TRD/ Magnuson 4.0 Supercharger Tips, Tricks, and Mods
Discussion in 'Performance and Tuning' started by 12TRDTacoma, Nov 8, 2017.
  1. Dec 26, 2019 at 6:50 AM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Same here. Since opening up the exhaust, I'm down from 10 to 7 lbs. Seems to run much better and just feels happier.
  2. Dec 26, 2019 at 1:40 PM
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    Damn! I can’t believe boost went down that far based on the kelford cams. Did you open the exhaust up headers back?
    When I swapped my stock ypipe out for a custom APR style ypipe my boost went down 1 psi. I already had headers.
    Athlaos likes this.
  3. Dec 26, 2019 at 1:49 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    It wasn't just the Kelford cam that did all that, it was the increase of displacement as well which upped him from a 4.0 to a 4.5L 1GR. 6 psi makes sense. You increase displacement and change the cam on top of it which usually increases duration of intake and exhaust valves being open, and you just increased the overall airflow dynamics of the engine radically, without question the boost would go down with the same pulley you were using.
    I hit 12.6 PSI at peak with my 2.3 pulley. I'm thinking with a 2.3 he may hit at most 9-10 psi with all those fancy internal mods he did to his engine.
  4. Dec 26, 2019 at 1:55 PM
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    This. I'm hoping for 10psi with the 2.3. Probably 8 peak now but I can't rev it up enough yet to confirm
    Athlaos, Norton and TRON like this.
  5. Dec 26, 2019 at 1:59 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Whats everyone's thoughts on long term longevity with stock internals and a 2.3" pulley? I have read that the ring lands start failing around 11psi, so im wondering if a 2.5 would be the sweet spot for extra zip without sacrificing reliability.
    JuanitoBonito and Athlaos like this.
  6. Dec 26, 2019 at 2:04 PM
    TRON
    Awesome!! Curious what kind of power this 4.5 liter makes on a TRD SC?
    Anyway, this is 12.6 PSI on a stock exhaust, ypipe, and manifolds though right. I bet you would drop about 2 psi alone having an fully open exhaust headers back!
    So who did the engine work? Is it 4.4 or 4.5 liter @mightytacoman
  7. Dec 26, 2019 at 2:06 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    What is your break in? I'm thinking 1000-1500 miles is about safe before your oil change no?
    Well, I got about 2 years on mine, roughly 30K or more. 113K total miles.. if there were going to be any issues I would had seen them by now.
    BassAckwards[QUOTED] and Athlaos like this.
  8. Dec 26, 2019 at 2:08 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Yeah stock manifolds and 2.5 piping from the Ys from the cats on rearward. I would love headers but you know how California is. :(
    jamesepoop and TRON[QUOTED] like this.
  9. Dec 26, 2019 at 2:10 PM
    TRON
    Boost is relative so I don’t think it’s directly linked. The 2.3 pulley, supporting mods, and stock internals at sea level and cold temps is around 360/380 rwhp. I’m still sticking with the xrunners from the past and think anything under 400 rwhp is okay.
  10. Dec 26, 2019 at 2:12 PM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    400 rwhp is my goal on stock internals. I need to find a 1GR to build in the mean time.
    BassAckwards and jamesepoop like this.
  11. Dec 26, 2019 at 2:25 PM
    TRON
    I’ve never seen a legitimate dyno TRD SC over 380 rwhp. Except one and it had a nitrous setup that bumped him up to 415 I think. And there were a few e85 runs with the extreme APRx1 tunes that prolly hit over 370.
    Exciting times with the kelford cams though. Looking forward to some numbers especially the 4.5 liters :thumbsup:
    BassAckwards likes this.
  12. Dec 26, 2019 at 2:27 PM
    zippsub9
    Halfmoon, NY
    14 DCLB
    380 would be good enough. I don’t see meth or nitro in my future.
  13. Dec 26, 2019 at 2:28 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    A 4.5 liter with a 1.4L MP90 blower would be the relative equivalent of a 5.9L engine. Of course the power output given all of our mods would put out A TON more power and torque than engines of those relative size are capable of outputting. (At least, based on current outputs, gives me reason to believe so)
    Agreed. If I am hitting 370-380, I'm pretty happy with that output.
  14. Dec 26, 2019 at 2:41 PM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    Aww, come on man. Just a little taste of meth.... first one is free
  15. Dec 26, 2019 at 2:42 PM
    zippsub9
    Halfmoon, NY
    14 DCLB
    That’s what i am scared of, just the tip, scarred me for life
    jamesepoop likes this.
  16. Dec 26, 2019 at 3:07 PM
    mightytacoman
    Kel
    4.5L 1grfe
    It's 470cc larger than factory. If that's a 4.4 or 4.5 is up for some debate I guess. (~4430cc)
    Lower half assembled and block machined by R&L Engines out of Dover NH. The rest assembled by myself.
    Break in so far is break in oil till warmed up. Oil/filter changed. Break in oil till 300 miles with oil/ oil filter changed. Vr1 racing oil just added.
    Darton says not to go over 4000rpm under 500 miles. Not over 6000rpm to to 1000 miles. No synthetic under 5000 miles
  17. Dec 26, 2019 at 3:16 PM
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    I personally think for those people who see ring lands fail, they are not failing “because of boost”. Boost doesn’t blow engines. Knock or improper maintenance does. Change your oil often, use good oil, do things to control your knock, and you’ll have good reliability.
  18. Dec 26, 2019 at 3:59 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Yep, I've been saying something similar to that for years now. Power does not kill engines, poor tunes and lack of maintenance does.
    Sometimes piss poor luck does as well.
  19. Dec 26, 2019 at 4:36 PM
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    Disassembled mine before I ever installed it to caress the internals. o_O
  20. Dec 26, 2019 at 4:38 PM
    Roostfactor
    TX panhandle
    Seriously spiked cider i'd say!!! :D:thumbsup::D......:rasta:
