TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Oct 18, 2019 at 7:33 PM
    henryp
    henryp A member of TW
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    Just over 100k. 35k with blower
  2. Oct 18, 2019 at 7:34 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    hmm. tell me how things progress brother. afraid ill be too soon to follow
  3. Oct 18, 2019 at 7:50 PM
    henryp
    Henry
    Montana
    Just don’t run the intercooler reservoir dry, have a good fuel pump, use good gas and be vigilant about it acting different. All things that happened to me. Stealership said all was well. I’ve had no engine codes pop up. It does misfire every other time I start it (based on my scanner). I ran a compression test and leak down. Had a local shop check my test (cuz I’m a little ocd about checking crap), they confirmed it.
    A friend of mine is a former master tech at Toyota. He wasn’t too surprised about all this and thought I might be better off spending a “little” more rebuilding it with better internals (forged pistons/new sleeves/crank, etc). He also said he liked the “gutless” 3.4L on the 1st gen better, lol.
    Edit: not trying to knock down the idea of getting a used engine. This is just a fun project. Could probably buy 3 used engines for price of this project. No the most economícal way to go.
  4. Oct 18, 2019 at 8:05 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    1st gens are great. but our engines are better. i changed my s/c pump to the mercedes high flow. i have a pile of gauges with constant data. (yes, i have ocd too) i do my best for what i know. but im plotting for a build yet hoping everyone gets the most out of their rig.
  5. Oct 18, 2019 at 8:39 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    still on the fence about 69 rpm and 2.3 or stock length rpm and pulley wrap with 2.3. 1st boost wold problems.feedback welcomed.
    12TRDTacoma[OP] likes this.
  6. Oct 18, 2019 at 10:37 PM
    Kelvin
    Kelvin Wheeeeee
    16’ GX460 with some junk bolted on
    So uh...brighter LEDs for my meth, anyone know of any? This thing is hard to see even at night. It’s brighter in this picture than it really is.
  7. Oct 19, 2019 at 7:11 AM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    You have to have mega OCD and be willing to do DIY work as well as be a bit of a car hypochondriac in order to make sure that these things stays running top notch all the time to prevent the issues that you had as well @DocME had. I am a freak when it comes to my running condition but that is also why all of my engines have lasted me time. It's too bad it happened to you guys, but at least we will learn through your mistakes.
  8. Oct 19, 2019 at 8:11 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    are you talking about taking it apart and replacing led's??
  9. Oct 19, 2019 at 8:41 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    found a core 4.0 on offer up in chandler az. asking price is 3$, runs.
    BassAckwards and henryp[QUOTED] like this.
  10. Oct 19, 2019 at 8:53 AM
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Rough shape kinda
  11. Oct 19, 2019 at 9:59 AM
    Kelvin
    Kelvin Wheeeeee
    Just that single led down by the ECT. It’s dimmer than a unlit candle.
  12. Oct 19, 2019 at 10:03 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    for the right price if youre doing a full rebuild it would work. it is kinda tough to judge from the photos.
  13. Oct 19, 2019 at 10:39 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    how about that green one i sent you?
  14. Oct 19, 2019 at 11:35 AM
    Kelvin
    Kelvin Wheeeeee
    Seems okay. I’m thinking of glueing two 194 LEDs into the switch blank lol
  15. Oct 19, 2019 at 11:42 AM
    Kelvin
    Kelvin Wheeeeee
    Here’s the whole setup
  16. Oct 19, 2019 at 1:03 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  17. Oct 19, 2019 at 1:06 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  18. Oct 19, 2019 at 1:07 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    I do. But im waiting for parts before I do it.
    inwood customs and Torspd like this.
  19. Oct 19, 2019 at 1:37 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I'm waiting to install them and hopefully be the co-driver
  20. Oct 19, 2019 at 2:01 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    id ralley mine if i was in texas.
