TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Nov 26, 2019 at 12:19 PM
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    No worries my friend. We are all here to help each other. Everyone brain farts every now and then. :cheers::thumbsup:
  2. Nov 26, 2019 at 12:25 PM
    RyanL
    RyanL Well-Known Member
    Indiana
    15 TRD Pro, supercharged, BP-51s, etc
    @crashnburn80 what's the latest, how's the truck running today?
  3. Nov 26, 2019 at 12:35 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    WOT testing on the way home yesterday and the way to work this morning with zero issues. Truck runs like it never happened. Haven't yet had the chance to investigate more yet.
  4. Nov 26, 2019 at 12:35 PM
    Voodoo Rufus
    Voodoo Rufus Well-Known Member
    Bakersfield, CA
    07 Sport Indigo Ink DCSB 4WD
    Magnuson S/C, Relentless armor, Icon/Dakar suspension, Konig CountersteerX 17", KO2's, Hellwig rear swaybar, BudBuilt Trac Bar, Level 10 VBU, Weathertech floorliners, Cravenspeed antenna, Redline elite hood struts, RollnLock, Satoshi, CBI sliders
    About the same as I get. 13 city, 15-16 hwy.
  5. Nov 26, 2019 at 12:40 PM
    RyanL
    Indiana
    Great to hear. Last month I had a couple of days where the truck would pull timing at WOT, no other symptoms. Thought it was bad gas but it went back to normal before I added octane booster or changed anything.
    Running theory is the knock sensor went into defense mode then decided everything is ok after all, been fine ever since. Hoping yours is the same.
  6. Nov 26, 2019 at 12:40 PM
    RyanL
    Indiana
    +1
  7. Nov 26, 2019 at 12:41 PM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    Depending on which sensors we are talking about, doesn't one side have a longer wire than the other? For instance when I installed my URD ypipe I switched the sensors unknowingly, and then when I went to install my roost ypipe I had to install them on the correct side for the wires to be long enough.
    BassAckwards likes this.
  8. Nov 26, 2019 at 12:43 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    This is what i was about to say as well, i thought they were side-specific
    Murphinator[QUOTED] likes this.
  9. Nov 26, 2019 at 12:52 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    These are non issues really as the connector is the same for both upstream sensors, HOWEVER, their connector location makes doing simple sensor swaps an absolute PITA to do and the risk exists of pulling the wires from the connectors and good luck repairing the issue if you do. That's why to me, it is best to check their general voltages at idle and their amperage output. Combined, both readings will let you know if the issue is sensor based or if it is unrelated to.
  10. Nov 26, 2019 at 1:54 PM
    Roostfactor
    TX panhandle
    The rears are slightly different lengths. You can check the fronts to ensure they are the same part # but I am pretty certain they are the same part. If there is any difference in the front censors, the only difference would be length of wire.
  11. Nov 26, 2019 at 3:07 PM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    No worries. I have extenders in the garage for my URD headers that I can use if needed. However, when I went to drive home the light was off and no issues. I am sure it may be symptomatic and will check the voltage.
  12. Nov 26, 2019 at 3:24 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    The light off means nothing. The issue will likely return and will likely return with a higher frequency as time goes on. These trucks can see fuel trims of as much as +-15% and never trigger the light on so just because the light is gone doesn't mean it's still not running lean. You may want to take a look at the fuel trims again just to make sure.
  13. Nov 26, 2019 at 4:06 PM
    Roostfactor
    TX panhandle
    ^^This^^
    Why I like my dual afr gauges. :thumbsup:
  14. Nov 26, 2019 at 6:17 PM
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    Waiting for clutch masters Black Friday sale for hydro bearing. And lc engineering for some head studs. Anyone sees or hears anything let me no.
    LGOPs504 likes this.
  15. Nov 26, 2019 at 7:29 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    if you do urd is having a sale right now.
    jamesepoop[QUOTED] likes this.
  16. Nov 26, 2019 at 7:33 PM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    same.
  17. Nov 26, 2019 at 7:42 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Lol yeah that’s above average for me
  18. Nov 27, 2019 at 2:46 AM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    Ditto on the CM hydro... I also need Spec to have a decent sale.
    Torspd likes this.
  19. Nov 27, 2019 at 3:37 AM
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    11-12 all city. 14 all highway. 16 if kept below 70 MPH. Not horrible considering the performance it has and all the weight it carries from topper, bumpers, winch, tools, roof racks etc.
  20. Nov 27, 2019 at 4:37 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Mmmm. Spec
