TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Nov 15, 2019 at 8:08 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    How long have you been running those spring packs for?
  2. Nov 15, 2019 at 8:08 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    well, someone else to advise jim's welding tecniques would be serious help. beverarge analist, 911 afficianato, lots of help potential.
    Torspd likes this.
  3. Nov 15, 2019 at 8:14 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    a couple months. the springs and hangers have been no issue. when my long travel units got welded in and i attempted that fucking idles carrier mount shit went south. since then i had my driveline reworked and stoxk carrier bearing mount back. upon checking i was out 2* put shims in and its better but not right. text me if you like.
  4. Nov 15, 2019 at 8:21 PM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    i went to a one piece driveshaft when i put the crawl box in. way better than dealing with the 2 piece shit. that carrier bearing is garbage
  5. Nov 15, 2019 at 8:28 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    ive asked about that but was hesitent about things from what ive read on max speed issues. id like to know more on your experience.
    loginfailed and nudavinci64 like this.
  6. Nov 15, 2019 at 10:46 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    What setup did you put in the rear?
  7. Nov 15, 2019 at 11:44 PM
    nudavinci64
    Robert
    Yah I am not against it. Not the happiest bunch but have some good parts none the less. Try to support the smaller guys if I can. Need a JFR or a modified version at some point.
  8. Nov 16, 2019 at 2:24 AM
    australian hilux
    australian hilux Well-Known Member
    Justin
    2005 Toyota hilux v6 4.0L 1gr-fe
    None at this point
    Hey guys.
    Quick question, how do you find the “bilsten” suspension? They came out standard in the Hilux TRD. Seem to have a good wrap. I’m looking at getting the 2” lift kit with heavy duty springs for carrying weight.
  9. Nov 16, 2019 at 3:25 AM
    australian hilux
    Justin
    None at this point
    Also,looking at what products LC engineering have... the have a piston that is 13:1 ratio. Cylinders need to be bored out a tad. Your thoughts? What else is recommended if I went down this path?
    I’ve emailed LC engineering to ask for theor input soniist waits for a reply.
  10. Nov 16, 2019 at 3:26 AM
    australian hilux
    Justin
    None at this point
    ...ask for their input so I’m waiting on their reply.
  11. Nov 16, 2019 at 3:27 AM
    australian hilux
    Justin
    None at this point
    Better combination= better fuel economy and more power so why not?!
  12. Nov 16, 2019 at 3:27 AM
    australian hilux
    Justin
    None at this point
    Combustion! Bloody hell!
  13. Nov 16, 2019 at 5:50 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I have a 4" aluminum, one piece. Won't be for everyone for certain. A 3" steel would be plenty strong for your needs. Just needs enough slip. May need a double cardan joint? Just need to discuss that with the builder. Tom Woods, makes some stout ones.
    I had extremely bad wheel hop from day one, with my '06 4x4 leaf springs. Just changing to the XRunner leaf springs, eliminated 90% of it. www.calvertracing.com is whom I chose to secure the last 10%. As their front attachment points pivot with axle travel to prevent travel binding. Other brands are static up front, and fight against the geometry of the travel. Calvert Racing makes them for the 4x4 and XR. Only true negatives are the metal heim joint noises, and the front bushing gets replaced with a solid aluminum piece. Which slightly adds to the overall noise. Wouldn't hear it over squeaky leaf springs by any means.
    I haven't any experience with the Bud Builts. No comment.
    I will say that the front Calvert mounts, plus their link bars, attached in a triangulated manner to the axle, with some Johnny joints, bushings, or heims, would do both axle wrap prevention and lateral movement prevention. At the cost of off-road clearance though.
  14. Nov 16, 2019 at 5:54 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Unless you're using corn juiced ethanol E85+, stay away from that compression ratio. It'd be a literally ticking time bomb. The combustion chamber isn't designed for that style of compression, with day to day driving in mind. Unlike the Mazda Sky Active engines.
    Find another ratio, or mod to supplement power goals.
  15. Nov 16, 2019 at 8:23 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I really need to start making turbo kits...
  16. Nov 16, 2019 at 8:25 AM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    1st
    loginfailed and BassAckwards like this.
  17. Nov 16, 2019 at 9:28 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    :cheers:
  18. Nov 16, 2019 at 9:31 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    In for a 2TR kit
  19. Nov 16, 2019 at 9:32 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I mean, I could. Already so easy with what's available to market though. Just need a truck if someone wants to make that happen.
    loginfailed likes this.
  20. Nov 16, 2019 at 12:04 PM
    australian hilux
    Justin
    None at this point
    Ah ok. So I’m assuming your advise would also be to stay away from a 12:1 ratio piston too?
    I’m just going off what LC engineering have in there parts list. Apart from the 12:1 which uses the standard bore, then it’s down to the standard 10:1 piston.
    So stick with standard or 12:1 may be ok?
