TRD locker motor troubles
Discussion in '1st Gen. Tacomas (1995-2004)' started by jbutch, Jan 30, 2012.
  1. Jan 30, 2012 at 10:53 AM
    jbutch
    jbutch [OP] Member
    colorado
    03 Double Cab TRD
    OME 3" lift Pro Comp 16" rims
    Anyone had to deal with diff locker problems? I am on my second (first replaced under warranty by dealer) and need guidance on what to do next...try different make, ARB? other than toyota? Actuator motor is seized up again.
  2. Jan 30, 2012 at 10:54 AM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    get another motor?
  3. Jan 30, 2012 at 11:10 AM
    pt law
    pt law Well-Known Member
    Concord, NH
    04 xtracab 4x4 TRD
    Do you use the locker often? They are more likely to freeze up when they do not get used often.
    Second, are you sure it is the motor or is the motor working but the actuator frozen up (the motor can still trying to be working but the actual gear that locks the differential may be frozen up).
  4. Jan 30, 2012 at 12:07 PM
    jbutch
    jbutch [OP] Member
    colorado
    03 Double Cab TRD
    Using the locker often is most likely the problem. And it is the actuator, thought I stated that but probably not. I do not really understand this this part too well or the lingo.
  5. Jan 30, 2012 at 7:12 PM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '03/'04 Mutt Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Manual hubs, Dorkel
    I had actuator troubles last summer. I fixed it by rebuilding the actuator on a bench and I used for reference. just ignore the part where he redoes the actuator shell with fiberglass.
