TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Mar 15, 2018 at 4:43 PM
    #2061
    ThomasMore66
    Dallas/Fort Worth & Durango
    I think Marks 4wd out of Australia makes a kit to put an LS in a Hilux.
  2. Mar 15, 2018 at 4:44 PM
    #2062
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
  3. Mar 15, 2018 at 4:56 PM
    #2063
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    My best so far was 340.5
  4. Mar 15, 2018 at 5:11 PM
    #2064
    jojotoo
    jojotoo Well-Known Member
    Brandon
    Socal
    2015 DCLB
    My best is 337 g/s .. shifts around 5800 ish.
    I thinking about replacing my AFE CAI to URD.. Wonder if it'll make a difference. Plus, I can use the extra space.
    loginfailed[QUOTED] likes this.
  5. Mar 15, 2018 at 5:14 PM
    #2065
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I wonder why our shift RPM are different.
  6. Mar 15, 2018 at 5:15 PM
    #2066
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    What are wanting to put in that space, compressor? 2nd battery?
  7. Mar 15, 2018 at 5:21 PM
    #2067
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    Midgets.
  8. Mar 15, 2018 at 5:32 PM
    #2068
    jojotoo
    Brandon
    Socal
    2015 DCLB
    yuppers !.. probably both.
  9. Mar 15, 2018 at 6:16 PM
    #2069
    jojotoo
    Brandon
    Socal
    2015 DCLB
    @loginfailed have you installed your injectors ? 600 or 800 ?
    Ive been sitting on 800cc injectors... if it rains on sat might get them installed. Was planning on sunday but scott is only available on sat.
    Biscuits and loginfailed like this.
  10. Mar 15, 2018 at 6:38 PM
    #2070
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I have the 61 lb/hr (640 cc/min) injectors. I haven't installed them yet. Thinking about doing it Saturday if I can get session with Scott.
  11. Mar 16, 2018 at 1:35 AM
    #2071
    FinnJ
    FinnJ Well-Known Member
    Finland
    2007 FJ Cruiser 6M/T
    TRD SC, UCON, CNG conversion, RC 6" (lifted 4"/3" air suspension) w/FOX 2.5, 315/70R17 Duratracs, RECARO seats, etc.
    Oh well, but the best hp comes somewhere close to redline (after 6000 rpm). I’ve rev it to 6k (shift light) at least once a week.
    Not mine (copied from Torspd’s thread):
    Different tire size and/or different weight.
  12. Mar 16, 2018 at 4:03 AM
    #2072
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    I was always under the impression that the blower ran out of steam at the higher RPM's anyways. The graph and you are saying it keeps producing power?
  13. Mar 16, 2018 at 6:13 AM
    #2073
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Manually shift. It should take you past 5500.
    Roostfactor[QUOTED] likes this.
  14. Mar 16, 2018 at 6:16 AM
    #2074
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Which owner's graph is that? I believe it to be Butters. That HP curve is a Centrifical blower curve, if I am correct. They always have a linear progressive curve.
  15. Mar 16, 2018 at 6:21 AM
    #2075
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Not cheap. The few and the resourceful are the ones doing it mainly. Then a select few wealthy individuals. One of those now has twin turbos and is making a tad over 1k whp.
  16. Mar 16, 2018 at 6:41 AM
    #2076
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Yeah it’s all wishful thinking for me. :rolleyes:
  17. Mar 16, 2018 at 8:34 AM
    #2077
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    That’s not Coupes? That torque curve though
  18. Mar 16, 2018 at 8:35 AM
    #2078
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Correct you are.
  19. Mar 16, 2018 at 10:46 AM
    #2079
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
  20. Mar 16, 2018 at 11:17 AM
    #2080
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
