TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Oct 13, 2019 at 8:14 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    im not sure what the problem is though. custom carrier, 2* shims now in, driveshaft. ugh.
  2. Oct 13, 2019 at 8:19 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    4wd? You can pull the rear and drive around in front wheel drive if needed. I did that a while ago for about a week. Just try to keep from hard accelerations.
    Yeah if you did it all at once it will be hard to diagnose. Any idea what your pinion angle is at ride height?
    zerotimeouts likes this.
  3. Oct 13, 2019 at 8:25 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    i have no idea. i have the tremec app but it makes no sense. ill just see if i can pull it and get to the shop in time. no idea what their work load is or price. where would i find driveline specs for this truck? i could buy a gauge at harbor freight.
  4. Oct 13, 2019 at 8:52 PM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Yeah you can get cheap angle finder and measure. That could at least get you closer to figuring out if it is driveline angle or driveshaft out of phase
  5. Oct 13, 2019 at 8:55 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Get an angle on your driveshaft, then disconnect and get an angle on the pinion face, send it to ECGS. That's what they had me do to get my pinion angle for my Dana 60/
  6. Oct 14, 2019 at 12:33 AM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Oh shit. How the hell did they manage to do that? Take a picture of your driveshaft as a whole if you can, if you can't take a pic of your driveshaft close to the CB. I want to see what it looks like.
  7. Oct 14, 2019 at 6:28 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    i will this morning. question- should all 3 zerk fittings be inine? 2 of 3 are.
  8. Oct 14, 2019 at 6:29 AM
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    They should all line up
  9. Oct 14, 2019 at 6:33 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    thank you very much. bet thats most of my problem.
    we used a pneumatic 12 ton press to put the u-joints back together. can it be done with sockets and a hammer? or am i risking damage?
  10. Oct 14, 2019 at 6:34 AM
    mightytacoman
    Kel
    4.5L 1grfe
    Sockets/hammer you are at higher risk of damage, it's doable though
  11. Oct 14, 2019 at 6:36 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    choices choices.....
  12. Oct 14, 2019 at 6:42 AM
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    Sockets and c clamp maybe?
  13. Oct 14, 2019 at 6:44 AM
    mightytacoman
    Kel
    4.5L 1grfe
    simple bench vise works well too
  14. Oct 14, 2019 at 6:44 AM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    They don’t necessarily line up from the factory. Mine didn’t and I remember it always being a pain in the butt to grease the u-joints since I’d have to move the truck to get to all of them. When I replaced the carrier bearing and u-joints I fixed that so they line up.
  15. Oct 14, 2019 at 6:45 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    my thoughts exactly.
    Roostfactor[QUOTED] likes this.
  16. Oct 14, 2019 at 6:45 AM
    mightytacoman
    Kel
    4.5L 1grfe
    My mistake! Each Tacoma I've been under, they've lined up. Good to know. Apologies for the mis information
  17. Oct 14, 2019 at 6:46 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    so zerks may, or may not be an accurate guide?
  18. Oct 14, 2019 at 6:46 AM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    It would be nice and I bet they do on a handful of them. I just wouldn’t use that as a diagnosis for his current situation.
  19. Oct 14, 2019 at 6:46 AM
    mightytacoman
    Kel
    4.5L 1grfe
    Sounds like it is not a trust worthy way to tell
  20. Oct 14, 2019 at 6:47 AM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Unless you knew they were lined up before, no I wouldn’t use that as a diagnosis
