TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Mar 13, 2018 at 9:12 PM
    #2001
    oni06
    oni06 Well-Known Member
    You get to keep it.
    Scott didn't uninstall after he installed it on my computer.
    Make sure you save the ZIP file he downloaded to some other location for later reinstall.
  2. Mar 13, 2018 at 9:24 PM
    #2002
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    That is great news!
    Post rotors, during boost, the air is as you stated "pushing". Pre rotors, during boost, it is still sucking. Just with more force.
  3. Mar 14, 2018 at 1:29 AM
    #2003
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Sounds like your hose from the boost port to the pressure sensor isn’t right. I know you said the little adapter didn’t screw onto the sensor very good. Maybe try running the engine at idle and spray carburetor cleaner at that connection. If there’s a leak there, the vacuum at idle should suck in the carb cleaner and the idle speed should change (engine speeds up) due to injection of the carb cleaner.
    Why did he change the injector pulse width, did you install bigger injectors? Or was it because you were getting rich codes?
  4. Mar 14, 2018 at 8:57 AM
    #2004
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    Bc I got the P0172 (rich code). He was wondering if Magnuson changed their injector brand/company bc he thought that was odd and said it was something he normally doesn’t do. But since both banks were reading 10% rich, he adjusted injectors by 10% (????)
    I’ll see this afternoon about the carb cleaner test (I have MAF cleaner and break cleaner at the house, will one of those work, pretty sure the break cleaner at a minimum flammable). I’m working with AEM now after jegs tech support ran out of options.
    loginfailed[QUOTED] likes this.
  5. Mar 14, 2018 at 2:57 PM
    #2005
    Camby
    Camby Well-Known Member
    Brian
    Denver
    2006 Tacoma TRD Off-Road
    Magnuson Supercharger TRD CAI Catch Can After market dual exhaust Heated Mirror Kit Install Aftermarket Head and Tail lights Several accessory Mods
    So clean I could eat off of that. How many miles?
  6. Mar 14, 2018 at 4:09 PM
    #2006
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    Crazy to think but I’ve had this blower at least 10 years and coming up on 100k. I’ve been sporting @Coupe and his idea on the catch can. He has came up with many innovative mods on XRU
  7. Mar 14, 2018 at 6:18 PM
    #2007
    Skootter14
    Jeremy
    sent up the two data logs to Scott today, we'll see what he says.
    It was the first time I had done a dead stop to WOT...I squealed tires dang near the entire first gear and that truck can MOVE!
    Definitely not something usually seen in a 4DLB on 35" Trail Grapplers (IMO)
    Roostfactor, GT7, Biscuits and 2 others like this.
  8. Mar 14, 2018 at 7:17 PM
    #2008
    Camby
    Brian
    Denver
    Reading this comforts me in knowing that Magnuson did it right in making a 'safe' blower for tacomas. Would we all like to see 9,12,14 lbs of boost, sure of course, but seems like 6-8 is a sweet spot for 1GR-FE's longevity.
    loginfailed and Skootter14 like this.
  9. Mar 14, 2018 at 7:58 PM
    #2009
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  10. Mar 14, 2018 at 8:14 PM
    #2010
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Im at ten and it seems quite safe
    Roostfactor likes this.
  11. Mar 14, 2018 at 8:31 PM
    #2011
    TRON
    Boost is merely relative... What rpm the rotors are spinning is really what to judge.
    inwood customs and loginfailed like this.
  12. Mar 14, 2018 at 8:48 PM
    #2012
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    Good point. There is more to it than that but rotor rpm is a key factor. I actually ran the numbers of the more popular pulleys a while back to check exactly that. This all numbers are with engine rpm at 5000.20180105_171734.jpg
  13. Mar 14, 2018 at 9:49 PM
    #2013
    Skootter14
    Jeremy
    Heard back from Scott:
    Hi Jeremy,
    Thanks for the data – all checks out nominal.
    AFR and adaptives are dead nuts…
    No signs of knock.
    Good flow at 306 g/s for a stage-1.
    Let me know if the code pops…
    Cheers,
    S”
    He sent a pic that has a ton of lines all over it....I’ll post that in a sec.
    Anyone who wants to explain to me what “adaptives” and the “300 g/s” refers too I’ll be glad to listen. (I’m sure it’s air flow but I mean the more in-depth “why that’s good” explanation along with what would be a stock comparison to judge off of and what that number provides me/the truck and S/C)
    Roostfactor and oni06 like this.
  14. Mar 14, 2018 at 10:00 PM
    #2014
    Skootter14
    Jeremy
  15. Mar 14, 2018 at 10:22 PM
    #2015
    Roostfactor
    TX panhandle
    Adaptive is basically how much the UCON has to adjust to compensate for an improper afr.
    So let's say you are climbing a long incline at 75mph at 2lbs of boost. The UCON (as well as the stock ecu) takes a bunch of inputs such as throttle position, rpm, vehicle speed, maf, etc and with all those inputs it tells the fuel injectors (with no adaptive) that a nominal 50% duty cycle to the injectors should yield the desired afr. Then it gets the ACTUAL afr from the o2 sensors to see if it is correct.
    If it is correct then the UCON doesn't have to ADAPT to make a change to the afr.
    If actual afr is not what the UCON wants to see then it will ADAPT meaning it will increase or decrease the duty cycle of the fuel injectors to obtain the desired afr. The amount it has to change from nominal is the amount of adaptive that is applied. Clear as mud?
    G/s is grams per second of airflow that the maf is reading. For our engines a calculation of maf x 1.18 gives you a ballpark figure of crankshaft horsepower. 306 is very good, especially with a stock pulley and exhaust.
  16. Mar 14, 2018 at 10:27 PM
    #2016
    Roostfactor
    TX panhandle
    You can open your etune program now and play around in there to see all of the different data. It is read only so you can't screw anything up. Also, you can datalog whenever you want and review the log like the pic you just posted.
    Skootter14 likes this.
  17. Mar 14, 2018 at 10:27 PM
    #2017
    Skootter14
    Jeremy
    Thanks man. I can’t wait to learn more about this stuff. I’m pretty intrigued and my passion for this sort a thing is growing...like the truck build haha
  18. Mar 14, 2018 at 10:29 PM
    #2018
    Roostfactor
    TX panhandle
    No prob Jeremy, that's what we are here for!
  19. Mar 14, 2018 at 10:33 PM
    #2019
    Skootter14
    Jeremy
    ...306 (g/s) multiplied by 1.18 is 361...
    Is the truck making 361 hp at the crank with the URD TCAI and UCON (and sc of course)!?!?!?!? (Ballpark I know)
    loginfailed likes this.
  20. Mar 14, 2018 at 10:34 PM
    #2020
    Roostfactor
    TX panhandle
    Did you try the syringe to induce vacuum/boost to ops check you gauge?
