TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Nov 23, 2019 at 9:05 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    I'm not. I.c.e 4 lyfe
    Torspd and BassAckwards like this.
  2. Nov 23, 2019 at 9:53 PM
    RyanL
    RyanL Well-Known Member
    Indiana
    15 TRD Pro, supercharged, BP-51s, etc
    Elon said they’ll start making that model in 3 years, which really means at least 2023. By then there should be some good aftermarket cybersnorkel options.
  3. Nov 24, 2019 at 6:52 AM
    SteelCooked
    SteelCooked Well-Known Member
    13 AC Sport Black
    I had planned to install AEM gauges but recently saw a post that they don't work well with altitude. Are there any others out there that are worthy? Hoping to keep the same style for both afr and boost.
  4. Nov 24, 2019 at 8:10 AM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
  5. Nov 24, 2019 at 10:04 AM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    Speedhut manual gauges work well and so do Innovate digital boost guages only. Stay away from their AFR gauges!
  6. Nov 24, 2019 at 10:11 AM
    henryp
    henryp Well-Known Member
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    So innovate and AEM are a no go for AFR gauges? I think I see a new section on the OP (unless I’ve missed an update).
  7. Nov 24, 2019 at 10:14 AM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    my aem afr's are great. their boost gauge seems slightly off. probably the sensor, not the gauge itself.
  8. Nov 24, 2019 at 10:45 AM
    LGOPs504
    LGOPs504 Nobody can hear you scream in Space.
    Danny
    Colorado
    09 TRD OR DCSB
    Stuff and things
    I posted an issue I had with AEM boost gauge at altitude but I didn't get to finish their AFR gauge install as I was trying to sort out the boost gauge issue. As many others here have attested to, speedhut gauges are great. Their boost sensor adjusts to atmospheric pressure and gives a more accurate reading. I'm at ~7000' and am reading about 7 psi at Wot, about where I expect to be considering my setup.
    SteelCooked[QUOTED] and Norton like this.
  9. Nov 24, 2019 at 10:48 AM
    LGOPs504
    Danny
    Colorado
    09 TRD OR DCSB
    Stuff and things
    Anyone know where there's a good explanation for 2nd DTC codes? I just threw some referring to emission control circuits not reading properly; I'm assuming a short or toasted sensor but I want to research to see what my concern level should be.
  10. Nov 24, 2019 at 11:19 AM
    RyanL
    Indiana
    I’m considering Speedhut boost & afr gauges too, maybe we could get a group buy going ...
    SteelCooked[QUOTED] likes this.
  11. Nov 24, 2019 at 11:21 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    No no. Innovate gets my nod of approval for boost gauges, and my disapproval for AFR gauges and AEM gets my approval for AFR gauges and my disapproval for boost gauges (for the moment being).
    They are a great company, so if there is a an alternative way to get a MAP sensor and retrofit it to the AEM gauge then I'm sure it would be a much more solid setup as a whole. When I get back from my vacation I will investigate an alternative.
    What are your codes?
  12. Nov 24, 2019 at 11:31 AM
    LGOPs504
    Danny
    Colorado
    09 TRD OR DCSB
    Stuff and things
    [QUOTE="12TRDTacoma,
    What are your codes?[/QUOTE]
    P043E
    P043F
    P2401
    P2402
    P2419
    they are referring to emissions evaporative control circuits. Codes come back after I clear them, but all other inputs are fine and truck is running FMC. Could it be my O2 sensors?
  13. Nov 24, 2019 at 11:32 AM
    LGOPs504
    Danny
    Colorado
    09 TRD OR DCSB
    Stuff and things
    Also, if anyone wants my AEM AFR and boost gauges, I part with them. PM me if interested.
  14. Nov 24, 2019 at 11:42 AM
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    henryp likes this.
  15. Nov 24, 2019 at 11:44 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    P043E
    P043F
    P2401
    P2402
    P2419
    they are referring to emissions evaporative control circuits. Codes come back after I clear them, but all other inputs are fine and truck is running FMC. Could it be my O2 sensors?[/QUOTE]
    Oh crap. That involves your EVAP leak detection pump. That item is exclusively integrated into the canister assembly. If you are throwing those codes the odds are pretty good that pump is shot. How many miles do you have on your beast and do you offroad it a lot? I have had good success with blowing out my evap eystem when I had odd activity occurring with it. The system is sealed but it does not like getting a lot of dirt in it which it can do eventually over time, especially with wheeling.
  16. Nov 24, 2019 at 12:06 PM
    LGOPs504
    Danny
    Colorado
    09 TRD OR DCSB
    Stuff and things
    Oh crap. That involves your EVAP leak detection pump. That item is exclusively integrated into the canister assembly. If you are throwing those codes the odds are pretty good that pump is shot. How many miles do you have on your beast and do you offroad it a lot? I have had good success with blowing out my evap eystem when I had odd activity occurring with it. The system is sealed but it does not like getting a lot of dirt in it which it can do eventually over time, especially with wheeling.[/QUOTE]
    We'll poop. I have about 160k and I off-road often. This is the first issue I've had with it, so I guess I should consider myself lucky.
    Okay, what kind of drama am I looking at it with this? Fix ASAP kind of thing or I can wait a week or so? What about driving until it's fixed? It's my daily....
  17. Nov 24, 2019 at 12:48 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Okay, what kind of drama am I looking at it with this? Fix ASAP kind of thing or I can wait a week or so? What about driving until it's fixed? It's my daily....[/QUOTE]
    Well EVAP is ultimately EVAP. It involves recycling the vapors which the fuel in your tank naturally emits and reusing it for fuel economy purposes.
    If the leak detection pump is indeed shot then you will have to address it at some point to turn the CEL off. More so if you have smog coming up. The codes will cause no drivability issues as they are just emissions control items, so there is no major rush to address it immediately.
    Consider yourself lucky if you are barely having issues now. I was having issues by 70K with my EVAP system and it sounds like you wheeled your truck more than I have over its life.
  18. Nov 24, 2019 at 3:36 PM
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    Needs a canister. Or a hp tuner:cool:
    Norton and 12TRDTacoma[OP] like this.
  19. Nov 24, 2019 at 5:01 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    both
  20. Nov 24, 2019 at 8:24 PM
    Norton
    +1, with emphasis on "...you will have to address it at some point to turn the CEL off." Given that we have no emission inspection program here in El Paso County, you should be able to drive it that way as long as you can tolerate the CEL being on.
    Side note: What's up with all your quotes of each others' posts being screwed-up?
