TRD Locking Differential Operation
Discussion in '2nd Gen. Tacomas (2005-2015)' started by coolreed, Feb 4, 2010.
  1. Feb 4, 2010 at 7:13 AM
    coolreed
    coolreed [OP] Well-Known Member
    OKC
    06 PreRunner TRD Off Road
    20's, Chrome Grill,Handles,Mirrors. Sat Radio, Dynomax Exhaust K&N Air Filter, Bilstein 5100's, Cross Drilled Slotted Rotors
    My Taco is a TRD 2WD Double Cab. According to the manual you only engage the locking differential after you have stopped and only use it long enough to get one out of trouble then stopping to disengage it before moving on. This seems a bit lame to me bordering on useless.
    We had a pretty bad ice / snow storm recently and I left it on most of the way to work because the roads were very bad. Did I do wrong?
    I would like to know how some of the other Taco TRD 2WD owners have used their Locking Differential. And if anyone has some more insight from Toyota on this bizzarre (IMO) differential.
    :cool:
  2. Feb 4, 2010 at 8:43 AM
    Pyrite FD
    Pyrite FD Well-Known Member
    Indiana
    09 DC TRD Off Road
    whats useless about it?
    it saying use it when you need it, and engage in disengage when your not moving.
    same thing you would do with an arb. seems sensible to em, not sure what is so bizzarre?
    i personally wouldnt run locked in 2wd on ice though. 4wd i would, but not 2..unless i was just playing. snow i would in either, but its up to you if you know how to drive and handle and prepare for the kickout you will get.
  3. Feb 4, 2010 at 8:47 AM
    NumNutz
    NumNutz One of the original 7928
    Virginia Beach, VA
    07 Tacoma 4x4 - Kings, TC, Dakars, broken stuff
    Lots.
    DO NOT, use your locker in snow and ice. Unless you are stuck in a ditch it will put you in one.
  4. Feb 4, 2010 at 9:36 AM
    Packman73
    Packman73 ^^^^ 3%er ^^^^
    The free state of Arizona
    2007 TRD Off Road
    Bilstein 5100's (front set @ .85"), OME 885's, chris4x4 anti-Taco-lean spacer on driver's side, Total Chaos UCAs, Rear Leaf Spring TSB, Toytec AALs, Black FJ TT Wheels, BFG 285/75R 16 AT Tires, TRD Exhaust, Viper Alarm, Fog Light Mod, De-badged, Blue LED Dome Light, EZ Clamped Tailgate, Wet Okoles, Satoshi Grill, 5% Tint, Engine Tick Fix, Black Rear Bumper, Black Center Valence, Exhaust Cut At Axle, Thanks for all the help chris4x4!
    I've used my locker at 75mph on the highway for 30 mlies. It was an accident but no harm no foul.
  5. Feb 4, 2010 at 9:46 AM
    derekAV
    derekAV Well-Known Member
    derek
    Humboldt
    2000 4x4 reg. cab
    totally not useless! one of the main reasons i got my prerunner. like said above, dont use it on the street! way dangerous!
  6. Feb 4, 2010 at 10:00 AM
    Crom
    Crom Outside
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    I have gotten stuck in 4WD LO more than once and the locker has always gotten me unstuck. I love it.
  7. Feb 4, 2010 at 10:12 AM
    misterquad
    misterquad Well-Known Member
    I had LSD in Ford, Dodge, Nissan and Jeep. I wanted the Tacoma O/R specifically for the locker.
    LSD on the street gets squirrelly in corners during the rain. I prefer open differentials in the rain.
    I use the locker to get unstuck only. I use it only to get moving again. And in stock form, the computer will disconnect it after 10 0r 15 mph in the 2008s.
    Just wish it engaged more easily.
