TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Sep 5, 2019 at 5:29 AM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    I would get a ecu programed as close as it can to your truck, so have them flash it to your transmission be it auto or manual. The only issue would be the vin number and the immobilizer. Idk if your hilux has one from the factory.
  2. Sep 5, 2019 at 5:31 AM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    Also since I just woke up another solution would be a haltech ecu. You could get a bloomslang harness to whatever haltech ecu you chose and tune from there.
  3. Sep 5, 2019 at 5:33 AM
    australian hilux
    australian hilux Well-Known Member
    Justin
    2005 Toyota hilux v6 4.0L 1gr-fe
    None at this point
    Yeah my ecu has an Immobilizer from factory. When the dyno guy tried to use the original ecu it’ll the Immobilizer kicked in. So all we have to work with is the ecu for the sc engine. I’ll find out more about this ecu you have sent me. Might be a good option. Thanks
  4. Sep 5, 2019 at 5:33 AM
    australian hilux
    Justin
    None at this point
    Like an over ride?
  5. Sep 5, 2019 at 5:38 AM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
  6. Sep 5, 2019 at 5:40 AM
    Lucario Runner
    Robert
    06 Toyota 4Runner
    Standalone. @Torspd and I have one
  7. Sep 5, 2019 at 7:04 AM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Plug and pray more like it. ;) :D
  8. Sep 5, 2019 at 8:33 AM
    Gerard6778
    Gerard6778 Well-Known Member
    Gerard
    2015 TRD Sport
    I'm going install a supercharger in the future, will a TRD Pro exhaust be sufficient? I did search this site for answers, but don't have time to go through over 1,000 pages on this thread.
    12TRDTacoma[OP] and BassAckwards like this.
  9. Sep 5, 2019 at 8:48 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    TRD catback is 2.5". Youll benefit most with a 3.0" catback with the blower for more flow
  10. Sep 5, 2019 at 8:58 AM
    rheath08
    rheath08 Well-Known Member
    Russell
    Bakersfield, CA
    Frankenstein's Monster
    converted AWD, RC62f swap, Supercharged
    @australian hilux you may want to check and see if the pins locations are the same for a us market ecu. If you have to re-pin or get an adapter harness, then a stand alone ecu may be a better route.
    JustDSM likes this.
  11. Sep 5, 2019 at 9:20 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I'm thinking the Mongoose cable, and short subscription to TIS. Reflash ecu to his type of transmission.
    Or....HP Tuners, then through email datalogs with @JustDSM to get it sorted out. HPTuner has more overall flexibility for the money though.
  12. Sep 5, 2019 at 2:27 PM
    australian hilux
    Justin
    None at this point
    Yeah got ya. Well that might just be an option. Definitely another avenue to go down if we have no luck doing what we are doing now.
  13. Sep 5, 2019 at 2:27 PM
    australian hilux
    Justin
    None at this point
    I’ll get some photos of the ecu and compare it to the US Tacoma ecu. Then go from there I suppose.
    JustDSM likes this.
  14. Sep 5, 2019 at 2:30 PM
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    I'm almost certain they use the same pinout. What year model is your Hilux?
  15. Sep 5, 2019 at 2:31 PM
    australian hilux
    Justin
    None at this point
    Question... is the vacuum line to the bypass the only
    2006 is the year of Ute and the engine is out of an 2008. No difference though between the 2.
  16. Sep 5, 2019 at 2:33 PM
    australian hilux
    Justin
    None at this point
    It got me buggered. If the vacuum is the only thing that controls the sc, what controls the vacuum? Surly the vacuum is not electtonic controlled?
  17. Sep 5, 2019 at 2:36 PM
    australian hilux
    Justin
    None at this point
    Well it’s friday today so I’m hoping to hear from the dyno guy before end of day. If I do I’ll relay the outcome
    Torspd likes this.
  18. Sep 5, 2019 at 2:39 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    The engine controls the vacuum. o_O
    DocME likes this.
  19. Sep 5, 2019 at 3:23 PM
    australian hilux
    Justin
    None at this point
    Hey JustDSM, is the calibration ID exactly the same numbers as well? So the only difference is you guys are EYWG1011 and we are EYWH1011?
    JustDSM[QUOTED] likes this.
  20. Sep 5, 2019 at 3:24 PM
    australian hilux
    Justin
    None at this point
    Sorry got the numbers mixed up. 0100
