TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Sep 28, 2019 at 10:01 AM
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    It has to be 2019+.
  2. Sep 28, 2019 at 10:02 AM
    Roostfactor
    TX panhandle
    Surprised in a good way?
    What is your exhaust config now?
  3. Sep 28, 2019 at 10:07 AM
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    Play it safe like me.....2.7 will be heaven
  4. Sep 28, 2019 at 10:08 AM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    2.5 to really thrive.
    kgamsg and skyking3 like this.
  5. Sep 28, 2019 at 11:33 AM
    Roostfactor
    TX panhandle
    2.3 if you want to flee
    2.0 if you want to ???....GO!
  6. Sep 28, 2019 at 12:28 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Cause with a 2.8 you’re gonna be late and the 3.0 is way too slow
  7. Sep 28, 2019 at 1:46 PM
    zscott
    zscott Well-Known Member Vendor
    Zach
    Utah
    13 DCSB Off-Road 4x4
    Surprised in a good way. I have JBA headers URD y pipe and URD catback. It had a nice sound but was pretty loud. Now all I can Hear is the supercharger whine.
  8. Sep 28, 2019 at 1:49 PM
    zscott
    Zach
    Utah
    Same one I have
    Roostfactor[QUOTED] and zippsub9 like this.
  9. Sep 29, 2019 at 1:02 PM
    kgamsg
    kgamsg RedTaco
    Kevin
    Huntsville, AL
    PreRunner Sport
    Hard Tonneau, Cat-Back Exhaust, Heated Leather, Power Slider, OEM Running Boards
    still requires the snout to be cut back, right?
    12TRDTacoma[OP] likes this.
  10. Sep 29, 2019 at 1:07 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    yes. but its 20 min. of work you never have to do again. somebody has the cutter tool on here.
  11. Sep 29, 2019 at 3:00 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Unless you go 2.3 or smaller.
    BassAckwards likes this.
  12. Sep 29, 2019 at 3:01 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    do you have any pics on page one about how much more carving is needed?
  13. Sep 29, 2019 at 3:12 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    I ground my snout flush with the quickchange hub
  14. Sep 29, 2019 at 3:56 PM
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    Once you press on a quick change hub that’s a done deal cause a 3 jaw puller is not getting that off. Not that there’s ever a reason to remove it.
  15. Sep 29, 2019 at 3:58 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Nah, I did it. You just need a spare pulley for the quick change to potentially sacrifice in the removal. In my case I didn’t damage the pulley in removal either.
  16. Sep 29, 2019 at 4:17 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    that wasnt one of my worst ideas.
    crashnburn80[QUOTED] likes this.
  17. Sep 29, 2019 at 4:18 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    i thought for major s/c service breakdown the hub does need to come off. could be wrong but i thought i understood it to be that way.
    Athlaos likes this.
  18. Sep 29, 2019 at 5:06 PM
    TRON
    Why did you take it off in the first place?! Did you do a complete SC rebuild? Regardless, Wonder how those threads feel after pulling the hub off ;)
    Norton likes this.
  19. Sep 29, 2019 at 5:08 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    we accidentally pressed the hub too far.
  20. Sep 29, 2019 at 5:08 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    :anonymous:
