TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Mar 17, 2018 at 12:50 PM
    #2121
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    And I read somewhere about the crank pulley eating through crank seals?
    12TRDTacoma[OP] likes this.
  2. Mar 17, 2018 at 12:54 PM
    #2122
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    I see adding a bigger throttle body on our modified engines is a plus. Is this fairly common in which a lot of you guys have added it? @loginfailed How did you source your fj tb?
    loginfailed[QUOTED] likes this.
  3. Mar 17, 2018 at 12:55 PM
    #2123
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Nice.
    I agree as well, but I will take a better accel/ decel response though.
    I thought so as well. Anyone have any updates on this?
    That would be poor tolerance measurements or poor machining or a mix of both on their part.
  4. Mar 17, 2018 at 1:05 PM
    #2124
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    This is why I said that @Lucario Runner received his pulley recently. I've seen a few other people on FB displaying theirs, as well. They have gotten their act back together it, shows.
    It wasn't that the pulley was eating through crank seals. It was that the crank seals were grooving the aluminum pulley. Faster than the what happens on the steel OEM pulley.
    In most cases, people were not greasing the seal, and pulley before installation. Friction did what friction does.
    Consequently, a steel sleeve started to be installed with the crank pulleys. Regardless ,it is still highly recommended to grease the pulley and seal prior to installation.
  5. Mar 17, 2018 at 1:18 PM
    #2125
    ThomasMore66
    Dallas/Fort Worth & Durango
    Are there any underdrive pulleys?
  6. Mar 17, 2018 at 1:23 PM
    #2126
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    Wish I would have known they were avalible again. I would have put them on while I had everything apart.
  7. Mar 17, 2018 at 2:11 PM
    #2127
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I just checked eBay every so often for:
    22030-31060
    Got lucky one day and found one NIB for $118 shipped.
    JuanitoBonito[QUOTED] likes this.
  8. Mar 17, 2018 at 2:24 PM
    #2128
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Awesome , thank you.......chalk up another for the to do list....
  9. Mar 17, 2018 at 2:55 PM
    #2129
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    Tried setting the boost gauge up with teflon tape this time which AEM recommended. Still reading 0.0 so I think I have a bad sensor. I included the AFR as proof that the wiring and everything works. Hoping to get a new pressure sensor part from them and call it good. we'll see.
    Modified the craven speed gauge mount to fit these x-series gauges
    And here is the bad spark plug that I got in the box from magnuson which caused me a delay in getting another one for everything to work. Gotta contact them about it still...
  10. Mar 17, 2018 at 6:39 PM
    #2130
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    So the plug threads were butchered up like that out of the box?
  11. Mar 17, 2018 at 6:41 PM
    #2131
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Is the TB plug n play or does it need to be tuned into the computer? Also, did you have to trim the CAI due to the URD spacer
    loginfailed likes this.
  12. Mar 17, 2018 at 7:03 PM
    #2132
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Plug and play. All you have to do is disconnect the battery for several minutes. Once you restart the truck it will re-learn the idle speed. If you don't disconnect the battery, it will just idle at 1100 RPM.
    The more you move the throttle body to the passenger side, the more you'll need to trim off the intake tube.
    • If you just have JUST the throttle body adapter, you might be ok without trimming the intake tube.
    • If you have the only 7th injector, you have to cut the tube.
    • If you use have the 7th AND the throttle body adapter, you have to cut the tube AND extend the coolant lines.
    Rajadat and Biscuits like this.
  13. Mar 17, 2018 at 7:13 PM
    #2133
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    Good info man....I’m just gonna do the throttle body and adaptor. I wouldn’t have thought to disconnect the battery either so thanks for that too. :thumbsup:
  14. Mar 17, 2018 at 7:21 PM
    #2134
    Coupe
    Coupe Well-Known Member
    Houston, Texas
    08 X-Runner
    Lots baby!
    I can confirm that Allan Phillips did tune my truck.
    Torspd likes this.
  15. Mar 17, 2018 at 7:32 PM
    #2135
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
  16. Mar 17, 2018 at 7:44 PM
    #2136
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
  17. Mar 17, 2018 at 7:47 PM
    #2137
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    That’s the same question I asked when I received the URD adapter, lol.
    Yea it’s not hard to make the gasket. Kind of fun, actually. :thumbsup:
  18. Mar 17, 2018 at 8:22 PM
    #2138
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I used Mr. Gasket silicone. Easy enough.
    Roostfactor and loginfailed like this.
  19. Mar 17, 2018 at 8:43 PM
    #2139
    Skootter14
    Jeremy
    yea man, kinda messed up. You get the box of 4 all together, and then 2 singles in their own individual boxes. It was one of the singles. QC definitely missed something.
  20. Mar 17, 2018 at 8:46 PM
    #2140
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    There is more than one way to skin a cat :D
    Roostfactor likes this.
