TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Nov 25, 2019 at 10:50 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Dis me :spy:
    :fistbump:
    BillDaCat8 and Norton[QUOTED] like this.
  2. Nov 25, 2019 at 11:02 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    I've been running the same setup for 6 months with no changes. This morning was not abnormally cold or anything either so conditions were not atypical.
    I can check the fluids this evening, I am also running the CSF FJ radiator. I'd be surprised if there was a gasket failure.
    I'll have to see if I can pull the data, I know I can if I start logging before running but I'm not sure if I can retroactively retrieve it afterward.
    I've definitely done aggressive WOT runs in much colder conditions, so it would be surprising if the MAF topped out today but not previous runs. Agreed that a code does not necessarily pinpoint a problem, but is an indicator of something that has occurred in the system. My smart OBDII reader lists a P1605 'rough idle' in a Toyota as the description saying a knock control malfunction. I'm curious if maybe the system tried to correct for possible knock and fell on its face. Unsure. I definitely had a couple misfires under load while still having good power before the truck really ate it and lost significant power, leading me to wonder if the misfires under load caused the knock sensor to trigger.
    It is a 2015 with about 58k miles.
    I'll have to check. But it ran fine after sitting for a few minutes so I doubt the hose came off.
  3. Nov 25, 2019 at 11:03 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    How did you attach your gauges? My speed hut gauges don't use the same rear bolt mount as the flexpod.
  4. Nov 25, 2019 at 11:29 AM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    it could be your intercooler gasket got sucked in the motor. confused it a bit during digestion, then fine. in these temps you may not notice anything different without it. mine was partially missing. i have lower miles, and a catch can. could be something to check out.
  5. Nov 25, 2019 at 12:28 PM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    I don’t have any nuts or bolts on the gauges. I simply wrapped the gauge in one or two wraps of electrical tape and then worked them into the pod. They are very tight inside the flex mount and don’t need anything extra to hold them. Hope that helps. I have 2 1/16 revolution gauges.
    12TRDTacoma[OP] likes this.
  6. Nov 25, 2019 at 12:39 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    If you have misfires under load especially under high load that leads me to suspect that you are having spark blowout either caused by faulty plugs or the more likely of the issue, coil issues. I have seen coils fail at all sorts of mileages.
    Athlaos and crashnburn80[QUOTED] like this.
  7. Nov 25, 2019 at 12:49 PM
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    I like this theory.
  8. Nov 25, 2019 at 1:00 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    It would seem like high boost would blow the gasket outward, not suck it in.
  9. Nov 25, 2019 at 1:26 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    part failure happens. oil residue on intercooler can reduce flow. possibly enough to wiggle that gasket loose. mine ate a 3" section and i never knew. iirc if it does come loose it would get sucked in. probably why its such a soft foam.
  10. Nov 25, 2019 at 2:18 PM
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    Am I only one not running that intercooler gasket anymore? Shoot seems like a few years back people were taking them off to prevent the engine from eating it.
  11. Nov 25, 2019 at 2:32 PM
    zippsub9
    Halfmoon, NY
    14 DCLB
    That would explain why mine didn’t have one when I rebuilt it. I have a brand new one sitting in the garage. Not sure I need it or even want it now.
  12. Nov 25, 2019 at 3:18 PM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    I have AEM AFR gauge in a flex pod. Took some bolts, some threaded rod, and some work but I have it mounted and its solid. Had to extend the threaded rod on the back of the slim gauge to reach out the back of the pod. I had to add washers where the pod attaches to the steering column bracket because my gauge face rubbed the wheel when I turned, as well as sand down the two buttons on the front of the gauge because they stuck out too far and rubbed as well.
    In the end, I wanted to use the flex pod, so I made it work.
  13. Nov 25, 2019 at 4:09 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    i do.
  14. Nov 25, 2019 at 4:13 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    15747270493134403230362528026697.jpg yes, i chopped mine in half. needed them farther apart for my meth gauge between them. this is easy with a dremel.
  15. Nov 25, 2019 at 4:16 PM
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    Still have mine. Meth hasn’t even started to touch it yet. Very rugged.
  16. Nov 25, 2019 at 4:40 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    im just guessing but i think magnuson did their homework. knowing the gasket could randomly fail over time they must have chosen a soft/degradable material not to damage an engine.
  17. Nov 25, 2019 at 4:49 PM
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    Yeah it’s pretty common those innercooler foam gaskets or pieces of them get sucked into the intake ports after about 65k of use. I removed mine completely a long time ago even though foam isn’t going to hurt anything
  18. Nov 25, 2019 at 4:53 PM
    TRON
    I started that trend :D
  19. Nov 25, 2019 at 4:59 PM
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    Mines more of a fabric then just foam.
  20. Nov 25, 2019 at 5:19 PM
    mightytacoman
    Kel
    4.5L 1grfe
    That's what I thought. I won't be putting mine back in. When I disassembled the engine after it was under water, that foam was half down an intake tube barely holding on and it didn't take much to pull it off the rest of the way. Could be a poor glue they use to put it on, could have been the water. Probably a combination of both.
