TRD locker speed q
Discussion in '1st Gen. Tacomas (1995-2004)' started by JuansTaco, Sep 11, 2013.
  1. Sep 11, 2013 at 5:41 AM
    JuansTaco
    JuansTaco [OP] JuanInAMillion
    Juan
    gilbert az
    2004 PreRunner SR5 stormtrooper
    ESB long travel kit, Deaver f67s with DTF 12 inch shackles.
    what is the safest speed to use our factory lockers at. i have a 3.4 if that matters
  2. Sep 11, 2013 at 6:24 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    You can't engage it unless you're in 4lo.... so..... theoretically, while in 4lo... you probably can't go any faster than 35ish without the engine screaming at you.
    If you're able to go faster than that, you don't need the locker. :D
  3. Sep 11, 2013 at 6:43 AM
    Gooiegoogoo
    Gooiegoogoo Well-Known Member
    Gustavo
    Phoenix
    03 TRD SR5
    2" lift
    I thought the Manual said you had to be completely stopped. I know you can change into 4hi on the fly up to 25 mph, I think. But elocker full stop then engage.
  4. Sep 11, 2013 at 6:50 AM
    JuansTaco
    Juan
    gilbert az
    im talking about the rear dif lock on a prerunner. you have to be stopped to engage but after that how fast?
  5. Sep 11, 2013 at 7:02 AM
    Janster
    Jandy
    Lancaster, PA
    The question should be - How fast are you going when you NEED to use the locker?
    What does your owners manual tell you?
  6. Sep 11, 2013 at 8:55 AM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
    Well, it locks up and goes as fast as you want to. Just know that the faster you go, the greater risk you have of a failure. Straight line driving, unless on sand, should be no problem. Just remember that if you are going to steer, with it locked, it will be much harder. I wouldn't lock it up on asphalt period. Toyota put the restrictions there for liability reasons. Add 4x4 and the locker and you have a very hard to maneuver vehicle. The prerunner didn't have speed regulations because of this. So......bottom line, start slow and work up to speeds that you are comfortable with.
  7. Sep 11, 2013 at 9:44 AM
    taco47001
    taco47001 Newborn
    Aurora, IN
    LX470
    The "warning label" on my drivers door indicates up to 5 mph.
  8. Sep 11, 2013 at 10:03 AM
    JuansTaco
    Juan
    gilbert az
    why is sand/dunes a problem? thats where i would be using it
  9. Sep 11, 2013 at 10:03 AM
    Mr. Biscuits
    Mr. Biscuits gentleman and a scholar
    Brennen
    Eugene, OR
    2000 3.4L Prerunner
    - OME 881s, Dakars + D43XL - Custom front tube bumper - 33x10.5R15 BFG KO2s - Deckplate mod + Airaid intake tube + AFE reusable air filter - Aero Turbine 2525 exhaust, chopped before leaf spring - Toyota Horns emblem by Diaz Fabrication - BOSS CarPlay head unit, 500W amp + 12" Pioneer in ported box - camper shell
    The locker shouldn't be engaged at anything more than 5mph and operated above 15mph.
    But I play it safe.
  10. Sep 11, 2013 at 11:01 AM
    Afwrestler1986
    Johnstown, NY
    Straight line driving, except for sand. Meaning, straight line on any terrain, but turning and such on sand should be ok.
    As long as the terrain allows for slipping. Like not engaging four wheel on black top.
  11. Sep 11, 2013 at 11:54 AM
    JuansTaco
    Juan
    gilbert az
    oh ok
  12. Sep 11, 2013 at 12:47 PM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    Engage it while stopped, as for how fast you can go ? Ive gone up to 80 with mine locked in. Wont hurt it but dont try turning going that fast with it
  13. Sep 11, 2013 at 12:54 PM
    taco47001
    taco47001 Newborn
    Aurora, IN
    LX470
    :eek:
  14. Sep 11, 2013 at 12:58 PM
    JuansTaco
    Juan
    gilbert az
    What if it's in the dunes or sand
  15. Sep 11, 2013 at 1:12 PM
    bellassaiw10
    Currituck NC
    I wouldn't be doing 80 in sand unless my truck was built for it lol I've gotten up to like 50 in sand with no problems but again you wanna keep it in a straight line cause things could bind up
  16. Sep 11, 2013 at 1:12 PM
    bellassaiw10
    Currituck NC
    The warning label is just there so avoid lawsuits
  17. Sep 11, 2013 at 1:18 PM
    taco47001
    taco47001 Newborn
    Aurora, IN
    LX470
    I know, but 80!!! Holy... Not that 80's even that fast...in 4x2...even 4x4 engaged for that matter. But with ur locker engaged...80! That's a big risk. Even the most gradual of turns like what's on a highway have your wheel spinning at different rates. Compound that to the speed of what's similar to mach 3 when ur talkng something like your rear end and something is bound to let go. Being locked in I think is stressfull enough for a driveline. Man, at 80 I think you're playing a game of russian roulette. Good luck on your impending repair....(no dickish undertones intended)
  18. Sep 11, 2013 at 2:02 PM
    bellassaiw10
    Currituck NC
    Done it tons of times haha nothing happened yet :p
  19. Sep 11, 2013 at 2:05 PM
    Janster
    Jandy
    Lancaster, PA
    We have 80.... Do I hear 85? 85? 85? Do I hear 85?? Do I hear 90?? 90....90???
    Going once.....going twice..... KABOOM!!!
  20. Sep 11, 2013 at 2:06 PM
    bellassaiw10
    Currituck NC
    2nd Gen problems:p
