TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Sep 20, 2019 at 7:56 PM
    henryp
    henryp Well-Known Member
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    Sign me up. I’ll take a trans.
    Hawk373[QUOTED] likes this.
  2. Sep 20, 2019 at 7:58 PM
    Hawk373
    Hawk373 Well-Known Member
    2012 TRD Sport DCLB
    DMZ, ADS, King, JFR, SOS, ECGS, LSK
    I’ll be giving them a visit in a couple months. Just a bit north of me.
  3. Sep 20, 2019 at 8:38 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    so jealous, again.
  4. Sep 20, 2019 at 10:01 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    tell me more about this ipt trans
  5. Sep 20, 2019 at 10:04 PM
    nudavinci64
    Robert
    Can I get any 2013 AT ECU? Looking at a 2nd one to try and flash the TRD tune. Found a few for 60-80 bucks with about the same mileage as my truck. Wanted to give it a shot in case I need to replace it at any time.
  6. Sep 20, 2019 at 10:05 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Spec Stage 3+ is likely the most expensive, but will handle everything you can throw at it. I don't feel like discussing all of the torque numbers and tires sizes while pushing it to the limits. Held its grip and yielded not.
    ACT makes clutches.
    Centerforce make clutches.
    Don't use Competition Clutch for our trucks.
    Too many failures. Literally. Witnessed quite a few.
    I can only best recommend Spec Stage 2+ and Spec Stage 3+. Due to my personal experiences.
    Edit* Don't forget exedy as well. I think someone mentioned URD's twin disk, for the truly powerful needs.
  7. Sep 21, 2019 at 6:25 AM
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    And I thought I was the most ambitious when I arranged the stroker/sleeves group buy! If this ever happened, I would probably be in.
  8. Sep 21, 2019 at 10:57 AM
    richiep
    richiep Well-Known Member
    Rich
    NY
    2006 Tacoma Access 4WD SR5
    Trd s/c 2.85 pully Walbro 255 f/p Urd stage 3 clutch Hurst core shifter Afe cai
    Thank you
    TodayWasTHeDaY likes this.
  9. Sep 21, 2019 at 4:49 PM
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    I think I might have to start parting out my stuff to fund the ls swap. I think if I sell everything then I can commit to the swap.
  10. Sep 21, 2019 at 5:02 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    There is that detailed write-up on XRU. By the Canadian guy. Know which one I am referring to?
  11. Sep 21, 2019 at 5:04 PM
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    We stick together!!!
  12. Sep 22, 2019 at 8:10 PM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    So I did a little experimenting the last few weeks, figured I would share my report here.
    Basically lately I feel I haven’t been getting very good mpg (12.5 to
    15), and I wasn’t sure if something was wrong or if I had been enjoying the truck a little too much.
    So this last tank I totally babied the truck around. Well not babied, but on the freeway I have been trying go keep it around 65-70 mph (hard in cali, everyone wants to go 85+). So for the most part I followed that, but a few areas I did hit 75 when going down hill. And I only did like one pedal to the metal pull, maybe two in this tank.
    I filled up the truck tonight and much to my surprise, I had achieved 19.9 mpg! Of course it couldn’t just be 20 even.
    I am pretty happy with these results, thats about 70% fwy driving. But for a heavy truck on 34s, stock gearing, and a supercharger I am happy. And knowing that nothing is wrong with my truck, I just have to keep the mph down. I always knew it got better mpg at 55-70 mph, never knew it would be that big of a difference though.
    And this concludes my little experiment from the last two weekends. I figured why not post it since it has been slow in here today. Football must be keeping everyone busy :D
    Roostfactor, JustDSM, henryp and 4 others like this.
  13. Sep 22, 2019 at 8:18 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    i agree with your findings. weather has a huge impact as well. cooler temps provide much better hp output so when pampering with mileage tests you can do much better. tire weight is a factor. gyroscopic change from 33 to 34" tires is big. i just changed to 4:10 gears and my highway mileage suffers according. however having track star accelerating lauches makes it worth it. at 35 when i punch it (not full throttle) its goosebumps and grins.
  14. Sep 22, 2019 at 8:29 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Yep, I average 13.5ish regularly but if I’m not in a hurry and doing more hwy, such as babying my messed up ds back from the rubicon, I think I got almost 18 with my heavy ass fully loaded self and 35’s. It’s all about how you drive.
  15. Sep 22, 2019 at 8:43 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    true, stop and go idle traffic with intermittent spaz boost runs hurt mine. i just dont GAF until its a road trip.
    12TRDTacoma[OP] likes this.
  16. Sep 22, 2019 at 8:54 PM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Eggsactly. Luckily the truck isn’t a dd so poor mpg is not too important. Just need the trailer and tow rig in a few yrs and then who cares.
    36mpg avg on my trip to Cali this weekend.
    Murphinator likes this.
  17. Sep 22, 2019 at 8:59 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    thats great! mine is dd. and until i have no moneys i really dont care about mileage. this is a purpose built performance truck. it gets what it gets. definately the coolest tile assult vehile in seattle too
  18. Sep 22, 2019 at 9:05 PM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Hey I totally understand. But grabbing the dd last year was a game changer. Can mod at my leisure without worrying about being able to drive come Monday morning. Some badass Tacoma’s being dd’d out there. Many in this thread. Mine I dd in winter.
  19. Sep 22, 2019 at 9:22 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    my girlfriend only drives 4 times a month so i can use hers. but who the fuck would drive a kia instead of a boosted taco?!? but... its a backup.
  20. Sep 22, 2019 at 10:17 PM
    nudavinci64
    Robert
    Any feedback on this? Looking to find one and try flashing it in hopes of just swapping ECU after install
