TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Sep 3, 2019 at 4:29 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Happy 1000 pages gents! Wow, what a thread and what a progression we have made since the start of page 1. Here's to much more progress! :thumbsup:
    henryp, Hawk373, GT7 and 5 others like this.
  2. Sep 3, 2019 at 4:30 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    have to celebrate with a slab when this gets sorted out.
    12TRDTacoma[OP] likes this.
  3. Sep 3, 2019 at 4:31 PM
    australian hilux
    australian hilux Well-Known Member
    Justin
    2005 Toyota hilux v6 4.0L 1gr-fe
    None at this point
    Thanks for the video. When we had the sc off to install the LPG system is when we changed the bypass valve and going by that video we installed and set it correctly.
  4. Sep 3, 2019 at 4:31 PM
    australian hilux
    Justin
    None at this point
    Oh tell me about it!
  5. Sep 3, 2019 at 4:33 PM
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    Hmm, damn. That makes me question things....I don't know what things, but I have ?'s
  6. Sep 3, 2019 at 4:36 PM
    australian hilux
    Justin
    None at this point
    Make 2 of us! It’s frustrating as hell. Even more frustrating cause this is the last thing I have to do on this Ute. Then I can start using it for work. Bloody annoying. Hopefully it gets sorted soon. I’m heading to the dyno guy today and have another chat about what he has done.
  7. Sep 3, 2019 at 4:42 PM
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
  8. Sep 3, 2019 at 5:08 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Do you have a boost gauge? What psi is full psi, with which size pulley, when the vacuum hose is disconnected?
    Do you have a scan tool of any kind that can display engine timing and throttle position when boosting with the vacuum hose and without? If so, relay those timing differences with and without the vacuum hose.
  9. Sep 3, 2019 at 5:09 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    I wish i could've found a TRD one. I was too late to the party. These are made of fiberglass though so they should be a nice alternative
  10. Sep 3, 2019 at 5:14 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    The TRD ones were notorious for splitting on the sides.
  11. Sep 3, 2019 at 6:07 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    i wonder how a core swap would work. a few of us get rebuildables then pass on ours to other members. just a thought. checked ebay and them pickin's were slim.
  12. Sep 3, 2019 at 6:28 PM
    australian hilux
    Justin
    None at this point
    From what the dyno guy said it running around 6-7psi. The issue is the boost just fades away as the rpm gets higher. I have a 2.5” pulley on.
  13. Sep 3, 2019 at 6:30 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    something is causing a leak down at a specific pressure. or its an ecu thing. my only guess.
  14. Sep 3, 2019 at 6:34 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    if its very consistent id hedge a bet its ecu. a leak should vary slightly upon thottle demand i would think.
  15. Sep 3, 2019 at 6:40 PM
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    @australian hilux , forgive me if I missed your mention of it, but is your truck reflashed to what we call the “TRD Tune”? Do you know, or better yet, can you find out what your Calibration ID is? Some OBD2 scanners can display it.
    I’m wondering if you’re still on a N/A calibration.
  16. Sep 3, 2019 at 7:07 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    @australian hilux this is the wizard you want to talk to!
  17. Sep 3, 2019 at 7:19 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    well said.
  18. Sep 3, 2019 at 7:31 PM
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    The bypass valve is only open when the engine is in vacuum. I can’t see how your engine can suddenly have vacuum starting at 3000 rpm.
    This sounds to me like a fueling problem. Not like a fuel pump/pressure problem, but more like the ECU is not adding correct fueling.
    12TRDTacoma[OP], Torspd and Norton like this.
  19. Sep 3, 2019 at 7:32 PM
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    This ^
  20. Sep 3, 2019 at 7:45 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    its gotta be his tuning if mechanical connections are new and done correctly.
