TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Nov 23, 2019 at 12:17 PM
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
  2. Nov 23, 2019 at 12:26 PM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    I'm holding my breath for the next GB.... I need this in my life
  3. Nov 23, 2019 at 12:28 PM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    I had less than 30k before switching out the sleeve. It was squealing pretty bad for a while. And the bearing was trash also
  4. Nov 23, 2019 at 12:45 PM
    LGOPs504
    LGOPs504 Nobody can hear you scream in Space.
    Danny
    Colorado
    09 TRD OR DCSB
    Stuff and things
    To be clear, you're saying that the sleeve is trash right? IIRC, you're running the CM hydro, if so, how's it treating you so far?
  5. Nov 23, 2019 at 12:45 PM
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Mine is seeping too. Need that
    loginfailed[QUOTED] likes this.
  6. Nov 23, 2019 at 12:59 PM
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    So is this something that installed in place of a regular tb
  7. Nov 23, 2019 at 1:00 PM
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    If they do let me know. I missed the last one
    LGOPs504[QUOTED] likes this.
  8. Nov 23, 2019 at 1:03 PM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    I'm hoping to get my entire clutch rebuild over black Friday...
    Maybe get me some HP tuners as well.
  9. Nov 23, 2019 at 1:05 PM
    wrmathis
    Bonaire, GA
    parts and stuff
    i THink the sleeve sucks. even after the sleeve was installed in squealed and the bearing wore out.
    I love the CM unit so far. easy clutch pedal feel and engagement. quiet as can be
    u remove the throwout bearing and clutch fork and replace it with a hydro activated bearing
  10. Nov 23, 2019 at 1:12 PM
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    It rides on its own sleeve overtop the original quill that solidly mounts to the face of the trans housing.
  11. Nov 23, 2019 at 1:13 PM
    LGOPs504
    Danny
    Colorado
    09 TRD OR DCSB
    Stuff and things
    JuanitoBonito[QUOTED] likes this.
  12. Nov 23, 2019 at 1:42 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    I would personally chase the stud, I don't like altering things on the block unless I absolutely have to but that's just the way I've always seen it.
    The way I see it is like this. An engine needs three things for it to work properly: air, fuel, and spark. That is the life blood of it. Without any of those the engine will not run and if there is a deficiency of one of those the engine will run, but not correctly and there will be increased risk of damages elsewhere due to that same reason.
    Many members are already aware of the physical size of the OE fuel pump and given that we are modding past the point of original OE intentions (which was NA all of this time) why would you risk your engine all to save a couple bucks on an item that you buy once and cry once over? Between the gauges and the pump, it is a toss up yes, but the fuel pump should be one of the very first mods you do on these trucks if you boost it and have even a twinkle of plans for go fast stuff later on down the road in your eyes.
  13. Nov 23, 2019 at 3:04 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    As @Torspd has always said, and I agree with....even if you think you don't need a new fuel pump, its better to have it and not need it than need it and not have it. pretty cheap insurance to prevent a loss of fuel under a hard pull.
    henryp, LGOPs504, TRON and 2 others like this.
  14. Nov 23, 2019 at 3:06 PM
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    With all the added goodies to the motor.......there is no reason not to upgrade the fuel pump.
  15. Nov 23, 2019 at 3:35 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Cheap insurance is exactly where I stand with it as well.
  16. Nov 23, 2019 at 8:18 PM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    is anyone else sitting here thinking like damn for all the $$$ I have put in this truck, I should just buy a Tesla cybertruck with the tri motor awd? Just me? these specs are insane tho. 18" ground clearance, flat belly, 0-60 2.9 seconds and 500 mi range :eek:
  17. Nov 23, 2019 at 8:28 PM
    Anderson
    Anderson Dudemanbro
    Anderson
    Benicia, CA
    ProBro
    Stuff
    It looks great on paper. Let’s see it out on the trail?
    I’m all for making forward progress technologically and environmentally. I just will wait to see how well it’s durability plays out.
  18. Nov 23, 2019 at 8:31 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    And I’m sitting here with single motor 4wd, 14” ground clearance, 0-60 eventually, and a 200 mile range.
  19. Nov 23, 2019 at 8:33 PM
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    I'm not sure how well it would do on the trail but it would be damn cool to try it out. I think it may be a little too big though. It's a massive truck.
    You still get 200 miles outta that beast? Not too shabby :D
  20. Nov 23, 2019 at 8:42 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    peak torque at 1rpm would be boss offroad.
