
    Brevard, NC
    Yours sits higher cause of the TSB packs. Mine sits level with the 3-leaf non TSB pack.
  8. Dec 30, 2010 at 1:36 PM
    KPT
    09 Prerunner
    Here this poll should help you decide AAL vs. block :laugh:
    http://www.tacomaworld.com/forum/suspension/130603-rear-lift-2-gen.html
  9. Dec 30, 2010 at 1:54 PM
    kd8awe
    kd8awe Well-Known Member
    Rocky
    Ohio
    4x4 TRD Off Road
    Fog mod, 3" lift, ShoMe stobes, MicroLight LED Strobes, HiLift Jack, RCI 2950, Yaesu 8900r, 20% Tint, ScanGauge II, Weathertech Side Window Deflectors, *** New Mod's (parts on the way) *** U-Bolt flip kit. Tom Woods 1 Piece Double Cardan Drive Shaft. 3* Axel Shims
    What if you want to keep the stock rake but want a 3" lift ?
  10. Dec 30, 2010 at 1:56 PM
    KPT
    09 Prerunner
    You will need a 3" block or a new leaf pack.
    Or I guess you could do a combo 2" AAL and 1" block.
    No one makes a 3" add-a-leaf that I've seen.
  11. Dec 30, 2010 at 1:57 PM
    ::childstoy::
    ::childstoy:: Hi-Tech Rednek
    Southeast, PA
    Black 2010 TRD Sport
    TRD Exhaust, Tint, Stubby Ant., Debadged, Weathertech Mats, Grillcraft... Currently collecting donations for a New Tires Fund.
    Did you find you had to do the UCA's because of space issues?
  12. Dec 31, 2010 at 6:44 AM
    Reepur
    Brevard, NC
    I got the UCA's when I ordered the lift from Downsouthmotorsports because
    1. I had the $$$$
    2. I wanted to eliminate as much as possible any alignment issues.
    3. Wheel clearance was not a consideration for me since I am going to use those stock 16" steelies with 1.25" spacers, just cant afford my tires yet.
    I can say that those DSM (Desert Specialties) UCA's are beefy, high quality,
    and a breeze to install. Not sure if they would give me more wheel clearance or not if I did chose do do a new set of wheels.
