TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Oct 24, 2019 at 3:22 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Not as cool as Spoon engines and T66 turbos.
    mr.trd and spencermarkd like this.
  2. Oct 24, 2019 at 3:23 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Any of you guys with a S/C have a Pelfrey plate bumper and winch? scoring a hell of a deal on one so I'm curious if I'll need to move the intercooler pump. I'm assuming so..
  3. Oct 24, 2019 at 3:31 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    My guess is you’ll be fine. I didn’t have any issues with my bumper and I chopped the cross member to raise it up. Unless there’s some internal bracing for the winch plate.
  4. Oct 24, 2019 at 3:34 PM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    Yes, I do. Yes, you will. I can send pics of my relocation.
  5. Oct 24, 2019 at 3:37 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Thanks guys. I'd appreciate some pics for sure.
  6. Oct 24, 2019 at 3:40 PM
    Kelvin
    Kelvin Wheeeeee
    16’ GX460 with some junk bolted on
    Not a legal CA swap sir
  7. Oct 24, 2019 at 3:43 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Your opinion isn't valid here 2 inchez.
    Just kidding bro. :D
  8. Oct 24, 2019 at 3:46 PM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    There ya go. You gonna color match or paint black? Maybe blue?
  9. Oct 24, 2019 at 3:49 PM
    Kelvin
    Kelvin Wheeeeee
    Small lives matter homie
  10. Oct 24, 2019 at 3:54 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I believe he is going with Rainbow color. Just ask @BassAckwards he's all about that color as well.
  11. Oct 24, 2019 at 3:56 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    That's great to hear!
  12. Oct 24, 2019 at 4:02 PM
    racebug68
    racebug68 Well-Known Member
    Travis
    Chandler, AZ
    05 DCLB 4x4 TRD SPORT SILVER
    I can't leave anything well enough alone
    I'd like to see the pictures of intercooler pumps with winch bumpers. I have a CBI bumper and haven't installed my blower yet, but know there will be challenges with pump mounting.
  13. Oct 24, 2019 at 4:08 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    by buddy has a SC and pelfrey and 12k winch and nothing moved. He did cut one part that used to support the stock bumper ( I did the same as well) you should be good.
  14. Oct 24, 2019 at 4:11 PM
    nudavinci64
    Robert
    While I am waiting for the SC install been putting off a few maintenance items. Recently noticed it this week the truck seems to be driving fine but my MPG took a fast dive on this last tank of gas. Driven a bit over 1/4 tank and only gone 19 miles. Been holding off on the plugs for the SC but may need to do it now. Any other things I should check out first? Working on engines not an area I know too much on outside of the general items. Recently done the general maintenance such a air cleaner, oil, etc. Not getting any error codes when I read it either. if its a plug or injector etc that will all get replaced soon enough but cant be getting 100 miles a tank in the mean time. I have been seeing avg mpg go from 11-12 to 8ish prob even worse on this one.
  15. Oct 24, 2019 at 4:21 PM
    henryp
    henryp A member of TW
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    Check tire pressures.
  16. Oct 24, 2019 at 4:25 PM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Been pretending you have the sc already and had an exceptionally heavy foot? 10-12 is on the low side of what you should be getting with the sc unless you’re wheeling, towing, etc
  17. Oct 24, 2019 at 4:44 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    i moved mine some. was able to use stock hose too. using a factory threaded hole.
  18. Oct 24, 2019 at 4:46 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    do you have a hole in your fuel tank? thats some sour mileage.
  19. Oct 24, 2019 at 6:18 PM
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    It could be cool. Still want a PD blower
  20. Oct 24, 2019 at 6:57 PM
    nudavinci64
    Robert
    that would be some shit but no have not smelled or seen any gas leaking. a bit stumped.
