TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Sep 10, 2019 at 6:34 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Just depends on what the damage is. If it is just a ring lands and you had a thick enough oil, the cylinder wall may be just fine. Had that myself. Swapped in a new piston from Toyota and done.
    If the cylinder wall is good, but you want to add internals, JE or CP pistons, then BC or Molnar rods. Then head studs and head gaskets. Done. Cheap.
    BassAckwards, DocME, henryp and 2 others like this.
  2. Sep 10, 2019 at 6:39 AM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    it sounds cheap if you can do it yourself. me, not so much.
    Torspd[QUOTED] likes this.
  3. Sep 10, 2019 at 6:57 AM
    henryp
    henryp Well-Known Member
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    I know that feeling....
  4. Sep 10, 2019 at 6:58 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    :annoyed:
  5. Sep 10, 2019 at 6:59 AM
    henryp
    Henry
    Montana
    Which tune were you running?
  6. Sep 10, 2019 at 7:32 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Can you do an engine swap of a different style engine by yourself? Turn key?
  7. Sep 10, 2019 at 7:43 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    i could probably swap a lawnmower engine.
    TheFang likes this.
  8. Sep 10, 2019 at 7:50 AM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Have you guys considered a ceramic coat? They don't protect against off-road scratching, but they make daily grime cleanup and shine maintenance MUCH easier.
  9. Sep 10, 2019 at 7:50 AM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    This is like 2 trucks in the last 30 days now? Not good at all. And @o0opackersfano0o doesn’t even drive his truck that much.
  10. Sep 10, 2019 at 7:51 AM
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    I coated my truck. Freaking love it. The dirt doesn’t stick to it as easy as before. We will see how long it lasts.
  11. Sep 10, 2019 at 7:54 AM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    I have but I have the feeling that I may be too late in trying to apply it as I already have scratches, paint chips from rocks and the road as well as random clear flake offs due to a few door dings.
  12. Sep 10, 2019 at 7:54 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    i havent heard of such a thing. id consider it for sure.
    12TRDTacoma[OP] likes this.
  13. Sep 10, 2019 at 7:56 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    scratches, polish. chips, touch up paint. then paintless dent removal.
    Norton likes this.
  14. Sep 10, 2019 at 7:57 AM
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    Its never too late. It will require polishing the paint as it will lock in any defects underneath the coating. When I did mine I didn’t get everything out just a light one step polish to get most of it. Then 7 days later I went to big bear and installed some new pin-striping because why not.
  15. Sep 10, 2019 at 8:02 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I was actually considering purchasing an airbursh and a small pint of single stage OE paint mixed with clear for touch ups, I hear they do really well in blending to the current paint after sanding the area smooth with minimal observance of paint over on the affected area after.
    Hahaha. Your post made me Lol. :D I still have stripes from 2013-2014 on my truck to this day.
  16. Sep 10, 2019 at 8:03 AM
    Norton
    My Shelby and the wife's BMW are both coated - same experience as yours. Did the wheels and calipers, making brake dust cleanup a breeze! They were both done last year, so can't confirm long-term results either.
    Haven't taken the plunge on my Tacoma, but am thinking seriously about it.
    You might be surprised as how many imperfections can be corrected. The key is preparation before coating, since you're "sealing-in" the paint's condition when the coating is applied. We corrected and coated my son's (pretty rough) white '01 while he was home for the summer. I can't claim it looks new, but it shines and beads water REALLY well. The biggest benefit for "older" vehicles is probably how much easier maintenance becomes.
    FWIW, I'd recommend it. Like I said, your truck may not look new but, assuming it's corrected before application, it will look a lot better and maintenance will be much easier.
    Exactly x2!
  17. Sep 10, 2019 at 8:06 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Don't they call the stuff CeraKote?
  18. Sep 10, 2019 at 8:12 AM
    Norton
    That's one option, though I have no experience with it.
    I went with Gtechniq Crystal Serum Ultra topped with EXO on our cars, and Adam's on my son's truck.
    Even if you don't go with a full-blown ceramic coating, you might consider something like Adam's Ceramic Spray Coating - (relatively) cheap and very easy to use!
  19. Sep 10, 2019 at 8:16 AM
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    My buddy does it on the side. Ceramic is something you need to maintain and a good thing to do. However, the new and better thing he’s doing is sio2 coating. It’s a 12 month protection on the paint. He uses extremely expensive products that carry a good deal of silica in them. Prior to coating regardless of which one he’s doing. He does paint correction on the vehicle involving like a 4-5 step process of deconing the paint, striping the surface of all contaminants, then the wax, deconing it again and rewaxing and sealing......then the coating. It’s an 8 hour or so process........he’s making a killing and it ain’t cheap......
    Norton[QUOTED] likes this.
  20. Sep 10, 2019 at 8:23 AM
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    Yeah, I didn’t bother getting them all out before the coating, realistically a little 3000 grit wet sanding would take care of most if not all of them, then a quick polisher would fix that but again, why take them out if I am just going to reinstall them lol.
    Only a year? That doesn’t seem right but I haven’t used the coatings you have. You should try using an iron remover and a clay bar to see if you can restore it.
    In reality most consumer based ceramics are resin based, so you should use an sio2 spray every now and then to replenish the coating’s top coat.
    I am expecting 2-3 years on my coating.