  8. Feb 4, 2010 at 10:16 AM
    BirdTRD
    BirdTRD Unsuspectingly striking from above
    Greg
    New Mexico
    TRD Off Road 4x4
    Front (2.75" total): 1.6" Eibach coils, Toytec 0.5" (L) & 0.25" (R) top plate spacers, 5100's @ 0.85", Built Right uniball UCA's, Differential drop, Removed sway bar Rear: TSB springs, Wheeler's 1.5" AAL, 5100's, 2* shims, Carrier bearing drop, F and R Spidertrax, 285/75-16 Goodyear Duratracs, Self-fabbed sliders, rear bumper, and skid plates, Cobra 75 CB, Bed lined slim lo-pro tool box, Bed Extender, Diff breather mod, Two tail gate security mods, Exhaust dumped behind axle, Can't leave shit alone so plenty more coming...
    Using a locker to get you unstuck or through a tricky trail section is wonderful.
    Using it driving down an icy road is VERY dangerous. If you go around an curve, the outside wheel needs to turn faster than the inside wheel. On dry pavement, a locked axle on a curve will at best ruin tires, at worst ruin your differential. On ice, a locked axle on a curve is going to try to push your vehicle straight instead of allowing it to turn. It will greatly increase the risk of breaking loose what little traction you already have. The possible ramifications of this are obvious. You are far better off leaving your diff open.
  9. Feb 4, 2010 at 10:24 AM
    derekAV
    derek
    Humboldt
    2000 4x4 reg. cab
    that sucks! mine doesnt do that!i got a 2010
  10. Feb 4, 2010 at 10:29 AM
    misterquad
    I am curious, why would you need the locker after you are moving? I don't understand why people need it at speed.
    Just wondering.
  11. Feb 4, 2010 at 10:31 AM
    BirdTRD
    Greg
    New Mexico
    TRD Off Road 4x4
    You don't need it at speed. In fact, at speed, you're much better off without it.
  12. Feb 4, 2010 at 10:39 AM
    coolreed
    OKC
    Most of my driving is on paved streets. I probably should have purchased a Taco Sport that comes with a limited slip diferential. A LSD seems more logical to me.:cool:
  13. Feb 4, 2010 at 10:43 AM
    derekAV
    derek
    Humboldt
    2000 4x4 reg. cab
    i use mine alot goin thru deep sand washes
  14. Feb 4, 2010 at 10:46 AM
    misterquad
    Okay, I misspoke after checking the manual again. The manual does not say the computer drops out the locker. It says don't use it over 5 mph. I must have read it somewhere else. Oops.
    Eitherway, I use mine to get it moving and then turn it off. That is why I bought it over LSD.
  15. Feb 4, 2010 at 10:47 AM
    BirdTRD
    Greg
    New Mexico
    TRD Off Road 4x4
    I also use mine in sandy washes, deep snow, and tough trail sections but that's all below 10 mph. I assumed when he said "at speed" he meant "at road speed".
  16. Feb 4, 2010 at 10:48 AM
    derekAV
    derek
    Humboldt
    2000 4x4 reg. cab
    yea mine says that too..lol i think its just for safety. yea i have LSD on mine as well.. very useful!
  17. Feb 4, 2010 at 10:49 AM
    misterquad
    I have not seen a sand wash since I left SoCal and that was 7 years ago. I miss them.
  18. Feb 4, 2010 at 10:49 AM
    doughboy
    doughboy Well-Known Member
    norcal
    hid head lights, hid fog lights, always on fog lights, bed lights
    good explanation. I think the OP misunderstood the use of differential.
  19. Feb 4, 2010 at 10:52 AM
    YayAreaTaco0311
    YayAreaTaco0311 Motivator
    California
    '09 TRD 4x4 O/R Supercharged
    OEM TRD supercharger, OEM wheels painted black by me, yellow sidemarkers, arb bumper, LED interiors, roll-n-lock, 5% rear windows, mudflaps removed, protector alarm, mobile trace, blacked out front Toyota emblem, debadged, & tree air freshener.
    I have a Prerunner w/TRD o/r and have used the locker to get myself unstuck several times while off-roading. I once parked on really wet grass for about 20 mins and when I tried to back up, my rear wheels dug in. Had to use the eLocker. Funny thing is, I have good tires. It's also important to air down before off-roading for more traction!!
  20. Feb 4, 2010 at 10:52 AM
    derekAV
    derek
    Humboldt
    2000 4x4 reg. cab
    what a bummer =/...im in the high desert haha so im in them all the time lol
