TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Dec 6, 2019 at 5:48 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Id really like to run an RPM one if possible, even if i have to cut it. I kinda want this to be a one and done type of thing for a while for peace of mind, especially after reading about your issues with your serp belt chewing up your front main seal. Tis my paranoia kicking in again:D
  2. Dec 6, 2019 at 5:50 PM
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    I have a Champion on my Tacoma. The cap that came with it did start leaking, yes. I ordered a premium one from their website. It's been working fine.
    Edit: I think it was actually from Ledfoot Racing's website.
  3. Dec 6, 2019 at 6:09 PM
    BassAckwards
  4. Dec 6, 2019 at 6:24 PM
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    Do you need a stock radiator cap?
  5. Dec 6, 2019 at 7:32 PM
    Kelvin
    Kelvin Wheeeeee
    16’ GX460 with some junk bolted on
    Does it need to be a higher pressure cap?
    XPOTRPR[QUOTED] likes this.
  6. Dec 6, 2019 at 9:14 PM
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
  7. Dec 6, 2019 at 10:42 PM
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    All this talk about the NST alternator pulley and over revving the it. I have one on my TRDsport and no problems towing. Curious if there is a difference :cool:
  8. Dec 6, 2019 at 10:48 PM
    Roostfactor
    TX panhandle
    Mine is not NST. I think it's like 8% smaller than stock. No problems here so far. Installed probably 9 months ago.
  9. Dec 6, 2019 at 10:55 PM
    TRON
  10. Dec 7, 2019 at 5:16 AM
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    Hopefully the black Friday alt pulley shows up before next week otherwise it's install will get delayed
    12TRDTacoma[OP] likes this.
  11. Dec 7, 2019 at 6:53 AM
    jamesepoop
    jamesepoop Well-Known Member
    California
    2007 Fj Cruiser
  12. Dec 7, 2019 at 7:01 AM
    BassAckwards
    Tried their website and it keeps leading me to the standard gates belt. Doesnt look like they make an RPM belt for our accessory drive. Only for the stock length sc belt. Thats why i mentioned we'd need to trim one down thats a similar size
  13. Dec 7, 2019 at 7:02 AM
    jamesepoop
    California
    2007 Fj Cruiser
    @BassAckwards Edit: nevermind, seems like you found a close fit. Is it as easy as slicing the extra rib with a razor and using a flame to seal up the aramid cord? Not sure I'd trust loose cord over a factory belt but I've heard it being done
  14. Dec 7, 2019 at 7:07 AM
    BassAckwards
    Youd have to cut 3 ribs off the one i posted but yes youd need to trim down wiith a razor blade. Ive found you need to have 2 or 3 very sharp blades and keep changing them out to keep the cut super clean. If you do it that way you wouldnt have issues with the cord. I have messed up a sc rpm belt by not changing the razor blades out frequently when the blade got dull.
  15. Dec 7, 2019 at 7:41 AM
    jamesepoop
    California
    2007 Fj Cruiser
    I guess only one way to find out if that belt is going to work! At least you can carry your OE as the spare. If you're shredding belts though, most likely alignment is off or a tooth skipped somehow, somewhere between pulley or belt. So unless the issue is fixed... maybe we need a adamantium (marvel™) crank seal too lol
  16. Dec 7, 2019 at 8:28 AM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Good to know. Thanks man! I'll look into em.
    I'll just go aftermarket. I appreciate it.
    I was wondering about that too. Mines stamped 0.9.. in BAR of course. Roughly 13 PSI.
    I tried a fix last night. I bent the lock flanges on the cap to help create a tighter fit. When I head back home after work this morning and it's built some pressure I'm going to check it.
    Probably just go with the upgraded cap as @Athlaos mentioned
  17. Dec 7, 2019 at 8:54 AM
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    No sweat, just thought I’d offer. If you change your mind let me know. My oem cap is on my oem radiator in the CSF box up in my shed.......I can send it to ya.
    XPOTRPR[QUOTED] and Roostfactor like this.
  18. Dec 7, 2019 at 10:38 AM
    Kelvin
    Kelvin Wheeeeee
    That’s what I went to. Lexus stock cap is 1.1 But I switched to a .9 cap off a Tundra. Seems like I have less issues with the Tundra cap.
  19. Dec 7, 2019 at 1:38 PM
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    For that one guy out there (besides myself) still running a stock air box...
    So you broke off the little nipple for the hose that goes to the fuel pressure regulator? No worries.
    :thumbsup:
    D086F0E1-73C3-40F8-905D-AE286A2B0649.jpg 6C429BBC-9C74-4C2F-AB95-6400F26F3349.jpg EBD9E064-E1BD-4E0F-8F41-6FACFC59818F.jpg 1A21B96E-9021-4968-B9DA-46A504CE10D7.jpg
    mr.trd, Norton, jamesepoop and 5 others like this.
  20. Dec 7, 2019 at 2:38 PM
    Kelvin
    Kelvin Wheeeeee
    I didn’t break mine but that’s pretty much what I’m using for my intake I’m making.
