TRD Locker Exchange
Discussion in 'Technical Chat' started by BRP27, Mar 11, 2010.
  1. Mar 11, 2010 at 12:42 PM
    BRP27
    BRP27 [OP] When I grow up I want to be just like Me
    So far south in Texas my feet are in salt water
    04 4X4 Tacoma SR5
    3 in Ultimate ToyTec, set @ 2.5 in. AAL PINCH Weld Mod ( beat the pinch weld over inside the fender) Painted the pinch weld on bottom of cab Black Hi Lift Knock off
    So I have a 04 SR5 4X4 V6 and I want to get a locker for the rear end. I am considering buying this truck its a 2wd TRD but if the rear end ratio is the same (4.10) I could bolt it in and wire it up? And then take the TRD decals off so I don't get anyone mad at me and sell it. The only other concern is the truck has 137,000 and my truck has 70,000 so I would be putting an older and higher mileage rear end in, what say you?
    2003 Toyota Tacoma PreRunner Double Cab SR5 V6 - $11,700
    Very clean
    137,000 miles
    2WD
    3.4L V6 automatic
    4 door crew cab
    Gray cloth interior
    TRD Off Road Package
    Alpine AM/FM CD player
    Runs good, no issues
    New tires
    Timing belt, water pump replaced at 102,000 miles
    18-19 MPG
  2. Mar 11, 2010 at 12:51 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    I don't see anything wrong with swapping the axles as long as the ratios are the same. I say do it.
  3. Mar 11, 2010 at 3:43 PM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    I really don't intend any offense, but ... It strikes me that paying about 20+ times the money necessary to get your hands on a TRD e-locker rear axle assembly is not a bright idea. By the time you pay taxes, fees, etc., you'd end up being 'out' as much as being patient and tracking down the specific components you really want ... ... Or just going ahead and putting a different aftermarket locker unit on your '04 4X4. Then there's the issue of trying to recover your investment out of a 7-year old Double Cab from which you've removed one of the main selling points ...
    Just my .02 ...
  4. Mar 13, 2010 at 11:32 AM
    BRP27
    04 4X4 Tacoma SR5
    One of the great things about the internet is all the info you can get floating a turd out on the electronic ozone
