TRD LSD Install
Discussion in '1st Gen. Tacomas (1995-2004)' started by DadsToy, Oct 12, 2009.
  1. Oct 12, 2009 at 6:33 AM
    DadsToy
    DadsToy [OP] Active Member
    David
    Gainesville, Florida
    2001 Tacoma Double Cab 4x4 V6
    Snorkle, ARB Bumper, Warn Winch, Driving Lights, CB, 2 meter Ham,
    I bought a TRD LSD for my Taco and wanted to replace the rear diff carrier bearings before I install everything.
    The dealer doesn't have clue what the bearings are and says I have an 8.75" rear, can't be, right? It should be an 8".........
    NAPA doesn't have a listing at all..............
    Advanced says they have them for the 8.75 on special order.
    The bearings are the same with or without the LSD so what bearings should I get and where?
    And I thought this would be an easy install...... :eek:
  2. Oct 12, 2009 at 1:06 PM
    DadsToy
    David
    I take it that you all are just as lost as I am....... :confused:
    Is there someone I should ask specifically about this problem? Dealer? Friend? :rolleyes:
  3. Oct 12, 2009 at 3:08 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Its an 8.4" rear....no idea where they are getting the "8.75"" from....
  4. Oct 12, 2009 at 4:10 PM
    DadsToy
    David
    So it has an 8" ring gear and an 8.4" case?
    Thanks, now I have to find the bearings.
